Diesel Chips / Diesel Engine Tuning: How its done - Page 10 - Patrol 4x4 - Nissan Patrol Forum
  #181
Old 24-05-2016, 08:13 AM
spacekadet's Avatar
Hey all, hey DT, I've just done a cheap rebuild on my rd28eti, one new piston, one new exhaust valve, faced head, honed one cylinder and one reco injector. Boost back to stock.
I was wondering if there is any way to put the Unichip back to factory standard for a bit.. Just for a few hundred k's, and do your rekon I need a retune?
Thanks.
  #182
Old 24-05-2016, 09:02 PM
Yes mate there sure is.
Best bet would be to give your local or closest unichip agent a ring. They should be able to give you the pin sequence to bypass the chip mate.
Do you know if its a Q chip or an older D12 chip.
The old chips are a long chip with large white connector on the end.
Newer chips are more square with a smaller black connector on them.
Factory Direct 4x4 Exhausts<Mention the forum for a good discount
Mechanical & Electronic Engine Tuning Guide
  #183
Old 24-05-2016, 09:16 PM
spacekadet's Avatar
Cheers mate. It's a q plus.. I'll give Matt a call.. Thanks.
  #184
Old 25-05-2016, 12:04 AM
Yep easy done. Its dead simple on the newer chips.
You just join same colours togehter.
White/ Yellow & White.
Blue / Yellow & Blue
Green / Yellow & Green
Black / Yellow & Black.
If you catch my drift, and they are always next to each other in the pin out left to right.
  #185
Old 25-05-2016, 09:44 AM
spacekadet's Avatar
So cut and join? Or bridge? I haven't pulled it out from its tucked up spot, so I don't recall what it looks like..
  #186
Old 25-05-2016, 07:06 PM
Nope dont cut anything.
If your local to Matt he can supply you with a proper terminating plug. Or at a pinch I have used both split pins and small pieces of wire into the end of the plug once its unplugged.
best of calling him I reckon.
  #187
Old 14-10-2016, 12:21 PM
Dan and Sarah's Avatar
Who is the best contact in WA to get a unichip fitted? Cheers
2012 GU Ti in progress
  #188
Old 14-10-2016, 07:13 PM
There is a few dealers in perth now I think. Best off just looking on the unichip website for the dealers PH number and phoning around.
  #189
Old 21-10-2016, 02:04 PM
i would use the proper bridge plug. There is a power and earth wire next to each other, brown white/red, don't jump them.
Andy
  #190
Old 13-04-2017, 07:51 PM
Thanks for your interesting post. This is a nice read experience for me to know more in this field.
