Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
  Directory  The Web
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Forums > GU/GR Nissan Patrol Topics Only
Reply
Thread Tools Display Modes
  #1
Old 03-05-2008, 09:22 PM
goodo4x4's Avatar
goodo4x4 goodo4x4 is offline
Senior Member
Default GU VI Radio Replacement
G'day Guys
just got my new GU this week and the mods have already started. I've got a DVD/MP3/Bluetooth/USB player to go in that I bought off ebay so I need to pull the old radio out to get to the new one.
I presume the dash surround come out the same as my old GU III. That is 2 screws above the heater controls and just prie it out gently.
Can anyone confirm?
Thanks in advance.
__________________
GU VI 3.0l CRD Manual (CRD member #4, ST member #64, Gold Patrol member #42) My Album ,
My Thread
Patrol History: goodo4x4
  #2
Old 04-05-2008, 07:40 AM
red80's Avatar
red80 red80 is offline
Senior Member
Default
Yep, 2 screws then start prying from the bottom.
On another note can anyone help with removal of the A/C vents and storage compartment above the stereo. Once the surround is off there are 3 screws that hold it in, it then unclips around the top but I can't seem to get the top centre clip undone and I don't want to break anything. Is there definitely a clip there or do you need to do anything special to remove it.
__________________
06 GU 4.2TDI air comp, UHF, rear camera, 3" pipe, snorkle, dual bat, rear bar, sliders...more to come
  #3
Old 04-05-2008, 11:23 AM
MaxPerry MaxPerry is offline
Member
Default
I've had that part out several times. From memory, it just needs to be given a good bit of brute force to unclip it.
__________________
Max
Silver 2006 GU IV ST 4.2 manual (my 4th Patrol)
GME TX3400, car computer with 8" touchscreen for GPS, MP3s & rev camera, drawers, steel b/bar, IPF900s
http://mcperry.customer.netspace.net.au/
  #4
Old 04-05-2008, 01:02 PM
Time's Avatar
Time Time is offline
Member
Default
This pic might be of some help
__________________
Time marchs on
  #5
Old 04-05-2008, 01:58 PM
stuartcarr2002's Avatar
stuartcarr2002 stuartcarr2002 is offline
Senior Member
Default
HI
Once you have installed it, could you take some pics as i would like to do the same in mine. How much was the system you bought and can you hook up an amp to it, as i would like to run a sub under one of the front seats (like BROADYSGU). Any feedback on this would be great
Stuart
__________________
05 GU IV ST Vintage Bronze 3.0L
Steel Bull Bar, Lights and Towbar.
3" lift, King wheels, UHF and Patrol 4x4 stickers
ST TROLS RULE
  #6
Old 04-05-2008, 05:04 PM
goodo4x4's Avatar
Senior Member
Default
The unit was off ebay:
http://cgi.ebay.com.au/ws/eBayISAPI....MEWA:IT&ih=009
$135 plus $65 delivery. I'dd say you could hook it too an amp without too much problem. Once its in i'll take some picks and can probably scan some pages of the engrich manual.
__________________
My Thread
  #7
Old 04-05-2008, 05:14 PM
GU5STS's Avatar
GU5STS GU5STS is offline
Senior Member
Send a message via MSN to GU5STS
Default
Goodo,
Only one issue i know with these , the AM/FM may or may not work mate..... ive seen people buy these before only to have them end up as a paperweight matw...... u could be lucky here.
Daz
__________________
Nissan GU ( Sold ) but im still here floating around.
SR5 Dual Cab V6 Hilux MY07
  #8
Old 04-05-2008, 10:35 PM
goodo4x4's Avatar
Senior Member
Default
Fingers crossed then!
__________________
My Thread
  #9
Old 05-05-2008, 09:01 AM
Senior Member
Default
Looks like it has the outputs for an amp, seems really cheap. If it works ok, let us know, and i might grab one. It seems to have a low output to the speakers so an amp should bring good results...
Stuart
__________________
ST TROLS RULE
  #10
Old 26-05-2008, 09:14 AM
goodo4x4's Avatar
Senior Member
Default
The ebay in dash DVD/MP3/TV/USB stereo is in and operating. The result is OK. The biggest disappointment is that the bluetooth doesn't work with my Nokia phone. The bluetooth is something I really wanted. The MP3 function is OK but the screen is impossible and dangerous to operate while driving - definately a job for the passengers. The TV seems to work OK. There is no cut off with the hand brake like most locally purchased systems. The TV antenna is cable tired to the snorkel at the moment. I'm not really fussed with the TV. The USB port works well with thumb drives but will not operate with portable hard drives. And the sound has too much bass. Radio reception is fine - just needed an antenna adaptor for the Nissan plug.
