What did you do to your patrol today MQ,MK? - Page 2 - Patrol 4x4 - Nissan Patrol Forum
Old 22-08-2010, 09:12 PM
Took my MQ shortie up to the mundaring powerlines and had a fat time. Alternator gave up in the last few hundred meters of the track, so guess Im pullin that out tomorrow after work.
Old 22-08-2010, 10:00 PM
Originally Posted by OutbackMK View Post
Radiator flushed. (a good handful of rust flakes and other goodies came out) Inspected front shocks. (disconnected top of shock, it moves up and down with little or no dampening looks like the front end float problem is solved)
Inspected front brakes. (The passenger side disk has been smashed and a good two inch piece is missing, it been ground off smooth on a bench grinder and just clears the pads" "Strike One to the Bush Mechanic". Ordered two new ones $31 each from Repco. (seems their old stock and going cheap!)
Getting a new shorty "Is like a box of chocolates, you never know what you get" (Forrest Gump)
Cheap all right , I got discs about a month or so ago, cost me 112 for disc and pads
I know repcoo are doing drums cheap, retail 160 something each, can get them for like 40 smackas, run out change of supplier.
Old 23-08-2010, 03:23 AM
Jelmer160's Avatar
Took it for some hardcore wheeling today!
'84 Patrol MK L28E turbo, SPOA, Y60 axles, PTO winch, shackle reverse with Hilux springs and 37" creepies.
'83 Datsun Laurel VG30DET 3.0V6 24v turbo
Old 23-08-2010, 02:45 PM
Today i am picking up my MQ
It has been at the mechanics, i had it put on straight gas.
cant wait till i get it back home,
The mechanic was sent the wrong parts, so then he had to
wait 2 days to get the right parts, after all that the job
went well. 1 step closer.
Old 23-08-2010, 03:19 PM
Pressure washed it last night to get rid of the salt water and sand...
Looked at it this morning...can't be arsed going to pickup the new top set so I can fix the head gasket with a genuine one....
It will get done...eventually...
Also, inquired about a new wastegate actuator.
Looking for a new WAIC radiator now too!
Old 23-08-2010, 08:04 PM
fix the back barn door as I found it would not open for some reason. r
reason being the the handle would not trip the catch to the second stage, so i shorten the rodd so it does now, ohhh the joy, Now i need a new handle as it snapped when i was trying to open it. any takers
Old 23-08-2010, 08:08 PM
GeoffM's Avatar
had it serviced
#54 CRD PATROL CLUB MEMBER
Old 23-08-2010, 09:03 PM
took it offroad, bent the rear bumper bad. All else was good! 1984 p40 patrol SWB. Running like new.
1984 K160 Patrol, 32 inch Cooper Tires, Edis ignition
www.teknik4x4.com
Old 23-08-2010, 10:08 PM
dat_610's Avatar
Got back from wheelin all day yesterday, now have to fix some stuff today......... well maby tomorrow lol
GQ TTD42, Sflex arms, 4" lift, 33"s, hks gtrs turbo, CC TMIC, custom 3" zorst, custom hi flow air intake and airbox, LR tank, loka, laminated front diff, dual batteries, rock slides. Built Not Bought!
Old 24-08-2010, 08:09 PM
OutbackMK's Avatar
Today new front shocks!
Where will it stop!
85 SWB SD33T 5 Speed 2" Body Lift, 2" Terrain Tamer Spring Lift Yokohama Geolander AT/s 31*10.5R15 Manual Boost Controller with 3" Dump and Exhaust. Sold
Old 24-08-2010, 08:51 PM
Doc Doc is offline
Send a message via Skype™ to Doc
Sold it
Old 06-10-2010, 10:09 AM
OutbackMK's Avatar
1st post on new hard drive!
Brought 4 new Yokohama Geolander AT/S 31 10.5R15, old Simex Centipedes walls broke up when braking beads so glad I replaced them. Hopefully it will be a bit quieter on the bitumen now.
Shame about the server dying, lost my on-line diary of all the stuff I've done since August, I'll have to go through the receipts and make a hard copy!
Old 06-10-2010, 12:01 PM
LordBug's Avatar
Worked out why she wasn't starting after putting the head back on.
Hadn't bled the air out of the IP - The filter & injector pipes definitely had fuel, I just didn't think to loosen the bleed screws and get rid of the air in there. Now she starts!
Old 06-10-2010, 12:49 PM
Ray!'s Avatar
Part of the furniture around here
Put on a new set of Bridgestone D694s, 275/65R17, for $282 each (fitted). They are sooo much better than the MT ATZs.
Ray
Nothing but Patrols since 1980
- He who has never made a mistake has never made anything.
- Many things have been developed by people who were not smart enough to realise that they were impossible.
Old 07-10-2010, 04:55 AM
Ch0ps's Avatar
Closed the bonnet.
1984 MK LWB Deluxe, SD33, Air-Con, P/S, Straight Body, No Mods.
Old 07-10-2010, 10:59 PM
Originally Posted by MADM4N View Post
Cut up an old bullbar to make a custom one... should look trick when finished!!
Did same last wkd. Chopped up old BB and used bits to make mounts for the GQ one I got of Ebay (sold as one that would fit MQ!).
Looks better than the old one, and lighter! Car looks a bit like Mr Maggoo though! Lol!
Old 08-10-2010, 02:15 AM
my friend started my front coil conversion
Old 10-10-2010, 07:18 AM
well (yesterday) i took out radiator and aircon stuff, few other bits and peices gettin it ready to take the motor out. today gotta drain the oil, dissconnect some more stuff and maybe just maybe get the motor out
Old 10-10-2010, 09:33 AM
dattopimp's Avatar
Send a message via MSN to dattopimp
Found out it still leaks like a sieve damn rain...picked up my GQ guards thursday/wednesday can't remember.
87 MK SWB.
2", 33" atzs or 35" MT117Es, dual ARBs, barwork, winch, bags, goodies, SD33t with the works.
Old 10-10-2010, 07:16 PM
OutbackMK's Avatar
Bonnet shuts now! Two hours with bars, jacks, bits of wood and heavy hammers, the car had been stacked before I brought it and the whole passenger front guard was, down an inch, back an inch
and in an inch. Inner guard still looks like a pig ear that the dog been chewing but its now nearly where it should be. While I had the radiator out I back flushed it well worth the effort and got a sh*t load of rust flakes out that didn't clear with radiator flush solution.
What did you do to your GU/GQ Patrol today? yumpet General Patrol Discussion 12762 Today 12:03 AM
Press Release (Nissan Australia): Patrol more affordable.. Link Nissan Patrol GU/GR 7 04-11-2011 11:03 PM
Press Release (Nissan Australia): Patrol more economical.. Link Nissan Patrol GU/GR 20 19-10-2010 01:08 PM
Welcome to the Patrol 4x4 Forum [Updated 17th Sep] Link General Discussion 11 16-05-2010 02:16 PM
Buying my first 4wd - GU Patrol? jarz85 Buying a Nissan Patrol 10 24-07-2009 12:28 PM
