Wife filled the diesel full of unleaded - Page 2 - Patrol 4x4 - Nissan Patrol Forum
Old 09-01-2017, 08:57 AM
lobbylloyd's Avatar
Originally Posted by RicknJo View Post
Dave,
I made the same rookie mistake on xmas night when filling up to go away the next day. I unbolted the main tank and syphoned out as much fuel as I could. I reckon there was still 15 - 20 ltrs still in it that I couldn't get out. I then removed my fuel filter and pumped all remaining fuel out of my lines. Bolted tank back up, replaced fuel filter and filled with diesel. Started car and it ran like crap for about 10-15 seconds until the diesel pumped through. It has been running fine ever since.
Hopefully you have the same luck but the only difference is I didn't drive mine till it stopped.
Mine is 2008 as well
Same here; when I made the mistake the first time but I didn't replace the fuel filter and drove it till it stopped. A friend came to help and after he finished laughing and rolling on the ground, we drained the tank and filled it up with diesel this time. Started the car and it spluttered until the diesel pumped through. It has been running fine ever since.
The second time I only filled the auxiliary tank DOH. By the grace of the diesel gods it will never happen again. And the fact my wife reminds me every time I fill up.
Anyhow, I hope it goes well for you.
ST-L Club member 03
GU VI ST-L Auto Sept 07 3.0Lt TDI Gold, Alloy BB, Driving Lghts, HDTowbar, Alpine Satnav/Rev, Outback Dwrs, Cargo Barrier, ARB Dual Batt, GME UHF Radio, Alpine MP3 Radio.
Old 09-01-2017, 02:18 PM
davecass's Avatar
Default Update
Well after draining tank of 69ltrs unleaded and 19ltrs diesel I replaced the the fuel filter and vacuumed fuel from pump and filled new filter with injector cleaner SHES ALIVE and running very well so far so good.
Big thanks to the guys with the tips on what to do and to the nay sayers suggesting new engine etc your glass doesnt have to be half empty it can be half full.
The Following 12 Users Say Thank You to davecass For This Useful Post:
ants_oz (10-01-2017), awyd (11-01-2017), bignev (10-01-2017), edb (10-01-2017), geeyoutoo (09-01-2017), jimbodeluxe (10-01-2017), Leethal (10-01-2017), Paddy16 (10-01-2017), shanfab (09-01-2017), skegbudley (09-01-2017), slow (10-01-2017), Softy (09-01-2017)
Old 09-01-2017, 02:20 PM
Softy's Avatar
Well done.. Go buy a lotto ticket now.
2003 GU SIII Auto Grenade. 2" Lift, Full NADS, 3" Exhaust. Few other things
The Following 2 Users Say Thank You to Softy For This Useful Post:
05_ENFORCER (09-01-2017), davecass (09-01-2017)
Old 09-01-2017, 02:42 PM
shanfab's Avatar
***** hot , Stoked it worked out ok for you Dave , maybe buy 2 lotto tickets
My go at making a top mount W/A Intercooler.
The Following User Says Thank You to shanfab For This Useful Post:
Old 09-01-2017, 02:52 PM
Good start. Now you've got many years supply of mower fuel . One of my neighbours has been running his lawn mower for eons on petrol drained from diesels in his workshop and indeed I had the same many years ago. Let's keep our fingers crossed it was caught in time mate.
http://powercurve.com.au/
The Following User Says Thank You to geeyoutoo For This Useful Post:
Old 09-01-2017, 03:44 PM
dylan666's Avatar
Good to hear mate, dodge a bullet there!
If it didn't work, on the bright side you WOULD of had a full tank for your new shiny 6ltr :P
Hope it all goes good
The Following User Says Thank You to dylan666 For This Useful Post:
Old 09-01-2017, 10:06 PM
Yep, fingers crossed. Now forget the lotto ticket and spend your money on one of these instead:
Haha.
Rugby league: 13 guys 1 little ball.
Motorbike road racing: 1 guy 2 big balls.
The Following 2 Users Say Thank You to festerGU For This Useful Post:
Bigfella65 (11-01-2017), davecass (10-01-2017)
Old 10-01-2017, 06:11 AM
Hey mate,
Get a good dose of two-stroke oil into it ASAP. My recommendation would be to let it sit idling (running on the diesel/two stroke oil mix) for a couple of hours at least. Allows the entire fuel system to be flushed through, while placing no great loads on the fuel system.
The Following User Says Thank You to ants_oz For This Useful Post:
Old 11-01-2017, 05:49 PM
ricster's Avatar
Not too sure about letting it idle for hours as this has other consequences on the sleeves with glazing, but definitively keep adding quality 2 stroke oil to every tank, at least for the next few tank fills. In my TD42, I don't really measure out the amount of 2 stroke I put in when I do decide to chuck some in, so sometimes its about 200ml and sometimes its 300ml. It makes no difference on my motor... runs the same, just a little quieter.
