Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
  Directory  The Web
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Forums > GU/GR Nissan Patrol Topics Only
Reply
Thread Tools Display Modes
  #1
Old 22-11-2008, 03:23 PM
awill4x4 awill4x4 is offline
Senior Member
Default Laminova water to air intercooler
A few people here know of my interest in the fabrication of various intercoolers, well here's my latest. It's a Laminova cored water to air intercooler for a TD42 the pics below show the fabrication including a close up of the core design and construction.
Regards Andrew.
[img][/img]
  #2
Old 22-11-2008, 03:26 PM
mickyd555's Avatar
mickyd555 mickyd555 is offline
Senior Member
Default
Andrew
I havent ready the thread on outlerlimits, plus i think there are people here who dont get on there.
Can you give me the basic principles on why you use the laminove core, i assume its giving you better results but is that just because of its size or other factors?
__________________
Owner Builder Racing
www.bolsys.com.au
www.highwaydiesel.com.au
www.dandwwreckers.com.au
  #3
Old 22-11-2008, 03:42 PM
Roachie's Avatar
Roachie Roachie is offline
Senior Member
Default
That is a thing of beauty!!! Lets see how it goes.... Should be a real p!sser I reckon.
__________________
6.5 V8 diesel dual-cab , 4" lift plus lotsa other stuff
  #4
Old 22-11-2008, 04:01 PM
Senior Member
Default
Quote:
Originally Posted by mickyd555
Andrew
I got involved in these through Matt McInnes also on Outerlimits when he asked me to weld his together. At the start I thought "these are never going to work" but I welded it together for him and then they got me interested, really interested. When you initially look at them your immediate thought is "you can't flow air through those" well take it from me, you can. The next thought is "how can you possibly cool the air when it's only travelling such a short distance around the core?"
It's when you look at the maths of just how large a surface area each core has that you realise it is absolutely massive. Each fin is 0.2mm in thickness and the gap between each one is 0.3mm so there's more air gap than fin so think of it as thousands of razorblades cutting the air as it passes between them and transferring the heat to the water which is then passed out the intercooler to its own heat exchanger.
Very short inlet tract so lag is no longer an issue, compact in design and very efficient, it's a win win situation.
Add to all that it's really freaky stuff that people just don't believe can work but we've proved it can and does.
How does post turbo temps of 82C with post intercooler temps of 32C and a flat line of 5C temp rise above ambient sound? That's what we're getting on Matt's one a 50 degrees C temp drop at 8-9 psi.
  #5
Old 22-11-2008, 04:09 PM
mickyd555's Avatar
Senior Member
Default
Quote:
sounds excellent, would more boost give a better colling effect or would that just bring more temperature to start with and a similar drop in temp?
__________________
www.bolsys.com.au
  #6
Old 22-11-2008, 08:08 PM
db1891 db1891 is offline
Newbie
Default Price on manifold
How much to suit TD42 what sort of time delay.
Do you do a radiator for this heat exchanger (Big one) to suit this for a GQ nissan patrol.
Thanks
Darren
  #7
Old 24-11-2008, 12:17 PM
benhl's Avatar
benhl benhl is offline
Senior Member
Default
take a ticket and get back in line - i've been watching this from the begining on OL and have my hand still firmly UP for the first production model (or at least in the first 5-10) regardless of the wait.
I'm not even bothering looking any further into coolers until these are in production. They are fantastic and simple to integrate into any TD42 system configuration...
__________________
GU 2001 ST 4.2TD White Bus - Custom Garrett BB Turbo, 3" Zorst, 4" lift, 35's, 4.3's & lockers + lotsa lightforce.
  #8
Old 04-01-2009, 10:00 PM
Matt.McInnes Matt.McInnes is offline
Senior Member
Default
The install
1st up out with the DTS
In with the the new.
  #9
Old 04-01-2009, 10:09 PM
Senior Member
Default
The intake and turbo reconnected.
GUTD42 air box with a ZD30 lid, Marin did get a complete ZD30 air box but the bottom half's are the same and the GUTD42 air box was all ready fitted.
  #10
Old 04-01-2009, 10:15 PM
marin's Avatar
marin marin is offline
Senior Member
Send a message via MSN to marin
Default
Who let you on here :P
hopefully radiator is good for when I get back and I/we can install it
marin
__________________
TD42T shorty (custom intercooler COMPLETE AND DYNO'D!!!!!)
Winch-bitch-ina-40! (Drove the 40 and broke it @ Vic Winch '09 LOL)
  #11
Old 04-01-2009, 10:20 PM
Senior Member
Default
The heat exchanger/radiator.
