Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Forums > GQ/Y60 Nissan Patrol & Maverick Topics Only
Reply
Thread Tools Display Modes
  #1
Old 25-01-2009, 04:41 PM
casndaveRX2.8 casndaveRX2.8 is offline
Newbie
Default Blocking EGR Valve Question??
Looking to block the EGR valve on my 97 GQ 2.8 turbo. I think I have searched through all the posts on here regarding Blocking EGR valves on the 2.8 turbo and I cant see any refrence to the pipe off the exhaust manifold that brings the exhaust gasses to the EGR valve.
Does this stay hooked up to the EGR valve when blocked or do you remove it and put some sort of plug in the exhaust manifold?
  #2
Old 25-01-2009, 05:26 PM
Godders Godders is offline
Senior Member
Default
Just leave the pipe connected you are only blocking the valve.
You should notice a reasonable differance at first untill you get used to it, then it happens all over again.
Why doesn't my car go any faster??
  #3
Old 25-01-2009, 09:32 PM
hhl hhl is offline
Senior Member
Default
There is not a lot to be gained in the 2.8. In the 2.8 the EGR valve is only open at idle, so there will be NO power increase at all as it shuts as soon as soon as you accelarate.
  #4
Old 16-02-2009, 04:53 PM
DansGQ DansGQ is offline
Senior Member
Default
can anyone verifiy this
cheers dan
__________________
GQ2.8 Club Member #2
"Good judgment comes from experience. Experience comes from bad judgment."
Still cant believe it lightes the 31" tyers
  #5
Old 16-02-2009, 06:07 PM
tweak'e's Avatar
tweak'e tweak'e is offline
Senior Member
Default
just going through the manual at the moment. i'm not 100% sure it s the same motor but it appears hhl is correct.
thats actually kind of odd as most motors have egr OFF at idle.
only thing to check is that the egr and butterfly are normally open or normally closed.
also it pays to check the operation with engine in gear. the testing in the manual i think would be with gearbox in neutral. i think there is a mention of gearbox switch, so its possible its operation is different than whats shown in the manual.
__________________
Navara, ZD30, EGR & butterfly mod.
to muddy to clean
  #6
Old 16-02-2009, 08:46 PM
Senior Member
Default
it didnt realy explain to me what i wanted to no when o read the manual
__________________
  #7
Old 17-02-2009, 08:25 AM
tweak'e's Avatar
Senior Member
Default
so far in the manual i found the test procedure. it doesn't say that egr is only used at idle. i havn't found what other conditions are a factor.
easiest way is to simply test it. fit a light or vac guages to the solnoids that run the egr and butterfly and go for a drive (motor must be warmed up tho).
__________________
to muddy to clean
  #8
Old 24-02-2009, 10:51 PM
geordie4x4's Avatar
geordie4x4 geordie4x4 is offline
Senior Member
Default
cheers dan
Like tweak'e said, test it with a gauge or light.
If it is anything like the 2.7 Terrano (mine was a 1992) I tested the vaccum with a gauge to see when it opened and closed. Yes it was open at idle (with the auto gearbox in N, P or D but seemed to shut in R). It closed as you accelerate. But it then opened again at cruising speed and when you back off slightly.
I closed it off because I could not use an exhaust jack without the motor stalling when the back pressure of the jack caused excess exhust into the motor.
__________________
Patrol GU4 3L diesel/gas chipped
3"Taipan SS
ARB winch bar, LR tanks 225L
285 Mickey T ATZ
Air locker, solar pannels, 3 batteries
Adjustable airbags 0 to 4" lift on the way
  #9
Old 25-02-2009, 04:21 PM
HS9090's Avatar
HS9090 HS9090 is offline
Senior Member
Default
Quote:
EGR is an emission control device. It supplies inert gas (exhaust) to the intake to take the place of some of the oxygen so the whole idea is to reduce power with the objective of reducing peak combustion temperatures where Oxides of Nitorgen (Nox) not Nitrous Oxide (Nos) are formed, thus reducing Nox emissions.
If it is only open at idle on the 2.8 I don't see how it can do its job.
The bad side effect of EGR, apart from power loss, is the carbon build up in the intake manifold, intake ports and on the intake valves.
Nox emissions can be more effectively reduced by water injection which also increases power and cleans up the carbon deposits etc.
Best thing to do for a 2.8 would be to replace the EGR with water injection.
That's what I intend to do to mine.
__________________
95 GQ RD28T vege-powered - the 'toy'
2" Dobinsons Flexy Coils Goodyear Wrangler Muddies
GQ 2.8 Club member # 1
and
2005 GU IV ST-S TD42TDi - the 'tourer'
3" exhaust, boost controller, digital pyro.
  #10
Old 03-03-2009, 05:18 PM
dacolprt dacolprt is offline
Newbie
Default
New here fella's, the egr valve requires vacume to open, so I just disconnected (blocked) the signal (vacume) hose to the valve. So the valve dosnt open sending exhaust gases to intake. Correct me if Im wrong.
  #11
Old 03-03-2009, 08:08 PM
tweak'e's Avatar
Senior Member
Default
yeah you can do that but there is a possiblity that the valve can be jammed opened which is why blocking the valve off is much better.
__________________
to muddy to clean
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Blocking EGR valve and fuel economy Godders GQ/Y60 Nissan Patrol & Maverick Topics Only 20 16-03-2010 08:01 PM
EGR Controler Valve - Should I replace??? josfamily GU/GR Nissan Patrol Topics Only 23 31-08-2008 07:46 PM
Dawes valve w/o blocking the EGR 5upaMav GU/GR Nissan Patrol Topics Only 2 04-03-2008 08:59 PM
Blocking the EGR question? jack180 GU/GR Nissan Patrol Topics Only 3 14-09-2007 06:51 AM
Blocking the EGR valve Joeker GU/GR Nissan Patrol Topics Only 4 08-04-2007 10:47 PM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
