#1
I've got a 6" lift on my GQ and when it flexes at the front the fat part of the Tough Dog panhard rod rubs the front of the diff pumpkin.
I've got 12mm radius arm spacers in the space the axle forward so the 35's clear the mudflaps when turning and I've chained them back. The tyres dont rub anywhere else even with the factory flares on. I've got some new drop arms to put on when I get the new Nissan slotted bushes which should not require spacers because the new arms (Big O) are the right length to locate the axle correctly. My thoughts are to space the panhard rod 10mm forwards at both ends to stop the rubbing, although its slight its enough to rub metal away on the pumpkin. Has anyone else had this problem, what did you do to fix it? cheers, sudso
__________________
GQ ST TD42t I love terra firma................The less firma the more terra |
#2
Don't want to sound like a smartarse Sudso but is your panhard in the right way with diff end bump going up. I have a very similar setup as what you seem to have with drop arms 6inch lift and previously had spacers in mine before arms where changed and no rubbing. Do you have a diff protector on the pumpkin?
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| GU Diff ratios & Rear diff types | gu4500 | GU/GR Nissan Patrol Topics Only | 18 | 16-04-2010 11:51 PM |
| Tough Dog 45mm or Rancho 9000 | pinoy2its | GU/GR Nissan Patrol Topics Only | 10 | 20-05-2008 05:38 PM |
| Tough Dog Adjustables | OldMav | General 4x4 Chat - Anything 4X4 | 3 | 17-07-2007 01:36 PM |
| Tough Dog | donkman | GQ/Y60 Nissan Patrol & Maverick Topics Only | 1 | 19-02-2007 11:56 AM |
| ebay tough dog package? | Rampage | GU/GR Nissan Patrol Topics Only | 1 | 25-01-2007 09:28 PM |