Spent the morning at the wreckers looking at al-sorts and ended up going with this late model Telstar.
Feed to the pump.
Trimmed the grill a little but no Chrome was lost
The radiator is currently at TrikFab with the plastic end tanks cut off to be replaced with Ali ones and feed in and out to suit our needs.
The Grill is pretty much intact but for those that don't want to chop a custom one would be easy, though a little shorter better quality and as always make the wallet a little lighter.
  #12
Old 05-01-2009, 03:01 PM
Senior Member
Default
Ordered a Spal 13" push fan, this will cover half the heat exchanger on the passenger side leaving half for air to flow though freely on the road. It will also blow air through half the air con heat exchanger that is behind it.
Slim-line fan 55mm thick and 1650CFM all this should fit behind the grill without having to chop it out.
You can also see here we have rolled the top edge over on the bottom cross member to accommodate the radiator rather than cutting it out.
There was originally a fan on the air con unit but much thicker than than Spal slim-line unit.
  #13
Old 05-01-2009, 03:22 PM
truckster's Avatar
truckster truckster is offline
Autos are Superior
Send a message via MSN to truckster
Default
how about keeping an upto date listing on 'extras' and their costs to see how much this will work out to be.
EG, how much has this setup cost so far on the Red GQ listed?
cooler, cores, fan, welding, pipes, heat exchanger/radiator etc
Lots of people are interested, but I think the total final price may shatter a lot of dreamers.
__________________
The Mighty TD6 GU
Some of goodies
but a bigger wishlist
http://www.gupatrol.com/
  #14
Old 05-01-2009, 04:22 PM
Senior Member
Default
Do you want the bling and integrated like Marin or the generic bolt on?
Things like the speed flow 45 and 90 degree fittings are $40 each, stainless braided $30 a meter the piping to look bling can add up real fast over hose tails and hose clamps. But we can do it in either.
Once Awill4x4 is back from his xmas hol's well will be fabricating the generic bolt on version which will be costed.
The Telstar rad was $60 from the wreckers.
Fan was $200 but again you can hit the wreckers and eBay the Telstar had a pair on it but we did not get them with the rad, rather a slim line so not to cut the grill.
Cores are available at present on eBay buy now price $50ea US, new $212ea Aus from Laminova.
Davies Craig pump EWP80 $200
These are not a cheap intercooler by any means but you pay for what you get.
You get to save on figuring out what rad to use and how to fit it. As we have done all the hard work there too for free.
  #15
Old 05-01-2009, 04:53 PM
Senior Member
Default
Just to give you some idea of what bling adds.
This will set you back around $200
This will set you back under $100
Not including hose and I beat I can buy a whole roll of hose for the price of a meter of Stainless braided.
I hate to imagine the cost of extras for this one and it will be VERY bling. Twin turbo LS1
  #16
Old 09-01-2009, 03:41 PM
Senior Member
Default
End tanks done and a quick check for size.
Just the inlets and out lets and mountings to do.
  #17
Old 10-01-2009, 08:52 AM
marin's Avatar
Senior Member
Default
Radiator is lookin' good!
Truckster, I would prefer not to see the current total cost of mine, best to just keep forking out money in smaller amounts that seem manageable lol easier to justify to myself.
marin
__________________
  #18
Old 11-01-2009, 06:01 PM
Senior Member
Default
Marin's rad will be ready tomorrow, the mountings, bleed point and returns from the intercooler are done. Just the main feed to the pump to do.
Rather than use a 4 way splitter on the return we elected to feed each intercooler core out let into the radiator direct, just need drilling and tapping to take the fittings.
  #19
Old 11-01-2009, 06:52 PM
money_killer's Avatar
money_killer money_killer is offline
Senior Member
Default
cant wait to see some results
  #20
Old 11-01-2009, 09:09 PM
mickyd555's Avatar
Senior Member
Default
are these for sale yet and do you have any figures to back them up?
__________________
www.bolsys.com.au
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Radiator for water to air intercooler on GQ? marin General 4x4 Chat - Anything 4X4 8 10-01-2009 09:04 AM
air water intercooler ITS A FORD NOT A NISSAN General 4x4 Chat - Anything 4X4 10 16-10-2007 07:03 AM
Water To Air Intercooler Nutza GU/GR Nissan Patrol Topics Only 13 17-06-2007 08:00 PM
Denco water to air intercooler Himble GU/GR Nissan Patrol Topics Only 4 24-06-2006 07:12 AM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
