MK Build thread ! :) - Page 11 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Models > Nissan Patrol MQ/MK 160/260 series
  #201
Old 05-10-2016, 07:30 PM
Johan Safari's Avatar
Originally Posted by DirtBag View Post
And horrible on hard ground with hubs locked ... (I forgot once when I came off the beach)..
I had a look at my struts and online, I can tell you the following stats ..
Extended length, 485mm
Compressed length 285mm
Newton metres 200
The online catalogues (Monroe Max lift etc) only want exact numbers but you can use a paper catalogue to get a near enough one, so long as the compressed length isn't more than 285mm. Sorry I couldn't help any more than that.
Sent from my HTC_0PJA10 using Tapatalk
My 82 LWB seems to be a bit different:
Extended length, 520mm
Compressed length 355mm
Stroke 165
Found this on Ebay
GAS Struts GAS Springs 525mm X 200N Caravans Canopy 2 Years Warranty Incl GST | eBay
Stroke is longer therefore the fully compressed length is shorter which does not matter right?
$34 free shipping. Better than the $130 I was quoted for a regas. Never did it because up till now I never knew what the newton meters was... Thanks!
Johan
Datsun Patrol MQ '82 RB25DE Neo - LWB
Coils are for old timers
  #202
Old 07-10-2016, 07:16 AM
Really do needa get around to making that thread on parts and we're to get em!, next week maybe, whats everyone paying for head gaskets? I've just got a pro-torque one for 130(retail@150), it's tho only one I could get a hold of
Sent From The Seventh Floor Of Hell
  #203
Old 07-10-2016, 07:25 AM
Even comes with torque and tensioning order
  #204
Old 07-10-2016, 11:53 PM
Last VRS I got was about $350 from memory. I'll double check tomorrow if I remember.
That was though Nizzbits, so all genuine Nissan stuff.
Not sure how'll you'll go with that gasket TBH, Nissan gaskets are the best you can get but it would be good to know if there is an aftermarket gasket (aside from getting a custom copper job done) that can handle the stresses of increased boost on an SD.
  #205
Old 09-10-2016, 06:32 PM
Well the old one is identical to this one and according to service records it's been there since 92 so hopefully this one will last a bit, I'll chuck some pictures up, old gasket was rooted
  #206
Old 09-10-2016, 06:34 PM
  #207
Old 09-10-2016, 06:46 PM
  #208
Old 17-11-2016, 09:03 AM
Replaced the tacho sender, still doesn't work!!,, anyone got a spare working tach I could buy?
  #209
Old 18-11-2016, 03:01 AM
Awesome build did you get rid of the death wobbles?
Quick question can you set 1/6 tdc without looking at flywheel? I need to set valves
  #210
Old 18-11-2016, 10:03 PM
Hey mate, I did end up shaking off the wobbles, nipped up my shackles and tightened the front u-bolts, off course after ensuring my wheel bearings were tight. Not sure on the tdc but I believe there are marks on the harmonic balancer, if you got the wobbles check wheel bearings >balance tyres>check leaf spring and shackle bolts/bushes>and if the leafs are too worn(like my old ones were) then replace em
  #211
Old 19-11-2016, 06:24 AM
SD33?
If so there are marks on the harmonic balancer.
There are TDC marks for 1/6, 2/5, 3/4.
  #212
Old 08-01-2017, 02:11 AM
Got my liscence back and the bastards done an alternator(or some sus wiring), also took 2 leaves out of the pack and the thing rides nicely now!
  #213
Old 08-01-2017, 04:14 PM
rtd's Avatar
rtd rtd is offline
Did you end up removing middle leaves or bottom leaves? Also, did you loose much overall height in doing so? For mine I'm thinking of taking the bottom two leaves out of the rears and maybe the bottom leaf out of the fronts, dunno if it'll sag way too much though...
93 GQ TI LWB TB42E
and
84 MK SWB SD33T
  #214
Old 25-01-2017, 07:29 AM
neixian's Avatar
A few pics of were its at now, treating rust hitting out dents, sound deadening(back) and just general body work.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG][IMG][/IMG][IMG][IMG][/IMG][/IMG][IMG][/IMG][IMG][/IMG]
How did you fix rust holes like this?
Sent from my HUAWEI MT7-TL10 using Tapatalk
Bring me sunset in a cup!
  #215
Old 25-01-2017, 10:32 AM
Hey mate, I cut the rust out and re made the Mount, not too hard to do if you're handy with a welder
The Following User Says Thank You to Mqmadness For This Useful Post:
neixian (27-01-2017)
  #216
Old 26-01-2017, 09:21 PM
Same spot on mine was cut out and repaired, looks like they then covered it all with a heavy gum rubber or something too. Holding alright
  #217
Old 02-02-2017, 02:10 PM
The shorty has been running flawlessly, wich is kinda suspicious. It has however developed a few oil leaks, wich I'd like to fix, Also wiring some spotties up
  #218
Old 03-02-2017, 11:13 AM
neixian's Avatar
I got the tig welder, unfortunately couldn't do it properly, only making holes in the patching panel.
  #219
Old 03-02-2017, 11:41 AM
Probably best to use a MIG welder for it man
  #220
Old 04-02-2017, 07:47 PM
Ric's Avatar
Ric Ric is offline
White & Whistlin sd33T
Hey MQMadness
Did you have the head machined or just clean it and polish the surface.
Cheers Ric
85 LWB deluxe SD33T
The White Whistler
Also
92 LWB Maverick TD42
Midnight Blue
You can not begin to fathom the immensity of the f*ck I do not give
