Nissan dealership saying installing bullbar will void my new warranty - Page 3 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Models > Nissan Y62 Patrol, Armada & Infiniti QX80
Old 09-01-2017, 04:02 PM
fwdpatrol's Avatar
Originally Posted by kinigo270 View Post
Hi everyone, i asked my local castle hill dealership to see if they can arrange a bull bar to be fitted and was told outright no they don't do this and I need to contact supplier direct. Then to my surprise I was told if I fit the bar it will void my warranty.
I then went on and told him so many folks out there with aftermarket bars seeing Nissan don't offer factory bar.
Can anyone confirm what the go is with warranty and also if you had your dealer arrange for bar to be fitted.
So then I can go back to dealer and let them have it.
Thanks
Load of crap
So many dealers actually organise the fitment
Fwdpatrol
GU patrol 2015 ST- N-Trek
Old 09-01-2017, 05:16 PM
Originally Posted by Madds View Post
Comparing a Ranger to a Y62 is pretty pointless as Rangers are compliance under category MA, so they're not technically meant for off-road use (MC).
<snip>
You're a fair way off-base with that explanation dude. Compliance categories exist for one purpose and one purpose only - ADR compliance. There is NOTHING in the ADR's which even vaguely infers that there is any reference to "not technically meant for off-road use". It's simply an administrative categorisation. Nothing more. Don't read more into it than what it actually represents.
There is absolutely NOTHING preventing a manufacturer from complying a vehicle in any category which it meets ADR's for.
Old 09-01-2017, 06:11 PM
RALPHMCPHERSON's Avatar
Exactly. Suggesting a Ranger is "technically not meant for off road use" is just ridiculous and misleading.
platinum 2011 GU 3.0 crd
Old 09-01-2017, 06:33 PM
Madds's Avatar
Damage your car off-road when's it's not considered off-road capable and good luck with your insurance. The ADR compliance is an assessment of a vehicles suitability based on its physical characteristics. Its a legal requirement, same as you can't use a people mover as a bus as it's not in the correct category.
Old 09-01-2017, 07:02 PM
I don't make the rules but that's just ridiculous. A car that is a 4wd but not intended to go off road? Thats like building an aeroplane thats not intended to fly, or a pair of running shoes not intended to be put on your feet. When do they actually intend for it to be engaged into 4wd?? The world's gone mad. They make rules like this but it's perfectly fine to tow a 3.5 tonne caravan with a car that weighs 1.5t, but dont take it off road.
Old 09-01-2017, 07:11 PM
No no no and no again. You are either TRYING to be misleading, or simply don't know what you are talking about re: ADR's and the compliance category.
The ADR "compliance" (as you call it) is NOT "an assessment of a vehicles suitability based on its physical characteristic" (as you put it). Sorry mate, but it is painfully obvious you do not know what you are talking about in this regard.
I'll make it easy for you and post the two category specifications (direct from the ADR's) for MA and MC:
4.3.1. PASSENGER CAR (MA)
A passenger vehicle, not being an off-road passenger vehicle or a forward-control passenger vehicle, having up to 9 seating positions, including that of the driver.
4.3.3. OFF-ROAD PASSENGER VEHICLE (MC)
A passenger vehicle having up to 9 seating positions, including that of the driver and being designed with special features for off-road operation. A vehicle with special features for off-road operation is a vehicle that:
(a) Unless otherwise ‘Approved‘ has 4 wheel drive; and
(b) has at least 4 of the following 5 characteristics calculated when the vehicle is at its ‘Unladen Mass‘ on a level surface, with the front wheels parallel to the vehicle’s longitudinal centreline, and the tyres inflated to the ‘Manufacturer‘s’ recommended pressure:
(i) ‘Approach Angle‘ of not less than 28 degrees;
(ii) ‘Breakover Angle‘ of not less than 14 degrees;
(iii) ‘Departure Angle‘ of not less than 20 degrees;
(iv) ‘Running Clearance‘ of not less than 200 mm;
(v) ‘Front Axle Clearance‘, ‘Rear Axle Clearance‘ or ‘Suspension Clearance‘ of not less than 175 mm each.
The vehicle classification for ADR purposes is PURELY a descriptor of the physical characteristics of a vehicle. Nothing more. There is no "assessment of suitability" (as you put it) included in the ADR's at all. NOWHERE in the ADR's does it describe or refer to the "vehicles suitability" or the purpose for which its used, or is intended to be used.
Within the greater body of the ADR's, these (in fact ALL) classifications have mandatory physical features described in detail. It would be mirror placement, it could be headlight configuration, it could be side-intrusion mitigation. But that is all that is described - never do the ADR's discuss how the category of vehicle will or may be used.
Now, lets talk about your statement "Its a legal requirement, same as you can't use a people mover as a bus as it's not in the correct category". Wrong again. You are trying to mix registration classification (state responsibility) with ADR type compliance.
