What did you do to your patrol today MQ,MK? - Page 194 - Patrol 4x4 - Nissan Patrol Forum
  #3861
Old 23-12-2016, 03:21 PM
Here ya go mate, keep in mind my standard shackles sat basically at 90degrees, think it's the springs, I needa take a few leafs out
Sent From The Seventh Floor Of Hell
  #3862
Old 23-12-2016, 05:16 PM
Johan Safari's Avatar
Looking at the left hand side leaf pack, you have way too much arc in the pack. Yes I know that is how you easily get a few inches lift, but it is the main cause if the angle problem (and a harsh ride). The biggest issue off course is that what leave packs like that is that all the travel is upwards, none downwards because of the natural arch.
So liberate some more travel downwards by flattening out the leave packs. I used to measure mine after bending to about 8 cm from the middle of the pack to a bar across the shackle mounts (no load). My angle used to be around 15 degrees out from centre.
You will have an amazing smooth ride and both lots of up and down articulation. I still have my leave pack bending rig, but I think you are a bit far away...
Johan
Datsun Patrol MQ '82 RB25DE Neo - LWB
Coils are for old timers
  #3863
Old 23-12-2016, 06:03 PM
Abcab's Avatar
Tell us a bit about the bending rig. My leafs run perfectly flat front and back, but of course I am not running MQ leafs.
Sent from my GT-I9300 using Tapatalk
David
South Africa
1996 D21 Sani/Hardbody 2.7TD
SFA on MQ UTE drivetrain
5" Lift on 33s
2 x TC's with 4.1 gearing
  #3864
Old 23-12-2016, 06:14 PM
The rig is somewhere under a lot of stuff in the shed. Basically it is a 30t bottle jack between 2 posts. The bending procedure is what is more important. I have posted the details somewhere on a forum years ago... will see if I can find it
Johan
  #3865
Old 23-12-2016, 06:32 PM
nutsy's Avatar
I would be interested to read that if you could find it. Abcab what springs are you running? I have heard of people using 60 series springs.
Sent from my SM-G900I using Tapatalk
  #3866
Old 23-12-2016, 06:37 PM
Yeah the fronts have heaps of ark, hoping they'll stretch a bit
  #3867
Old 23-12-2016, 08:25 PM
Abcab's Avatar
I am not really qualified to be on this thread because my rig is not a MQ. I have the MQ H260 rear and C200 front diffs/axles under a Hardbody SUV.
Running Hardbody rear springs with an additional blade to carry the 2.7TD motor that made the standard one tonner springs bend backwards
I'm just not getting the flex out of the springs and wondering if its not going to be better to just go three link later.
Its all still work in progress with the rear diff hopefully going in next week when I got some time off work and the rig can be taken off the road for a few days.
David
South Africa
5" Lift on 33s
  #3868
Old 23-12-2016, 09:37 PM
What leaves are you running?
I took the lowest leaf out of my dobinsons packs, lost about 10mm lift but gained a bit of flex and ride quality.
  #3869
Old 23-12-2016, 09:50 PM
There the heavy duty 'rock crawler' leafs, supposed to lift it around 45mm, I got the hd ones as I usually have dual batteries and a winch with steel Cable, thinking of taking one of the middle leafs out
  #3870
Old 23-12-2016, 11:28 PM
The shorter the leaf, the stiffer it is.
Each leaf in the pack directly affects the stiffness of the ones around it, so if you only want to soften a little, take a middle one out, if you want to soften more then take the bottom leaf out.
My leaves are heavy duty, I have dual batts and even with me sitting on the bullbar with the bottom leaf out, my weight (73kg) doesn't make a really noticeable difference to height.
  #3871
Old 24-12-2016, 06:05 AM
I can jump on the front of mine and it barely moves (69kg) bloody rough off-road too
  #3872
Old 10-01-2017, 11:38 AM
bruteutes308's Avatar
fitted 2 more window washer nozzles HEAPS better
The Following User Says Thank You to bruteutes308 For This Useful Post:
jazie (14-01-2017)
  #3873
Old 14-01-2017, 05:33 PM
fitted RTC works really good
  #3874
Old 03-02-2017, 09:25 AM
Just got my Carby back from getting rebuilt will drop it back in place tomorrow
  #3875
Old 23-02-2017, 10:44 PM
Took off my broken radio mast to see what I could do with it. Anyone find a good replacement? Factory ones are not available anymore apparently.
  #3876
Old 24-02-2017, 02:28 AM
I believe I still have a good one , not sure if it is viable to send it up you . I would say there would be other models that run the same aerial ( radio mast )
Sent from Alf Stewart's rape dungeon .
  #3877
Old 24-02-2017, 02:44 AM
Thanks,
Perhaps I will take the broken piece to the local auto wrecker and see what they say.
  #3878
Old 24-02-2017, 03:24 AM
I would say it would be a pretty common item on nissans of that vintage . I know he patrols are he same or very close
The Following User Says Thank You to Wish I Had Coils For This Useful Post:
jazie (24-02-2017)
  #3879
Old 24-02-2017, 07:35 AM
To suit Datsun/Nissan Patrol MK-MQ pillar mount antenna NEW! Aftermarket | eBay
  #3880
Old 24-02-2017, 07:38 AM
Aha! Hey thanks
What did you do to your GU/GQ Patrol today? yumpet General Patrol Discussion 12755 Yesterday 03:27 PM
Press Release (Nissan Australia): Patrol more affordable.. Link Nissan Patrol GU/GR 7 04-11-2011 11:03 PM
Press Release (Nissan Australia): Patrol more economical.. Link Nissan Patrol GU/GR 20 19-10-2010 01:08 PM
Welcome to the Patrol 4x4 Forum [Updated 17th Sep] Link General Discussion 11 16-05-2010 02:16 PM
Buying my first 4wd - GU Patrol? jarz85 Buying a Nissan Patrol 10 24-07-2009 12:28 PM
