Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
  Directory  The Web
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Forums > GU/GR Nissan Patrol Topics Only
Reply
Thread Tools Display Modes
  #41
Old 26-01-2009, 08:54 PM
Matt.McInnes Matt.McInnes is offline
Senior Member
Default
Quote:
Originally Posted by mickyd555
never mind, i got the answer elsewhere. I didnt realise there was more than one thread on this topic
  #42
Old 26-01-2009, 08:55 PM
mickyd555's Avatar
mickyd555 mickyd555 is offline
Senior Member
Default
Quote:
Originally Posted by Matt.McInnes
sorry matt
__________________
Owner Builder Racing
www.bolsys.com.au
www.highwaydiesel.com.au
www.dandwwreckers.com.au
  #43
Old 26-01-2009, 08:57 PM
Senior Member
Default
sorry matt
Did I miss something, I did not even see a question.
  #44
Old 28-01-2009, 10:35 AM
Senior Member
Default
Well final testing is done, the Mav fiished.
Dyno'd today at 35C ambient
No dyno print outs Andy @ Dzltec is not back until tomorrow so some time next week.
Twin thermos gave us the extra cooling on the dyno adding 4.5kw
So all up now 104.5kw @12 PSI ambient 35C
26% power increase from what we started with and cooler EGT's
  #45
Old 10-02-2009, 11:30 AM
Senior Member
Default
Final run on the dyno.
Also the missing pre and post Map graph.
  #46
Old 13-02-2009, 09:20 AM
thepaperboy's Avatar
thepaperboy thepaperboy is offline
Senior Member
Default
I hate to imagine the cost of extras for this one and it will be VERY bling. Twin turbo LS1
The twin turbo LS1 isn't in a Supra by any chance is it ?
  #47
Old 13-02-2009, 09:01 PM
Senior Member
Default
No a 1952 Ford Mercury
  #48
Old 16-02-2009, 10:42 AM
MQ SWB#14's Avatar
MQ SWB#14 MQ SWB#14 is offline
Member
Send a message via MSN to MQ SWB#14
Default
hey guys i have seen what your up too and sounds sweet i am putting some thought into how I'm going to do mine with the Laminova technology and what i wouldn't mind knowing is
how much does the inter cooler rad block the engine rads air flow?
and is that the most HP you can get out of the system?
thanks fellas keep up the engineering
__________________
Ford Maverick SWB 89' 4.2 Petrol
Ford Maverick SWB 91' 4.2 Diesel (Project)
Nissan Patrol SWB MQ 2.8 84' Petrol
Nissan Patrol LWB 91' Petrol/Gas
  #49
Old 16-02-2009, 02:49 PM
Senior Member
Default
Up to 600 HP but keep in mind HP and cooling ability are 2 different things.
  #50
Old 19-02-2009, 11:26 AM
MQ SWB#14's Avatar
Member
Default
what do you mean by HP and cooling are 2 different things
what HP u getting from yours?
__________________
  #51
Old 19-02-2009, 07:30 PM
Senior Member
Default
Example:
A 1Ltr Engine running 30psi making will make x amount of HP, lets say for arguments sake 400hp
A 2Ltr Enigine running 15psi as above lets say for arguments sake will make 400hp.
The 1Ltr engine requires twice the boost of the 2Ltr engine to make the same HP. Generating 30 psi will heat the air twice as much as generating 15psi. So pre inter cooler temps are dependent on boost not HP.
Hope that makes sense, more psi more heat.
I make around 240hp @ the rear wheels, Marin around 140hp, but Marin's Diesel runs 12psi and makes 115C pre intercooler where as min runs 9psi and makes 82C at the same point. So as you can see HP and required cooling are very different things.
  #52
Old 19-02-2009, 08:36 PM
bennoGU28's Avatar
bennoGU28 bennoGU28 is offline
Senior Member
Default
Also why marine engines can make so much more horsepower out of the same cubic capacity with dependable reliability because cooling is so much easier.
