Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Forums > GQ/Y60 Nissan Patrol & Maverick Topics Only
Reply
Thread Tools Display Modes
  #1
Old 02-01-2008, 10:18 AM
Irakli's Avatar
Irakli Irakli is offline
Senior Member
Default Vibrations after 2" lift
Need advice from experienced out here.
I got an 89' swb, I got a 2' lift recently (dobinson springs and shocks) got the brake lines extended too ... however I get horrible vibrations when I drive, past 60kmh it becomes annoying, I think its the drive shaft but not sure ... its not the tires or bushes or anything of that sort. It only appeared after the lift, and its not the same time of vibs you get from tires...
Proposing its the drive shaft, what could be done other then dropping the transfer and gearbox ?
Any ideas ? its only a 2" lift surely enough the shaft should be vibrating soo much...
if this helps its done 530,000 km, manual, swb, TB42, lhd.
Thanks
__________________
Irakli
2006 Altima 3500
2004 Patrol 4800 LWB - Sold
1996 Patrol 4200 SWB - 2" Dobinson lift
1989 Patrol 4200 SWB - sold
  #2
Old 02-01-2008, 10:24 AM
DaveM DaveM is offline
Senior Member
Default
Sounds like it will be driveline vibes from the lift.
Using gearbox spacers would be the easiest and cheapest.
Other than that, you could possibly get the upper trailing arms shortened, or lower arms lengthened, or get adjustable uppers or lowers.
A cheap way would be use thick washers as gearbox spacers, this will allow you to see how far you need to drop it and then get proper plates made.
  #3
Old 02-01-2008, 10:46 AM
Oldbugger Oldbugger is offline
Senior Member
Default
I just lifted my SWB only 2" and I had the vibes too...badly and I mean almost undriveable.....I needed BOTH gearbox spacers (12mm) and lengthened lower rear control arms (I got Snake racing adjustables...had to set them at 14mm extension). It was the only way to get rid of the vibes. I have none at all now except for a slight drumming at 85-90kmh...but not too bad.
I got the springs for nix and had new OME extra length shocks....the spacers cost $85 plus delivery and the adjustable lower rear arms cost about $380 with bushes....I also renewed the upper rear control arm bushes too. (free springs but a fortune on the extras to get rid of the vibes).
Good luck...the shorties are REALLY REALLY sensitive to drive shaft angles....mine would even alter depending on how much fuel I had in the truck...(I believe the 80 series cruisers are the sensitive too) ....you need to ensure the transfer case and diff flanges are exactly parallel (not necessarily in line but parallel)....and I mean exactly.....be careful of the spacers...some of the bolt holes need honing to allow the bolts to easily fit through and to line up with the chassis nuts.
Also try flexing the tailshaft at the slide point...there should be no noticeable movement at all....if there is it might be worth while replacing that first. Same with the uni's.
  #4
Old 02-01-2008, 10:54 AM
ab'z's Avatar
ab'z ab'z is offline
Senior Member
Send a message via MSN to ab'z
Default
turn tail shafts around an check uni's
__________________
turbo petrol/gas patrol #2
silver patrol #13
www.teamnaturallyaspirated.com
  #5
Old 02-01-2008, 10:41 PM
Irakli's Avatar
Senior Member
Default
Turn tail shafts around an check uni's
You mean just turn the drive shaft around ?
Are there no companies out there who make custom drive shafts to cure problems like these ?
When I look at the length of my 4.8s drive shaft length and then the swb its really funny ...
__________________
Irakli
2006 Altima 3500
  #6
Old 03-01-2008, 05:22 AM
Senior Member
Default
Yeah, just unbolt the shaft and swap end for end.
The only driveshaft you can get to solve these is a dc joint one, but they are not needed on such a small lift
  #7
Old 03-01-2008, 09:28 AM
Irakli's Avatar
Senior Member
Default
Alright will do that tomorrow, is swapping the shaft ends going to completely remove the vibes or is it going to reduce the vibes a little or a lot ?
Sorry about too many stupid questions, but this is the first time of having a shorty, used to the long ones and they don't vibe at 2" !!
__________________
Irakli
2006 Altima 3500
  #8
Old 03-01-2008, 11:28 AM
Senior Member
Default
No such thing as a stupid question.
Afraid to say that every shorty is different.
Have mates with 2" lifts and no vibes and dont need any mods, while others have done the driveshaft flip, 20mm gearbox spacer and adjustable upper arms to get rid of the vibes.
Mine has a 4" lift, 10mm spacers, and lengthened trailing arms with no vibes, although the vibes do start in mine if I don't regularly grease the uni's.
  #9
Old 07-01-2008, 06:32 AM
Rooster Rooster is offline
Newbie
Default
Hi Mate
I have the same problem here in UK what was your final solution to this and did turning the shaft end for end work
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What to expect - Before and after 2" lift MarcusParcus GU/GR Nissan Patrol Topics Only 8 23-03-2009 03:20 PM
Cheap 2" lift kit Jeffers_S13 GQ/Y60 Nissan Patrol & Maverick Topics Only 4 18-09-2007 06:32 PM
2" body lift with 33's? Slowlux GQ/Y60 Nissan Patrol & Maverick Topics Only 7 12-05-2007 07:45 PM
LAWS on more than 2" lift CAMERONCJC General Discussion 8 18-09-2006 03:40 PM
Help for OME 2" suspension Lift vanhack GQ/Y60 Nissan Patrol & Maverick Topics Only 9 13-10-2005 10:19 PM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
