Hints and tips for campers and caravans. - Page 2 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > Caravaning, Camping and Equipment > Camping and Caravaning Technical
Old 10-09-2016, 10:48 AM
Originally Posted by rgren2 View Post
Will whiteboard markers work?
Yes. Write a note on the blackboard so you remember to get chalk.
Sent from my SM-G900I using Tapatalk
The Following 2 Users Say Thank You to skegbudley For This Useful Post:
Foo (10-09-2016), rgren2 (10-09-2016)
Old 10-09-2016, 09:31 PM
Foo's Avatar
Foo Foo is offline
U
Foo
RIP Mal, Ron and Bruce. Gone but never forgotten.
I don't suffer fools easily and so long as you have done your best, then you should have no regrets.
Old 30-09-2016, 09:59 PM
Here's another coupla.
If you have a fitting to plug a hose into your caravan, make up a sealed fitting to go over the inlet. This will stop dust and crud from getting in and wrecking the valves in there. I attach mine to the van with some whipper snipper cord, use heat shrink to prevent the cord from becoming untied.
We all freeze drinking water in a bottle, add water, use a stubbie cooler to keep it cold. Now, try adding some squeeze lime juice (the stuff you buy in the supermarket, green bottle for lime, yellow bottle for lemon) to the water before freezing and add some more to the water you add to the frozen bottle. Adjust the amount to suit your taste.
My water outlet is a normal female hose connection.
I got a male connection that screws on to a tap fitting and I filled it with silicone and I plug that into the female outlet when not in use to keep the dust and mud and water out.
Sent from my A1601 using Tapatalk
Old 25-10-2016, 01:15 PM
rgren2's Avatar
Default Hot water system anode.
I saw this on another forum and it's not my photo. I have ordered 2 new anodes and purchased a 27mm socket. I suggest you check your anode, cheap and easy to replace. Recommend to be checked every 12 months.
2008 GU Wagon. Hybrid. Silver Patrol Member#74. V8 Member # 17. Now retired doctrinaire extraordinaire
Old 08-11-2016, 10:10 AM
Whats the anode for (ie, what on a camper is it protecting)?
Old 08-11-2016, 12:44 PM
rgren2's Avatar
Hot water system in the caravan. Note to oneself, release water pressure before undoing anode. It does come out rather quickly and covers you with water if you don't.
Another note to oneself, take your phone out of your wet pocket.
Dead phone at the moment.
Old 05-03-2017, 09:09 AM
rgren2's Avatar
Sick of losing your tailgate clips? Whipper snipper cord, heat shrink tube, bingo, problem solved.
The Following 2 Users Say Thank You to rgren2 For This Useful Post:
geeyoutoo (21-04-2017), lornjohn (05-03-2017)
Old 08-03-2017, 04:52 PM
62woollybugger's Avatar
You can make curly cords to keep them neater. Get a piece of 12mm wooden dowel & drill 2 holes through it, about 100mm apart, that the cord will fit through. Poke one end of the whipper snipper cord through one hole, leaving enough for the loop poking through. Wrap the cord tightly around the dowel, until you get to the second hole & poke the cord through that hole. Put it into boiling water for a few minutes then put into cold water. When it's cool, take the cord off the dowel & it will stay curly. I make leashes for my rods etc for when I go kayak fishing this way.
2.8TD GU, OME shocks & Dobinsons springs ,2 3/4" exhaust, Bolsys sliders & now 63% slower
GOLD PATROL CLUB MEMBER #9
2.8 CLUB MEMBER #6
The Following 4 Users Say Thank You to 62woollybugger For This Useful Post:
lornjohn (09-03-2017), rgren2 (09-03-2017), shanfab (09-03-2017), Thrasher (08-03-2017)
Old 09-03-2017, 08:10 AM
rgren2's Avatar
Now that's a top idea.
Old 09-03-2017, 08:34 AM
4Bee's Avatar
Default 4.5kg gas bottle
Originally Posted by Leethal View Post
Warning for people with 9kg gas bottles on campers!!!
This won't be relevant for most people fortunately. In my case, the BOTTOM of the 9kg gas bottle is located by an 'X' shape bracket on the INSIDE of the ring that is welded to the bottom of the bottle as a base.
I got a full bottle (swap'n'go) the other day, only to find the diametre of the ring on the bottom is 20mm LESS than normal, so it would not fit in its spot.
I've never come across this before, so in future I will have to measure them while at Bunnings or wherever I change it.
Probably can't really tell from pic, but one on right is 20mm diameter smaller.
Keep it in mind if your 9kg bottle locates the base from the inside instead of the outside.
Same with the 4.5kg bottles Leethal, I recently made up a gas enclosure for my camper, and luckily had 2 bottles at home . . . different sizes!
I made the ring in my gas cabinet a bit bigger and then made a ring spacer to drop in the hole when I'm using a small one
06 GU TD42 Coil Cab Chassis
Tong Slide-on tilt-top Camper
Air bags on all corners, Genie 3" mandrel exhaust, 185lt water storage, drop boxes, Holley Red Lift pump, secondary fuel filter & more
The Following User Says Thank You to 4Bee For This Useful Post:
Leethal (09-03-2017)
Old 21-04-2017, 03:48 PM
Thumbs up
When planning stopovers I use this site to calculate distances and routes. Works for me.
Distance Calculator | Distance From | Find distance between cities
Great tips you got here buddy! Thanks a lot.
Old 21-04-2017, 04:25 PM
When pulling tent pegs out of hard ground, instead of busting your ass trying to pull them straight out, out another tent peg through the bent over bit and use it to twist/turn the peg as you pull it up... Easy
Back in a GU Ti with stuff.
The Following User Says Thank You to Richo For This Useful Post:
Chris.66 (24-04-2017)
Old 21-04-2017, 07:56 PM
I used to keep one larger tent peg just for that purpose but then at one particularly windy camp site, someone decided to bang my extra long peg all the way down to bury it in really hard clay ground, where it remains to this day.
So at a caravan and camping show I bought a rubber mallet that has a tent peg extractor hook on the handle. You hook it on and use like a slide hammer. So now I have both, a new large tent peg and the rubber hammer tent peg extractor, just as a backup plan.
Old 21-04-2017, 08:06 PM
GeoffA's Avatar
Yep. That works well most of the time.
For the REALLY difficult ones I use a crow bar.....yes, I do carry one...
Old 24-04-2017, 09:05 PM
Overboard's Avatar
I'm considering putting another set of shovel clamps on the side of my roof rack for a crow bar. One of the guys I frequently camp with brings one and there is nothing better for digging the deep narrow holes we make for latrines near our camps. Digging a hole that is 300mm x 400mm x 700mm deep with just a shovel is more than twice the effort of doing the same hole with the help of a crow bar. There is just the right amount of space on the side of the roof rack just above the shovel handle for a crow bar to fit nicely.
GU Series 1 wagon
Jan 2000
TD42T
Old 24-04-2017, 09:23 PM
GeoffA's Avatar
When heading up the PDR in 2014 an 80 series in our group dropped the lower bolt out of the rear panhard. The crow bar came in real handy for getting another bolt back into it. They can be a very useful item....
Old 25-04-2017, 05:29 AM
Foo's Avatar
Foo Foo is offline
Don't ya have any imagination Just need one with a bigger auger.
Foo
The Following User Says Thank You to Foo For This Useful Post:
Overboard (25-04-2017)
