What did you do to your GU/GQ Patrol today? - Page 51 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > General Technical Discussions > General Patrol Discussion
  #1001
Old 27-03-2010, 06:43 PM
Well exactly today, but over the last week
1. Put in a second hand power steering box, as the last one had destroyed itself internally,
2. New plugs (BPR5EIX)
3. Oil and grease
4. Pulled the fuel gauge sender and gave it some minor attitude adjustment so that it actually reads from full to empty now.
All on a 1990 Ford Maverick TB42
The ouch part was last week, $1600 on the aircon, new compressor, condenser and evaporator. Lots of coin, but oh is it so nice to have cold air again.
  #1002
Old 27-03-2010, 06:50 PM
coxsy's Avatar
Send a message via MSN to coxsy
fitted a superior adjustable front panhard rod to fix the axlecentre under the truck after a 75mm lift, will cut and lenghten the rear one this week
oh where does everyone put the pump for air lockers under the hood
  #1003
Old 27-03-2010, 07:00 PM
marin's Avatar
Send a message via MSN to marin
Under the pass. seat.
More coal, MORE COAL!!!!
  #1004
Old 27-03-2010, 07:51 PM
Fitted 3inch flexi lift kit
  #1005
Old 27-03-2010, 07:54 PM
gqmad's Avatar
Fitted aluminium mesh to my full length roof racks - now much more useable. As usual a simple project becomes a PITA when you can't buy the mesh in sheet sizes that fit the racks...
92 GQ, TD42T, 2" lift, Snorkel, 33x10.5x15 BFG KO2's, Spotties, UHF, Bullbar, Roof Racks, White Patrol Club #203
  #1006
Old 28-03-2010, 05:08 PM
GlynGQ's Avatar
had a grumble when i got home from a weekend of playing. realising i need to lift the bugger to be able to have any more fun with it. damn saggy old shocks and coils. very sad.
1988 GQ 4.2L diesel
Narva halogen spotties
Homemade Rear Drawer System
2"XGS shocks
Lovells springs
Diamond Automotive custom body lift
35" maxxis bighorns
  #1007
Old 28-03-2010, 07:37 PM
BOOSTED GQ's Avatar
Trying to clime a nice soft but very steep hill in second gear low range at around 3,500 rpm with the new 36" peedes the front right cv thought that it had had enough and went CRACK. Got home pulled the hub off and found the dog looked a bit odd and give it a pull and about 3" if the axle come out. It had snaped the end of the axle off in the stub. So now I have to fix that.
  #1008
Old 28-03-2010, 08:18 PM
bennoGU28's Avatar
Installed remote UHF speaker to the GME TX3420, plucked clutch/flywheel from spare donk a few days back and got the whole faschizzle on an engine cradle. Tried out new chain block lift donk onto cradle and assembled arrived jack stands and "garage panzer" 2150kg floor jack. Gotta figure out why its got no oil pressure (spare donk); main contenders look like being rooted oil pump, a worn out oil pressure relief valve somewhere or the bloody pickup got blocked. Started thinking about how to design flywheel to work with a sterndrive at work cause I was bored, put that off to sometime in the future, not bored enough. Cut up steel for the spare gearbox trolley, went round to mates house to get welded. Then it was teatime, so we finish welding tomorrow when he brings his mig home.
Decided to order another two engine cradles (for 1x RD and 1x RB) before tax time, figured forgiveness is more likely than permission
What the world needs is alot more rednecks
  #1009
Old 28-03-2010, 08:35 PM
Give it some goat
Send a message via MSN to 89 GQ
Adjusted tappets and gave it a good clean out. Touched up some of the paint so now it looks a little bit cleaner.
Methanol injection.... because lpg is for poofs
  #1010
Old 28-03-2010, 10:37 PM
Sent it off to the doctors for a new clutch. I knew when I bought it (3 months ago) the clutch was dicky. It wouldn't go into gear unless your foot was jammed to the floor but it wouldn't fully engage until your foot was almost off the clutch. I'll find out what the deal was in a couple of days.