The 2 stroke will just keep the pump and injectors well lubed after the petrol cleaned everything out.
Cedric
'99 GU TD42 - intercooled & Turbo ( the Iron Maiden )
Old 11-01-2017, 08:17 PM
MaxChickens's Avatar
Personally id stay right away from the T2 oil and put in an additive that is designed for go in a HP fuel system.
T2 is fine in a diesel that is basically the same as it was in the 1930s and the benefits have been proven.
Yet to see any benefit for a CRD that can't easily be written off as a placebo effect.
Sorry to be a negative nelly but id say you are up for an entire fuel system regardless.
When the time comes do it all in one go, dont do injectors then pump, or you may find that you need to do injectors again.
Sent from my SM-G930F using Tapatalk
Old 11-01-2017, 08:23 PM
I'd agree ricster. If anything has worn no amount of lubrication (2 stroke) is going to restore that wear. Once the 2 stroke mix starts running through the injectors then everything is back to as normal as it will ever be.
Just put the 2 stroke in, give it a few minutes to get through the whole system and start using the car as normal again. I would consider using the 2 stroke all the time though if you haven't been previously or at least as regular as you can remember. If there is wear then the extra lubrication from the 2 stroke could take up a bit of that "slop".
Old 11-01-2017, 08:27 PM
Disagree mate, you are correct that the CRD fuel system does not benefit as much as a DI does from 2T, the DI is definitely not a 1930's system and I can assure you first hand of the benefits of 2T for the DI.
In this case we are trying hard to get this system up and running without spending thousands so throwing in 2T at 150/200-1 is not going to hurt anything and may well help in the short term.
Old 11-01-2017, 08:35 PM
No your DI is 1970s system.
And the only data i have seen indicates that T2 in a CRD has negative effects.
I have given a opinion.
You gave yours.
There is no need to hover over threads and attempt to correct anyone with a different opinion.
And for cost factor mark my words it will be far cheaper to replace the entire fuel system right now.
Old 11-01-2017, 08:46 PM
Crd patrol benefits from 2T.
I trust the recommendations of Baileys, who know a bit about injectors.
The Truth About Adding Two-Stroke Oil To Diesel In Modern Common Rail Engines
2010 CRD Auto, White, ECU flash, Nomad valve body, Lockrite front, manual hubs, EFS coils, bullbar, winch, etc.
Old 11-01-2017, 09:07 PM
You gave yours.
I didn't correct, I disagreed as I know it definitely won't hurt and as said could assist short term, I'm looking at it from a positive low cost perspective, hell it's worth a try. I have not seen any data that says 2T hurts a CRD, actually the opposite in many articles I've read, but not as much as a DI.
Old 11-01-2017, 09:30 PM
Ok so there was no scientific testing done their what so ever it is an assumption nothing more. Good attempt to discredit me.
But this is stuff that i actually know and companies spent an extraordinary amount of time and money training me to know.
I have said my bit and that is that.
The OP can do as he pleases with all the info presented.
Old 11-01-2017, 09:31 PM
ricster's Avatar
yip.... well he can, if he chooses, to put some 2T in to assist the lube up, as I'm pretty damn sure it won't do ANY harm.... even if he does it for 2 or 3 tank fills. There after he can also choose not to add 2T .... but I agree with geeyoutoo, there is no harm in trying to save a few bucks until such time when he can look at doing your suggestion of a full and complete expensive replacement. Who knows, maybe he never needs to do the replacement..... only time will tell.
Cedric
Old 11-01-2017, 09:37 PM
You gave yours.
Why would it be cheaper to replace the whole system right now. Replace it now or in 2 years wouldn't the cost be exactly the same. (Ignoring inflation and exchange rates etc) Am I missing something.
I am also at a loss to understand why 2 stroke is detrimental to a CRD. There are plenty of CRD brands running it. I ran it for several years in a CRD MB engine as did many guys on the Jeep forum for one, without a recorded incident. I certainly got longer out of my injectors, high pressure and low pressure pumps than many blokes not running it and I don't recall anyone running it for an extended period that suffered premature failure.
I certainly wouldn't be replacing so much costly components till I was 100% sure it was all stuffed. If I had any idea that it was that dire I'd be trying to look at holding it together long enough to trade it in on something else.
Old 11-01-2017, 10:07 PM
Old 12-01-2017, 05:54 AM
Originally Posted by ricster View Post
Not too sure about letting it idle for hours as this has other consequences on the sleeves with glazing, <snip>
Well, our opinions are different - I have no issue with that.
My engine mechanical background allows me to know that leaving a modern diesel engine idling for a couple of hours will have absolutely no ill-effect on the condition of the bores (re: glazing). (This isn't an old two-stroke stationary engine)
diesel unleaded