This category CAN be used as a "bus" as you call it:
4.3.2. FORWARD-CONTROL PASSENGER VEHICLE (MB)
A passenger vehicle, not being an off-road passenger vehicle, having up to 9 seating positions, including that of the driver, and in which the centre of the steering wheel is in the forward quarter of the vehicle’s ‘Total Length.‘
This category can ALSO simply be used as mums taxi. The REGISTRATION category determines whether it can be a fee-paying passenger carrying vehicle, or is private registration, and cannot be for fare-paying passengers. A common example in this category - the Kia Carnival. It is widely used as mums taxi. It is also widely used a taxi vehicle (when registered appropriately). It is also registered and used as a fare-paying passenger vehicle on some small routes. But its legal use as a fare paying passenger conveyance is a function of its REGISTRATION approval category (a state responsibility), and has nothing (zero) to do with it's ADR category. In all instances, this vehicle is - for ADR purposes - category MB.
So now we'll talk about what are more commonly considered "buses":
4.4. Omnibuses
4.4.1. A passenger vehicle having more than 9 seating positions, including that of the driver.
4.4.2. An omnibus comprising 2 or more non-separable but articulated units shall be considered as a single vehicle.
4.4.3. LIGHT OMNIBUS (MD)
An omnibus with a ‘Gross Vehicle Mass‘ not exceeding 5.0 tonnes.
4.4.4. HEAVY OMNIBUS (ME)
An omnibus with a ‘Gross Vehicle Mass‘ exceeding 5.0 tonnes.
Any "omnibus" described above does not cease to be an omnibus just because someone does a partial motorhome conversion for example, if they retain the seating capacity stated above. Nor do the ADR's make any statement about what you can and can't use your omnibus for. You can drive one around for pleasure if you want. The state motor vehicle rego office won't care. But if you use your private REGISTERED omnibus to carry fare paying passengers, you are in for a world of hurt. And it has nothing to do with ADR's - just the rego category.
NOWHERE do the ADR's does it state what you can use a vehicle for - what purpose you can use it for. The ADR's are there for everyone to read, including you. While I have little doubt you won't like being taken to task in this way, I believe it important to post the RIGHT legal information when discussing rules, regulations, legislation etc. This is a classic example of what you think, in no way matches the intent NOR the fact of the legal framework.
Please do not post misinformation - it does not help the members of the forum.
(I'm not even going to bother responding to your comment about insurance - that is a contract between two parties....ah forget it...sorry mate, but you really need to educate yourself on this stuff if you are going to make statements that you claim are correct)
(You could say that I know a little bit about this stuff.)
Old 09-01-2017, 07:34 PM
4.4. Omnibuses
Cheers mate, I was just about to post that info up. You saved me the hassle.
The Following User Says Thank You to RALPHMCPHERSON For This Useful Post:
ants_oz (09-01-2017)
Old 09-01-2017, 07:52 PM
Madds's Avatar
Your own post clearly states that vehicles classified as MA are not intended for off-road use. I'll leave it at that.
Old 09-01-2017, 08:27 PM
No, my post does not say that (which incidentally is why you can't quote me - because you can't quote what I didn't write). The truth betrays you.
The adr excerpt I posted says that (in effect) a vehicle can be complied in one category if it is not complied in another category, AND if has certain physical characteristics. Nowhere in there is there any mention of "intended for off road use" (as you claim).
The adr for MA quite clearly says "...A passenger vehicle, not being an off-road passenger vehicle or a forward control...". Read it. Actually read the words that make up that statement. Try your best to understand their meaning in-context. It is saying that, out of the three classes of passenger vehicles, a passenger vehicle is an MA class if it doesn't fit into one of the other classes (Mc and MB).
It explicitly does NOT refer to "intended for off road use".
One of two things is happening here - either you are **** stirring by deliberately misrepresenting what I've posted - which is just plain immature. Or you really have your head buried so deep in the sand that you really do genuinely believe what you say, despite the factual information provided (direct quotes from adr's), and despite repeated attempts to help you understand.
If it's the first - okay, you got me and I took the bait. But if it's the latter, I suggest that you are not sufficiently equipped to continue talking part in this discussion.
Old 10-01-2017, 07:00 AM
I read this as absolutely hilarious.
I think some of you took it way too seriously?
Old 10-01-2017, 08:58 AM
Madds's Avatar
Yeah, seems some people are a little touchy about their choice of vehicle. Was merely meant as a not so serious don't compare apples v oranges.
Just for the record, disecting people's war and peace posts on a phone is a pain in the butt, hence why I didn't use the quote button.
Old 10-01-2017, 09:20 AM
<snip>
And yet I managed to respond to your post - in full and with accurate information - last night ON MY PHONE Technology is not your strong point either - that's okay, you don't need to make excuses.
In the end, you can be as childish as you want - the facts are the facts, and you are obviously short of any evidence to support your claims which is why NOT ONCE - despite every opportunity to do so you have not provided an ounce of verifiable reference to support your claims.
The truth is that I did not say anything of the sort. yet you refuse to acknowledge that you made a false claim.
(highlighted by me)
Through the information I have posted - direct extracts from the ADR's - it is patently obvious that what you claimed is INCORRECT.
