What did you do to your GU/GQ Patrol today? - Page 11 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > General Technical Discussions > General Patrol Discussion
  #201
Old 19-08-2009, 10:26 PM
Madmav77's Avatar
the old girl ticked over to 370000 k's today
to celebrate, i bought some rims and rubber
01 4.2td coil cab DTS intercooler, 12psi, ET 35s, 3" zorst 2" lift, dual battery, 54" LED bar, 12000p tigerz winch
  #202
Old 19-08-2009, 11:50 PM
BORDERTREK 4X4 & FABRICATION
Pretty sad, I looked at mine in the carport again today and thought what a shame I cant get out 4 wheel driving and see more of this great country more often
Apart from that, its getting some Creepy Crawlers soon
4WD Accessories, Dobinsons & Ironman 4x4 Dealer, Welding, Auto Electrical Parts & Spares, Installation
Ph 08 8752 1389 b/hrs Mob 0400 250 734 b/hrs Bordertown SA
  #203
Old 20-08-2009, 12:27 AM
Quickest Tyre Deflator On The Market
Built My first hilift jack holder for the spare wheel carrier today,flash as! cant buy one for alloy rims so ARB says,But now iv'e got one and it's lockable,takes a rear light and I don't have to remove the whole thing to change a tyre as it goes behind the wheel, no such thing as 'cant.'
  #204
Old 20-08-2009, 09:20 AM
Bogmeister's Avatar
Show us some pics Ferret
Understanding the big bang theory is owning a ZD30
WPC 149
GPC 061
  #205
Old 20-08-2009, 01:09 PM
  #206
Old 20-08-2009, 01:16 PM
There are 2 small holes as you can see,one each side and they take 2 m6 setscrews that hld the bracket in place when the wheel is removed, other than that, no modification of the wheel carrier is required.
  #207
Old 20-08-2009, 01:24 PM
Originally Posted by THE FERRET View Post
There are 2 small holes as you can see,one each side and they take 2 m6 setscrews that hold the bracket in place when the wheel is removed, other than that, no modification of the wheel carrier is required.
The guys at ARB have told Me that K-Mar don't do a jack bracket for use with alloys, and there is a bit of modification to the wheel bracket if you want to fit the ones available, due to the thickness of the hub centre. Ah well, I've got mine!
  #208
Old 20-08-2009, 02:48 PM
Canuck's Avatar
naturally asthmatic
Grease and changed gear oils. Redline MTL 70-80 in the tranny and T-case now. Looking forward to seeing how that works this winter when its -20C. Just 80-90 dino oil in the front dif and 90-140 in the back dif. Tomorrow evening, I need to clean up some the skid plate bolts which got skidded on and put the skid plates back on. Oh, and wash all the oil marks out of the driveway from the oil I spilt before the wife gets back.
Cheers, John
... even on board computers can't compensate for stupidity.
VA7 CFS
  #209
Old 20-08-2009, 02:58 PM
Bogmeister's Avatar
Nice job Ferret
WPC 149
GPC 061
  #210
Old 20-08-2009, 03:00 PM
MRY61's Avatar
Fitted a Tough Dog RTC steering dampner and replaced my rear axle seals because the R/H was leaking.
2009 TB48 ST-L - Spoon engine, T66 Turbo, Motec System Exhaust.
MY13 Holden Captiva 7 LX - Family Hack.
2014 T-Box V4 Off-Road Camper - expensive garage ornament.
  #211
Old 20-08-2009, 03:37 PM
snapndash's Avatar
Fixed my clock today. Went around all the solder joints with the iron.
Connected it up. Worked sorta, kinda dull, then didn't.
Had to be the little 4.7uF, 16v capacitor.
Changed if for a 4.7uF, 25v one because it was the closest I had. (voltage in caps usually doesnt matter as long as you go up)
I had to fold it over because it is twice as tall as the old one.
Works beautifully, nice and bright. Very happy with it.
  #212
Old 20-08-2009, 03:50 PM
Nice job Ferret
Thanks Mate, so now I can swap
over to a shovel rack or the jack rack, using the same sleeve,it's a bit like a multi purpose outfit.Depends where I'm goin,fishn or floggn.
  #213
Old 20-08-2009, 11:35 PM
Looks nice mate.