I bought a loom harness adaptor and wired the supplied loop to it so that I can easily put back the OEM head unit. I used the AMP output to trigger the radio power antenna - works fine.
I still have some spare ports on the new unit so I'm thinking a front mounted camera for those tight city parking spots and rutted bush tracks. And I'll probably run the av output to the rear DVD screen when I get it so the TV / DVD can be viewed in both the front and back.
BTW the dash panel came out very easily. As did the old head unit. Probably took 10 minutes all up.
In dash touch screen DVD player come up quite well.
TV antenna is currently cable tied to the snorkel. I'm going to get an internal window mount anntenna with booster instead of this.
__________________
My Thread
  #11
Old 26-05-2008, 09:19 AM
goodo4x4's Avatar
Senior Member
Default
TV in operation.
MPG play back.
Main menu.
__________________
My Thread
  #12
Old 26-05-2008, 11:08 AM
GU5STS's Avatar
Senior Member
Default
Goodo.
is that the factory screeen above the Double Din you have installed mate ?
Daz
__________________
  #13
Old 26-05-2008, 04:35 PM
Senior Member
Default
Looks good, have you got it running through an amp or just hooked the factory speakers to it. If so how is the sound quality though the factory speakers???
Looks like i might have to invest in one
__________________
ST TROLS RULE
  #14
Old 02-06-2008, 02:13 PM
goodo4x4's Avatar
Senior Member
Default
Quote:
Yes factory/dealer (VDO Dayton) nav and reversing camera.
__________________
My Thread
  #15
Old 02-06-2008, 02:15 PM
goodo4x4's Avatar
Senior Member
Default
Quote:
No amp just factory speakers. Sound quality isn't as good as factory head unit. I need to fiddle with the equaliser settings to see if I can improve it.
Factory speakers seem to be better than in my old GU.
__________________
My Thread
  #16
Old 02-06-2008, 02:19 PM
goodo4x4's Avatar
Senior Member
Default
Bluetooth is now operational. The user manual leaves a little to be desired and wasn't clear on the bluetooth setup. An email to the supllier soughted it all out though.
__________________
My Thread
  #17
Old 02-06-2008, 02:33 PM
Yes Yes is offline
Senior Member
Default
GU VI?? Geez, I didnt even know there was a GU V! So whats the diff between a V and VI from a IV??
  #18
Old 02-06-2008, 02:43 PM
goodo4x4's Avatar
Senior Member
Default
GU VI is the CRD. I get a bit lost myself here.
I had a GU III previously. Released late 2002. Mainly an 03 model.
GU IV came out in 2004. Had new headlights, grill, taillights, flairs and updated interior.
GU V. Is the question? Is this when the 4.2l diesel finished and there was a bit of an update?
__________________
My Thread
  #19
Old 02-06-2008, 03:17 PM
thepaperboy's Avatar
thepaperboy thepaperboy is offline
Senior Member
Default
So you can now use it hands free with a nokia phone ?
  #20
Old 02-06-2008, 03:39 PM
goodo4x4's Avatar
Senior Member
Default
Quote:
Yes. I have a 6230i and unit works as if it was any other bluetooth car kit. The bluetooth connection name is displayed on the nokia screen. Radio/DVD/MP3 cuts out automatically when call is received or made. Red and green phone buttons above the volume control can be used to control the phone. Alternately, you can skip to the bluetooth menu and use the touch screen to enter the number and intiate the call. Audio is via the car speaker system. Volume control via the touch screen. Range seems to be a bit limited. I have been getting audio breakup if I leave my phone in my right pocket. Works fine if I leave the phone in the centre console or in the tray in front of the nav screen.
I haven't tried to play music from the phone via bluetooth. Theoretically it should work as well.
__________________
My Thread
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
GU VI drivers seat 07CRD GU/GR Nissan Patrol Topics Only 9 30-06-2008 08:47 PM
Accessing Back of GU Radio slots Bushbloke GU/GR Nissan Patrol Topics Only 13 01-12-2006 08:10 PM
Gu radio in gq splatty GQ/Y60 Nissan Patrol & Maverick Topics Only 1 30-07-2006 07:23 PM
GU Bullbar Blinker Lens Replacement Jason 99 GU GU/GR Nissan Patrol Topics Only 2 07-07-2006 01:54 PM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