So since you have been proven to be incorrect in your claims, you change your story:
<snip>
Um....no. YOU claimed that ADR's are an assessment of a vehicles suitability based on physical characteristics - and it is patently not that.
You have been proven wrong on a matter which is unambiguous, so change your story to try to deflect attention away from your own lack of knowledge by suggesting that other people are 'touchy', and that you really meant something else all along. Just learn from it - it's okay to be wrong. No one thinks any less of you for being wrong - I suggest that people WILL think less of you for being purposely misleading however...
I make no apologies for sticking to the facts, and for repeatedly making sure the RIGHT information is included in discussions like this. I do it because it is vitally important that misinformation such as you have provided is called out as wrong. Someone may read all this, and unless your statements were corrected - might assume you were factually correct and get themselves into a whole world of hurt because they thought the advice you provided was right.
Lastly - you say you didn't quote me because (essentially it was too hard) on a phone. Here is the challenge - find something to quote me on that supports what you claimed. Go back and find ANYTHING of mine that you can quote in this thread that supports your claims. Stop seeing just what you want to see, and actually look at and understand the words. These posts aren't going anywhere - you can look through everything I wrote/quoted and NOWHERE does it support your claim that:
Your own post clearly states that vehicles classified as MA are not intended for off-road use<snip>
If the facts were at all supporting your claims, you would have been able to come up with SOMETHING. But as yet, you have NOTHING.
With compliance type information I believe it is vitally important to not post false information - that is my personal belief and I don't ask for agreement by anyone else. But by you claiming that I said something I did not? That is insulting.
Old 10-01-2017, 10:08 AM
Madds's Avatar
At least I haven't resorted to personal insults to get my point across...
Don't worry, I won't take your insults about being technologically illiterate personally. I get paid far to much as an IT Professional to care lol
Old 10-01-2017, 10:49 AM
Hi Madds,
That's awesome that you are an IT Professional. So am I. Only been in the field since 1999 though, so relatively new to it and obviously don't get paid "far too much".
For saying you were being "childish" - I publicly and sincerely apologize. That was an unnecessary statement to make on my behalf, and I should not have done so. So I offer my apology for saying that. That I was frustrated with your continued false claims regarding what I posted is not an excuse.
As for your claim that I said you were "technologically illiterate" - I have raised your false claim with an admin and will leave it up to them.
I have said it previously in this thread and will say it once more because of your continued actions - I do not appreciate, nor do I believe it is appropriate, that you should misrepresent what I have posted, or falsely claim that I said something I did not.
Are there any other alleged "personal insults" that you claim have been made by me, which you would like addressed?
Old 10-01-2017, 11:16 AM
Settle down boys and girls, getting personal can have some serious repercussions for the contributors and the thread .
Old 10-01-2017, 12:31 PM
What is written and what happens in real life are usually two different things. There is offroad and there is dirt road. Some people confuse the 2.
100 series V8 petrol vs ZD30 GU vs BT50 diesel. Gu wins. I recon a y62 would get even further
Old 10-01-2017, 01:13 PM
Bulbous's Avatar
Obviously you've never heard of the F35 Joint Strike Fighter
2011 4.8 Safari - The Fitek
2015 LC 71 - The Rub3
4.8 litre Patrol Club member #114
The Following User Says Thank You to Bulbous For This Useful Post:
GUTim (10-01-2017)
Old 10-01-2017, 01:19 PM
Just putting my motorcycle boots on while reading this, getting ready to head home. And almost literally fell off my chair laughing.
All I can say is "Well played sir, well played"
Old 10-01-2017, 01:41 PM
Rangers are chit
Gu's are a pig, it's a shame they didn't put in the 4.0 petrol and turbo that.
The 62 is better off road mod for mod
As for needing a laptop for the 62,... ffs natal your not real clever are you! Lol obviously still on ya p's and full of hormones and read to much 4x4 monthly.
Any modern diesel is the same.
Breaking crap under a 62, well the supercharged one has been holding up fine.300 odd wkw and 650 odd nm from idle ish to redline. The 62 was actually build for he power it makes, the poor old gu does pretty well but it's far from unbreakable.
They both have there place, truth be told ow many people really use like properly use there gu. Farkin hardly anyone, fluff up the beach doin 40kph in there crd or a bit of gravel and have the hide to say the 62 doesn't suit them cos it's a petrol and ind suspension... lol
Pretty sad old world out there.
GU 42T proper heavy douche work horse with spool
62 ti-l family bus
gu 42t dually nearly home and ready to mod
The Following User Says Thank You to simcoe For This Useful Post:
topdeck (10-01-2017)
Old 10-01-2017, 03:01 PM
Converted's Avatar
Originally Posted by simcoe View Post
Rangers are chit
Andrew fitted one of the Harrop blowers just before Christmas to a guy I know in Kangaroo Flats Vic, doesn't have a uni chip but something was pre done to the ECU (can't remember what he called it sorry).
369kw at the wheels
726 nm at the wheels
also has custom extractors ceramic coated inside and out needless to say
2013 Y62 Ti-L
The Following User Says Thank You to Converted For This Useful Post:
Polmjcl (10-01-2017)