  #1011
Old 29-03-2010, 06:33 PM
Send a message via MSN to NZDAN
Replaced drivers rear window mechanism, broke it yesterday, almost everything I touched yesterday seemed to break
  #1012
Old 29-03-2010, 06:54 PM
Sabbath Keeper
After pulling the rear bar off yesterday, I begun attacking the rust that had begun on the inside channel of the chassis ends... nothing too serious, but certainly needed addressing! I then gave it a good coat of enamel, then slopped a heap of fish oil up the channel as far as I could get it.... should do the trick!
After closer inspection of the rear bar however, (aftermarket) it's in pretty poor condition... as I begun taking the paint and rust build up off, I discovered many holes which had been filled with bog and painted over... NOT HAPPY JAN. Will need to look at maybe finding a welder/fabricator to chat with to see if the bar is worth ressurecting. Otherwise it's an unfortunate loss.
This is not what I need at the moment!!!
On a good note... I finally got around to installing my Jap spec tail lights... very nice!
  #1013
Old 29-03-2010, 08:53 PM
I took the oil pressure sensor off and fitted the master gauge from work.
My dash gauge was telling me, 2 kg/cm2 (28psi) at full pressure hot.
the master gauge says 50psi at the same temp and revs.
then while putting the sensor back in, i broke both the wires off.
  #1014
Old 29-03-2010, 09:07 PM
Removed this strange looking thing:
So i can put this one on:
  #1015
Old 29-03-2010, 09:43 PM
Jaido's Avatar
i like it dirty
Send a message via MSN to Jaido Send a message via Skype™ to Jaido
whats the difference?
is the second one a direct injected head or something
  #1016
Old 29-03-2010, 10:05 PM
Nah no difference, its just new
I had serious overheating problems and blowing bubbles through the coolant, it was probably just the gasket as I can't yet see anything wrong with the head (havn't had a good look though), owell at least I'll know it'll be fine when I'm done
  #1017
Old 29-03-2010, 10:07 PM
Had the radiator rodded flushed, pressure tested & general clean out.
Replaced fuel filter, oil filters, changed oils in gearbox, diffs as well.
Flushed the brakes, clutch with new fluids & went for a spin.
That was enough for today.
"Have 4x4 will travel",
"Leyland bro's got squat on me !!"
  #1018
Old 30-03-2010, 07:39 PM
tittezzz's Avatar
Default Fixed it
installed new starter, leads & drove the barsted thing
then put a carbi kit through it & now it runs well on gas & crap on fuel ah well Ill sort that tomorrow
GQ LWB duel fuel 4 inch lift, Tires, snorkel, extrackters 2.5 inch exhaust, bullbar, winch, lights, sunroof, CHAINSAW
  #1019
Old 31-03-2010, 12:33 PM
changed the headlights from sealed units to some semi sealed assemblies and some narva bulbs. can finally see something when the low beams are on
  #1020
Old 31-03-2010, 12:51 PM
installed new carpet, fixed rust in the roof, installed fixed aircleaner hose, install pertronix ignition and new coil, install brake bias bracket all i have left for now is the extended rear brake line
time to sell the patrol
Press Release (Nissan Australia): Patrol more affordable.. Link Nissan Patrol GU/GR 7 04-11-2011 11:03 PM
Patrol loss of torque especially when towing meercat Nissan Patrol GU/GR 6 30-08-2011 01:34 AM
Press Release (Nissan Australia): Patrol more economical.. Link Nissan Patrol GU/GR 20 19-10-2010 01:08 PM
Welcome to the Patrol 4x4 Forum [Updated 17th Sep] Link General Discussion 11 16-05-2010 02:16 PM
Buying my first 4wd - GU Patrol? jarz85 Buying a Nissan Patrol 10 24-07-2009 12:28 PM
