Recall on Nissan for airbag problems - Page 5 - Patrol 4x4 - Nissan Patrol Forum
  #81
Old 11-04-2016, 02:04 PM
GQ4B's Avatar
Had ours replaced this morning. In at 10:05am, out at 11:30am
I had initially removed the glove box and surround, simply to make it one less thing for the guys at the dealership to remove and refit. However, I decided to refit it all before taking it to them just I case they wanted to say we can't safely 'sign off' on the recall with that section not fitted - my paranoid thoughts!
Anyway, my cursory look on pickup in the dealership driveway didn't notice anything. Once I got home a more detailed look at the glove box and surrounds showed that one screw was missing altogether and another screw had been replaced with a slightly smaller sized one and of a different colour. Useless mechanics have lost 2 screws and replaced only one.
It's a petty complaint I know, but that will teach me none the less!!
  #82
Old 06-05-2016, 11:15 AM
Had it done today and had a primetime view on how it is done as the tech didn't even bother to put the truck inside workshop. The service advisor told me it is gonna take 1.5 hour...
The actual job took around 35 mins, he had the entire assembly out in less than 12 mins, then on the bench to remove flawed inflator tube to fit replacement and back in.
After the fitment the poor guy got confused when he powered the system and checked, he probably noticed that glow light is staying on instead going out after a few seconds (because I wired it that way so I can see when the glow system is on)
so he left the job for a foreman to figure out I guess to check what is going on.
Whatever they were doing afterwards took longer then actual recall job, truck sat there unattended for 40+ mins then obviously didn't make sense to them they opted out of it, just to tell me at handover.....all while I was looking at them.
I haven't noticed any stuff up yet after had a glance, all screws were there so the fingers crossed this is the last time I ever have to go there.
Regards
  #83
Old 06-05-2016, 11:25 AM
Regards
And you didn't take pics for us .
http://powercurve.com.au/
  #84
Old 06-05-2016, 11:32 AM
Haha, that thought never occured to me. I'm just glad the nightmare is over, I alwas dread when I have to rely on someone else with my stuff. Cheers
  #85
Old 06-05-2016, 12:44 PM
So what is your advice.
I have all the glove-box and stuff out at the moment after fixing my air-conditioner fan and condenser box. Is it better to give to them with this all out of the way.
I also have last year removed a Diesel Gas system but not stripped all the wiring harness yet. When looking up under the dash to make sure any of my wiring is out of the way of the air-bag, what do I find. The bloody Diesel Gas controller box had been fitted to the bar directly in front of the airbag. Lucky it was never needed in an accident or the controller box would have been fired out the dash with the air-bag.
The Following User Says Thank You to geordie4x4 For This Useful Post:
geeyoutoo (06-05-2016)
  #86
Old 06-05-2016, 12:50 PM
Whoa! that is an oversight and a half, was it a reputable company that fitted it?
  #87
Old 06-05-2016, 01:34 PM
Yes, but unfortunately they used a subcontractor (still a licenced auto gas installer with compliance plate etc). After the initial issues I had with mine, they stopped using this guy. But this was a little hidden surprise he left behind.
  #88
Old 06-05-2016, 01:51 PM
So what is your advice. I have all the glove-box and stuff out at the moment after fixing my air-conditioner fan and condenser box. Is it better to give to them with this all out of the way.
The tech removed the glove box and he reached in there disconnecting all the wires/plugs required then undid bolts/nuts whatever with ratchet and extension and then pulled the SRS unit downwards out of here. He had to lay on his back on the floor doing it, seemed uncomfortably bad position to be in. The less he needs to remove the better I say, especially if you are concerned about lost screws etc for the glove box attachemnt. I did clear out everything I thought they'd need to remove (centre console wise as well but it wasn't required) Regards
The Following User Says Thank You to rumcajs For This Useful Post:
geordie4x4 (06-05-2016)
  #89
Old 13-05-2016, 08:34 AM
Mine is now done. In at 7.30, out at 8.20.
