The Three Amigos. - Page 23 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Models > Nissan Patrol MQ/MK 160/260 series
  #441
Old 28-12-2016, 06:56 PM
Ordered a new set of rims and tyres today. 285/75r16 Hankook RT03's on Dynamic Soft 8's.
Pretty keen to get them fitted up and take them out for a test run!
  #442
Old 30-12-2016, 05:29 PM
33's fitted!
Factory flares had to go, but I have some flexi flares to put in place of them.
Unfortunately the tyre joint ordered the wrong rims, but that will be sorted next week.
New rims and tyres has transformed the look though, I'm loving it!
  #443
Old 31-12-2016, 01:29 PM
neixian's Avatar
My 32s go well with the flare. Not sure if they are factory ones, but they look like factory.
Sent from my HUAWEI MT7-TL10 using Tapatalk
Bring me sunset in a cup!
  #444
Old 03-01-2017, 02:35 PM
Picked up the A/C idler bracket and pulley I needed today.
Thanks to Paul, and it was good to meet ya mate.
The Following User Says Thank You to james008 For This Useful Post:
Wish I Had Coils (29-01-2017)
  #445
Old 07-01-2017, 10:44 AM
Noticed some bad cracking around the LHF shackle hanger the other day, and a crack running through the bottom of the chassis rail from the hanger to the front end of the chassis. I was able to get it fixed up by one of my old man's mate's which was lucky since I'm leaving for a big trip in a few days.
  #446
Old 07-01-2017, 10:49 AM
neixian's Avatar
Nice. Wondering where the idling hose connected to? Gq is in injector pump. Same as mq?
  #447
Old 07-01-2017, 11:35 AM
There is a line that runs from the vacuum pump on the back of the alternator to a vacuum solenoid on the firewall behind the main air filter housing and that runs to the idle advance unit, its attached to the IP on a bracket right near the throttle lever.
neixian (27-01-2017)
  #448
Old 27-01-2017, 11:10 AM
I was really impressed with how well the old MK ran up to Qld and back, I covered about 5500km and the only mechanical issue I had was the nut on the positive starter terminal working loose once, easy fix just nipped it up again.
I got it out onto the beach a couple of times too, having never driven on sand before I was wondering how the old SD would go on the soft stuff but I was pretty impressed. Tyre pressures were about 25psi the first time I went out and 20 the second time, and the old SD pulled really well, no issues with the cooling system either.
And a shot from when I went out with MQtray, GU2 and JFF45.
The Following 3 Users Say Thank You to james008 For This Useful Post:
Marko_SJ (05-04-2017), MQTray (28-01-2017), neixian (27-01-2017)
  #449
Old 27-01-2017, 11:14 AM
neixian's Avatar
Gq is still my choice of weapon for long trips. Mq? Probably will be used as an Ute.
  #450
Old 02-03-2017, 12:10 PM
rtd's Avatar
rtd rtd is offline
James - the truck looks great with the new tyres. What offset did you end up going with? I've had Dyna Pro MT's in the past on a GQ and they were an excellent tyre. Plan is to get a set for my MK soon, in the same size you went with, with a -22 rim.
Any further thoughts on getting a set of fibreglass flares? I don't really know what to do about flares for mine. Were the flexy flares cheap and easy to fit?
-Rich
93 GQ TI LWB TB42E
and
84 MK SWB SD33T
  #451
Old 02-03-2017, 04:18 PM
Jelmer160's Avatar
It looks great now!
'84 Patrol MK L28E turbo, SPOA, Y60 axles, PTO winch, shackle reverse with Hilux springs and 37" creepies.
'83 Datsun Laurel VG30DET 3.0V6 24v turbo
The Following User Says Thank You to Jelmer160 For This Useful Post:
james008 (09-03-2017)
  #452
Old 02-03-2017, 04:36 PM
Not sure what James runs but I have run -22 almost from day one. Flexi flares are easy to fit , either screw or pop rivet with a small washer to add to the surface area . Pretty cheap of e'bay
Sent from Alf Stewart's rape dungeon .
  #453
Old 09-03-2017, 05:22 PM
-Rich
Thanks Rich. I'm extremely happy with the DynaPro's so far, I haven't had them off road as much as I'd like, but on road they have been excellent. I've had 1-1.5mm wear after about 7000km too at 36psi all round. I went with a -22 offset rim.
I did come across scrubbing issues both front and rear after fitting the 33's, the front will require extended bump stops but I think the rear scrubbing is more an issue with the leaves I'm running (Dobinsons 2") since I had to pull the rear diff forward significantly to fit the springs and the wheel sits noticeably further forward in the wheel arch - maybe to protect the driveshaft from over extending, but they don't flex very well anyway.
I haven't done anything about the fibreglass flares yet. The flexeys were pretty easy to fit, I had to use 89mm flares, which protrude 80mm, on the front to almost cover the tyre and keep it looking legal. When fitting initially tried to just use the factory mounts, but the flares sagged sonI had to whack a couple of tech screws in which I didn't really want to do, but at least they're out if sight.
  #454
Old 02-04-2017, 11:35 PM
So it's happened again...
Today I paid the deposit for yet another Patrol.
jazie (02-04-2017), Marko_SJ (05-04-2017), Squalo (05-04-2017)
  #455
Old 02-04-2017, 11:55 PM
Heavensent's Avatar
Bahaha
Do we get a teaser pic
Sent from my SM-N920I using Tapatalk
AKA Boyd
http://www.facebook.com/pages/Heavensent-Fabrications/635552486461725#
Expect the best, plan for the worst, and prepare to be surprised.
  #456
Old 03-04-2017, 08:05 AM
Originally Posted by Heavensent View Post
Bahaha
I've only taken one photo of it so far. And the interior was a bit dark so it didn't turn out great, but this is one of the main reasons I bought it...
Heavensent (03-04-2017), Jelmer160 (03-04-2017), Marko_SJ (05-04-2017)
  #457
Old 03-04-2017, 04:25 PM
Jelmer160's Avatar
Low km's and an early one!
  #458
Old 04-04-2017, 08:20 AM
Yep she's very early. Build date is December 1980. She's an N/A SD33 4 speed van. Interior is as basic as they get.
The Following 2 Users Say Thank You to james008 For This Useful Post:
jazie (05-04-2017), Marko_SJ (05-04-2017)
  #459
Old 05-04-2017, 07:38 PM
MQTray's Avatar
Pass the Popcorn
Hmmm.....That's the year I originally had and it was 24v.
Fun and frustrating all rolled into one vehicle!
'03 GUIII TD4.2Ti DX C/L Cab Chassis! TMCC intercooler BTC 4" airbox
You can check out any time you like, but you can never leave.
The Following User Says Thank You to MQTray For This Useful Post:
james008 (08-04-2017)
  #460
Old 08-04-2017, 01:02 PM
Picked the old wagon up this morning.
It's in storage at a mate's house till I clear a spot for it in the shed.
I was surprised how well the old shorty towed it, considering the car + trailer was longer and heavier than the shorty. It was a bit slow, and I had to drop back a little on bigger hills to keep the EGT's down, but she did alright for an old girl.
Paint looks pretty good in the sunlight considering it hasn't even been washed yet and it's covered in dust.
Jelmer160 (10-04-2017), Marko_SJ (18-04-2017), Softy (08-04-2017)