Navistar PowerStroke 7.3l in marine form, dependant on application, makes 330hp
Navistar PowerStroke 7.3l, in F truck application, makes 215 hp
If you could double or triple the F-Truck cooling ability you should be able to get 330hp marine tuned engines fitted, but its all money and time.
__________________
Originality is Best
TD6 Intercooler
  #53
Old 19-02-2009, 08:43 PM
Senior Member
Default
Plenty of cold cold water on tap.
  #54
Old 19-02-2009, 08:48 PM
bennoGU28's Avatar
Senior Member
Default
__________________
Originality is Best
TD6 Intercooler
  #55
Old 21-02-2009, 09:11 PM
MQ SWB#14's Avatar
Member
Default
Example:
okay i think i get it if i put lets say 10psi in and the cooler i make the charge air the mor HP?
and is that why marin makes 140 due to hotter precooler temps and you make 240HP due to cooler pre cooler temps?
so what about after Inter cooler temps wouldnt marins make more due to higher efficiency cooler
how does his compare to your? have you guys got similar setups?
thanks
__________________
  #56
Old 22-02-2009, 09:26 AM
marin's Avatar
marin marin is offline
Senior Member
Send a message via MSN to marin
Default
Can't compare our cars in the slightest, Matt's engine is a fuel injected, custom built, fully worked with aftermarket computer and large turbo PETROL engine based on a 2F, mine is a stock as a rock TD42 with a bolt on DTS turbo kit and no fuel pump or injector mods.
They behave quite differently when reacting to boost.
marin
__________________
TD42T shorty (custom intercooler COMPLETE AND DYNO'D!!!!!)
Winch-bitch-ina-40! (Drove the 40 and broke it @ Vic Winch '09 LOL)
  #57
Old 22-02-2009, 09:39 AM
marin's Avatar
Senior Member
Default
thanks
Sorry, let me answer your actual questions.
Cooling the charge air means that the air becomes more dense, meaning more oxygen that can be burnt for the same volume of air. You need to add more fuel to get more power after doing this.
The power thing... that is completely to do with the engine. Matt's is petrol and custom built, big garrett ball bearing turbo, mine is stock TD42 with small mitsubishi bush turbo.
Matt's has a larger volume of water due to piping and larger radiator. I'm not sure what you mean about mine being "higher efficiency cooler".
My radiator is at the front, Matt's is rear mounted.
If you are really interested, and have a spare 2 hours or so, read here for his truck build up, and here for his original intercooler build up, will explain a lot about the coolers.
marin
__________________
  #58
Old 22-02-2009, 02:19 PM
MQ SWB#14's Avatar
Member
Default
Marin i thought you were making the laminova intercooler for more efficiency(better cooling)and more pwr
__________________
  #59
Old 22-02-2009, 02:42 PM
Senior Member
Default
No me and Awill4x4 are making them Marin was just a guinea pig and we are making them for better cooling, therefor more power and better efficiency are the end result.
Marin is correct though you can not compare our 4x4's in any way at all. You can however compare the intercoolers to some degree but they are not identical. Both cool exceptionally well with little or no heat rise from been off boost to full boost, also both have incredibly low pressure drops and no pressure spikes.
  #60
Old 07-03-2009, 11:03 PM
Senior Member
Default
Well Dzltec's 8 core is almost complete, this has to cope with up to 50PSI of boost from the compound turbo's.
One of the kit's like Marin's ready to go out Tuesday. End caps to suit hose tails.
The first of the bolt on inter-cooler's is ready for fabrication with 4 more ready and waiting once we have finalized the design of the outer skin. Just to show how small the second generation end plates are. Standard size business card.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Radiator for water to air intercooler on GQ? marin General 4x4 Chat - Anything 4X4 8 10-01-2009 09:04 AM
air water intercooler ITS A FORD NOT A NISSAN General 4x4 Chat - Anything 4X4 10 16-10-2007 07:03 AM
Water To Air Intercooler Nutza GU/GR Nissan Patrol Topics Only 13 17-06-2007 08:00 PM
Denco water to air intercooler Himble GU/GR Nissan Patrol Topics Only 4 24-06-2006 07:12 AM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
