Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Forums > GQ/Y60 Nissan Patrol & Maverick Topics Only
Reply
Thread Tools Display Modes
  #1
Old 17-01-2008, 04:54 PM
pro4wd pro4wd is offline
Member
Default Suspension advice
Hi all, i know this topic has probably been discussed heaps, I have a GQ LWB petrol 4.2 dual fuel . My question is what height above standard, is it safe to raise the vehicle without getting in to the major modifications eg 2" or so on. I only want to change springs and shocks but if there are other minor changes i need to do i will do it. Also how do i know if i have standard height springs in it now ? Is there a measurement i can do to give me some idea? I would like my rear springs slighty heavier and a little higher for towing purposes aswell.
Thanks in advance
__________________
1989 Ford Maverick
1974 HQ Monaro GTS
  #2
Old 17-01-2008, 05:02 PM
GQMac GQMac is offline
Senior Member
Default
What type of offroading are you using your truck for? If to the beach, then 2inch lift is enough.
  #3
Old 17-01-2008, 05:32 PM
Member
Default
Beach is planned and beginner/intermediate 4wdriving for the time being. My point is at this stage i want to raise to truck with minimal changes ( eg springs and shocks ) to the vehicle as handling/driving of the the vehicle is important as it must be able to safely tow my drag car around too.
__________________
1989 Ford Maverick
1974 HQ Monaro GTS
  #4
Old 17-01-2008, 09:36 PM
Mavman Mavman is offline
Senior Member
Default
Most insurance companies don't like it if you raise more than 2 inch. Also a f/e castor correction kit would be needed for 3 inch plus. There is a measurement between the bump stops to check your current height. Run a search as I saw it here not long ago. Your old suspension is probably sacked out anyway and if you put new stuff in you can determine the springs you want by the loads being carried. You can always go to polyairs or coilrites in the rear for towing if you don't want the springs too stiff for normal use.
__________________
GU 3 litre auto with enough kit to keep me happy. They say that hard work never killed anybody. I aren't going to risk them being wrong.
  #5
Old 18-01-2008, 01:31 PM
Member
Default
Thanks for your response guys, i thought more people would have knowledge on this . To be safe by the sounds of it 2 inch lift in spring and shocks would be max without any changes.
__________________
1989 Ford Maverick
1974 HQ Monaro GTS
  #6
Old 18-01-2008, 01:59 PM
oondy's Avatar
oondy oondy is offline
Senior Member
Send a message via MSN to oondy
Default
PM Sent mate
Can get away with no caster correction with 2" lift but you realise how much better it is with the correct caster. Coils and shocks are an easy way to get started so to speak - once you start lifting you just keep wanting it just a bees pecker taller.
OONDY
__________________
BIG O 4X4 - 4WD Suspension & Accessories
Ph: 08 73293322 | PH(AH): 0438 870 856 | email: sales@bigo4x4.com.au
Info, Pics & Pricing at www.bigo4x4.com.au
  #7
Old 18-01-2008, 03:23 PM
OldMav's Avatar
OldMav OldMav is offline
SUI GENERIS UTE
Default
Just a note to add to oondy post.
Our patrols drive very well with 3 to 3.5 deg caster if you are lucky and your std height patrol has 3.5 deg then 2 in lift will change your caster to very close to 3 deg which is fine BUT in reality most patrols have only 2 to 2.5 deg of caster which is hardly enough to start with and leads to the start of many problems like the death wobble, or wanders or pulling to the right when sh*t starts to wear, so add 2 inch lift and now you have closer to 1.5 to 2 deg caster not good. So with this in mind you save nothing and cause yourself a lot of pain down the track just because you want to save a few dollars now. Take oondy's advice and heed it have your front end checked first if it isn't min 3 deg, have it corrected with your 2 inch lift.
__________________
Peter
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gu Wagon Suspension Advice PETE03GU GU/GR Nissan Patrol Topics Only 13 21-01-2008 03:54 AM
Need suspension advice for noob.....with 2" lift Robbied_216 GQ/Y60 Nissan Patrol & Maverick Topics Only 13 24-10-2007 07:09 AM
Need suspension advice for new GU wagon Ricksta GU/GR Nissan Patrol Topics Only 3 22-08-2007 03:30 PM
Need suspension advice for new GU wagon Ricksta GU/GR Nissan Patrol Topics Only 3 20-08-2007 08:11 PM
GQ/Mav suspension advice Stu GQ/Y60 Nissan Patrol & Maverick Topics Only 0 23-05-2005 03:07 AM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
