Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
Go Back   Patrol 4x4 - Nissan Patrol Forum > 4x4 Forums > General 4x4 Chat - Anything 4X4
Reply
Thread Tools Display Modes
  #1
Old 29-01-2009, 05:56 AM
easyas easyas is offline
Member
Default ZD30 in navara
I'm beginning to suspect the same designation (ZD30) is two different motors.... I ask the question as my brother has a 2002 navara and I need to know what mods to do. WE'll be buying a lot of the same stuff I imagine.
I have a 2003 TD42TDi GU ute bought sight unseen. It's ex-telstra so I hoping its got a solid service history and maybe the GVM upgrade. Here my mods plan based on what I've read here;
1. boost and EGT gauge
2. oil catchcan from PCV
3. block off egr
4. 3" exhaust
5. pump tune/ injector crack pressure to 1800kpa
I'm hoping for a fairly bulletproof engine that pulls 100hp at the rears and is economical (11ish L/100km)
Whatcha rekon?
  #2
Old 29-01-2009, 07:37 AM
tweak'e's Avatar
tweak'e tweak'e is offline
Senior Member
Default
neither navara ZD30 or patrol TD42T have a variable turbo so no need for dawes valve.
both engines you can block off EGR without any boost problems. info on navara EGR and butterfly mod Here.
navara responds nicely to a bigger exhaust due to one very small rear muffler. however the common 3" exhaust is known to hit the chassis now and then when the motor rocks.
catch cans are highly recommended for both motors.
__________________
Navara, ZD30, EGR & butterfly mod.
to muddy to clean
  #3
Old 29-01-2009, 01:55 PM
Member
Default
Thanks tweak'e. Thanks for your input into this board too, where ever intelligent comment is found you are usually there. Good call on the catchcan- I'm looking forward to having a scrape around in the intake manifold to see how much crap is actually in there. OP edited to reflect comment.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Navara Zd30 help request pedrok General 4x4 Chat - Anything 4X4 8 05-12-2008 10:18 AM
navara ZD30 boost tweak'e GU/GR Nissan Patrol Topics Only 3 10-03-2008 06:13 PM
navara zd30 problems? patrol28 GU/GR Nissan Patrol Topics Only 2 17-07-2007 07:49 PM
ZD30 intercooler's. Who's has split. Dave_STR Polls 6 13-05-2007 05:33 PM
ZD30 for Cab Chassis GU Patrol. charlie835egg GU/GR Nissan Patrol Topics Only 31 17-01-2007 11:19 AM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
