#1
Y60 Dimensions (88 Model)
Station Wagon Overall Length: 4180mm / 189.4" Overall Width: 1800mm / 70.9" Overall Height: 1815mm / 71.5" Front Tread: 1530mm / 60.2" Rear Tread: 1535mm / 60.4" Wheelbase: 2970mm / 116.9" Station Wagon (Gulf Standard) Overall Length: 4850mm / 190.9" Overall Width: 1800mm / 70.9" Overall Height: 1815mm / 71.5" Front Tread: 1530mm / 60.2" Rear Tread: 1535mm / 60.4" Wheelbase: 2970mm / 116.9" Station Wagon (High Roof Models) Overall Length: 4850mm / 190.9" Overall Width: 1800mm / 70.9" Overall Height: 1995mm / 78.5" Front Tread: 1530mm / 60.2" Rear Tread: 1535mm / 60.4" Wheelbase: 2970mm / 116.9" Station Wagon (For Australia with 215/80R16 Tyres) Overall Length: 4850mm / 190.9" Overall Width: 1800mm / 70.9" Overall Height: 1785mm / 70.3" Front Tread: 1530mm / 60.2" Rear Tread: 1535mm / 60.4" Wheelbase: 2970mm / 116.9" Hardtop (SWB) Overall Length: 4240mm / 166.9" Overall Width: 1800mm / 70.9" Overall Height: 1825mm / 71.9" Front Tread: 1530mm / 60.2" Rear Tread: 1535mm / 60.4" Wheelbase: 2400mm / 94.5" Hardtop (SWB Gulf Standard) Overall Length: 4280mm / 168.5" Overall Width: 1800mm / 70.9" Overall Height: 1825mm / 71.9" Front Tread: 1530mm / 60.2" Rear Tread: 1535mm / 60.4" Wheelbase: 2400mm / 94.5" Hardtop (SWB High Roof Models) Overall Length: 4240mm / 166.9" Overall Width: 1800mm / 70.9" Overall Height: 1995mm / 78.5" Front Tread: 1530mm / 60.2" Rear Tread: 1535mm / 60.4" Wheelbase: 2400mm / 94.5" Pickup Overall Length: 4970mm / 195.7" Overall Width: 1690mm / 66.5" Overall Height: 1855mm / 73.0" Front Tread: 1435mm / 56.5" Rear Tread: 1405mm / 55.3" Wheelbase: 2970mm / 116.9" # Note: Models with winch are over length by 185mm / 7.3" |
#2
Engine Specs
TB42 (89 Model) 4.2 litre, water-cooled petrol engine. 4 cycle, 6 cylinder in-line OHV. Crossflow cylinder head, high camshaft. Bore x Stroke: 96 x 96mm. Displacement: 4169 cc. Compression Ratio: 8.3.1. Max. Power: 125kW @ 4200r/min (DIN). Max. Torque: 325Nm @ 2800r/min (DIN). TD42 4.2 litre, water-cooled diesel engine. 4 cycle, 6 cylinder OHV. Crossflow cylinder head, high camshaft. Bore x Stroke: 96 x 96mm. Displacement: 4169 cc. Compression Ratio: 22.7.1. Max. Power: 85kW @ 4000r/min (DIN). Max. Torque: 264Nm @ 2000r/min (DIN).
__________________
Terry 4WD Links - Australian 4WD directory, videos, photos Patrol 4x4 - Nissan Patrol forum |
#3
Transmission & Ratios (89 Model)
5-speed Manual FS5R50A 5-speed with synchromesh on all forward gears and reverse. Floor Shift Lever. Gear Ratios: 1st: 4.556 2nd: 2.625 3rd: 1.519 4th: 1.000 5th: 0.836 Reverse: 4.245 4-speed Automatic RE4R03A 4-speed electronic auto with lock-up torque converter and two-mode shift pattern (economy & power). Gear Ratios: 1st: 2.784 2nd: 1.544 3rd: 1.000 4th: 0.694 Reverse: 2.275 Transfer TX12A Chain Driven Transfer. Ratios: High: 1.000 Low: 2.020 Diff Ratios: Cab Chassis Diesel: 4.375 Cab Chassis Petrol: 4.111 Hardtop & Wagon (except ST): 4.111 Hardtop & Wagon ST Petrol: 3.900
__________________
#4
Electrical System (89 Model)
12V 80 AH battery (Diesel) 12V 50 AH battery (Petrol) 60 A Alternator
__________________
#5
Suspension (89 Model)
Cab Chassis Front: Semi elliptic 'progressive rate' leaf springs with telescopic double acting shock absorbers. Torison bar type stabiliser. Rear: Semi elliptic 'progressive' leaf springs with telescopic double acting shock absorbers. Wagons & Hardtops Front: Long Travel 3 link coil springs with leading arms. Rear: Long Travel 5 link coil springs with leading arms with rear stabiliser bar (on/off stabiliser with ST Models).
__________________
#6
Fuel Tank Capacity (89 Model)
Hardtop & Wagon: 95 litres Cab chassis: 90 litres (Optional long range tank available, extra 95 litres)
__________________
#7
Steering (89 Model)
Minimum Turning Radius: Wagon & Cab Chassis: 6.7m Hardtop: 5.5m Power Assisted recirculating ball steering. Tilt adjustable column on DX & ST Models. Ratio: 17:1.
__________________
#8
Paint and Trim (89 Model)
Interior Trim DX Models - Grey breathing cloth seat trim - Vinyl floor and luggage area cover - Dark grey instruments and side trim ST Models - Grey fleck cloth seat trim - Grey carpet floor and luggage area - Dark greay instruments and trim GLI Models - Grey vinyl seat trim - Vinyl floor and luggage cover - Dark grey instruments and side trim Pick-Up/Cab Chassis Models - Grey breathing cloth seat trim - Vinyl floor - Dark grey instruments and side trim Colours and Trim - White (531): Pick-Up/Cab Chassis, DX Hardtop, ST Hardtop, DX Wagon, ST Wagon, GLI Wagon - Red (AG2): Pick-Up/Cab Chassis, DX Hardtop, ST Hardtop, DX Wagon, ST Wagon, GLI Wagon - Blue Pearl (BJ9): ST Hardtop, ST Wagon - Silver (549): Pick-Up/Cab Chassis, DX Hardtop, ST Hardtop, DX Wagon, ST Wagon, GLI Wagon - Black/Grey (4J2): ST Hardtop, ST Wagon - Black/Silver (5J0): ST Hardtop, ST Wagon - Silver/Green (3J - Red/Beige (4J heres two links to large pics of the body mount measurements of the GQ pick up and GQ wagon. http://www.4wdlinks.com.au/albums/album146/aav.jpg http://www.4wdlinks.com.au/albums/album146/aau.jpg thanks to BIG GQ for the links.
__________________
| Thread Tools | |
| Display Modes | |