It's a lot of weight to have levering on a GU door (the cracking problem) Them jacks can weigh as much as the spare.
  #214
Old 20-08-2009, 11:55 PM
Originally Posted by sudso View Post
Looks nice mate.
Yeah true Sudso, I spose if ya left it on all the time, I mean if you were on rough ground or bad roads constantly,you would need to look at strengthening the door eh, I had a bit of a look inside and I reckon it could be done with out too much fuss, I mostly wear the shovel bracket as I have more use for it. Handy to be able to swap one for the other if needed to lift out a jeep or a cruiser tho he he
  #215
Old 21-08-2009, 09:06 PM
BOOSTED GQ's Avatar
Fitted my rear locker and im happy as a pig in ***** should have got a pair years ago. Now I just have to fit the front one.
  #216
Old 22-08-2009, 02:25 PM
Roachie's Avatar
Chev 6.5 litre V8: no substitute for cubic inches
Default Spare tyres moved away from back of canopy.
In an effort to try to minimise the possibility of cracking my chassis again, i have been hell-bent on finding a way to get rid of the 100kg that was bolted onto the back of my canopy (IE: 2 x 315/75R16 MTZs plus their respective brackets).
I had to modify the back of the camper trailer so that I could mount one spare back where it was supposed to be (it was only designed to take a 33" max) and that left just one spare on the Patrol.
Still not happy, I've decided to put the remaining spare up on top. Ideally I want to get a couple of roof bars and mount it above the roof of the Patrol. In the meantime, I've chucked it up on top of the canopy as far forward as possible.
However, the top of that canopy is about 2.5 meters above the floor and at my age (54), I'm not able to hoist the bloody thing that high in a million years. In fact I found it very difficult to even get the spares up onto their spot/s on the back of the canopy and so i made up a lifter with a 2000lb leccy winch.
So, in order to now be able to get the wheel/tyre onto the roof, I've made up a jib that I can de-mount. It attaches to one side of the roof top of the canopy and swings around 360 degrees. I've bolted the small winch onto it and used some "Parramatta" rope and the pulley that came with the winch.
It's as rough as guts, but the bloody thing works great.
Now I've just gotta make up an extension cable for the winch with a 50amp Anderson plug on each end.
Roachie
6.5 litres of Uncle Sam's best iron!
  #217
Old 22-08-2009, 02:36 PM
That's the go Roachie, us old codgers need things to be easy eh, who cares if it's a bit
bustedarse,as long as it does the job,I'm still waiting for the bloke that lifts Me on and off to come back from hollidays!he he
  #218
Old 22-08-2009, 05:14 PM
DeansyGQ's Avatar
Checked engine oil & water levels. Booked in tomorrow to have radiator removed & cleaned properly. Good check-over under it's belly for nasty surprises, all good.
Moved on : 97 GQ RX2.8 turbo ltd....
#23 GQ 2.8 CLUB.
New Ride : 05 GU4 ZD30, 5 spd, Family Tourer...
  #219
Old 22-08-2009, 07:46 PM
Roachie's Avatar
G'day Ferret,
I shouldn't be "talking" to you mate.....your handiwork is far too good for the likes of me....
I look at the neat welding on that job of yours on the hi-lift jack mount and then I look at the spoggy-chit that I call "welding" and it makes me wanna puke!!!! hahahaha
Very nice job mate.
Roachie
  #220
Old 22-08-2009, 08:08 PM
Thanks Roachie, I'v got an old 3ph stick welder, about 50 years old,I grew up with it in My dads shed, good for small jobs, I use it almost every day. I hate welding, with a passion, but the Missus won't do it, so I'm stuck with it.
Press Release (Nissan Australia): Patrol more affordable.. Link Nissan Patrol GU/GR 7 04-11-2011 11:03 PM
Patrol loss of torque especially when towing meercat Nissan Patrol GU/GR 6 30-08-2011 01:34 AM
Press Release (Nissan Australia): Patrol more economical.. Link Nissan Patrol GU/GR 20 19-10-2010 01:08 PM
Welcome to the Patrol 4x4 Forum [Updated 17th Sep] Link General Discussion 11 16-05-2010 02:16 PM
Buying my first 4wd - GU Patrol? jarz85 Buying a Nissan Patrol 10 24-07-2009 12:28 PM
