#1
Hi All
I have got a complete running GQ (Y60 Station wagon) Chassis. My mate has a immaculate MQ (1983 Station wagon) body. Would this body fit straight onto the gq chassis or are there too many modifications. cheers |
#2
i know some of the panels swap over. if you can measure up all the mounting holes and draw it up on paper to compare might be the go.
__________________
SWB Nate. Built not Bought |
#3
can I ask it is a coil chassis? couldn't see any good reason other wise
and what engine box combo ?
__________________
the life of a 4wd used ,abused ,and tampered with and they love it |
#4
The chassis is different and wider on a GQ and the body mounts are in different spots. Doors are the same fit though.
__________________
GQ ST TD42t I love terra firma................The less firma the more terra |
#5
yes it is a coil chassis. I used the gq body on another project so I am left with a complete chassis TD42 engine and gear box
#6
Transmission tunnel in a GQ is wider. Your MQ body may not fit over a GQ gearbox. nothing a few mods wouldn't fix though.
__________________
MK Shorty - SD33 and 5 Speed - Lukey extractors, 2.5" pipe and hotdog - 4" Snorkel - 2" Body Lift, 2" Spring Lift - 33" BFG Muddies - LSD in the rear |
#7
GQ's have such flared guards because they're essentially a much modified MQ body on the GQ chassis. The track on the GQ is much wider than the MQ, hence the bulges & flares, so there's one problem. The trans tunnel is another. Depends how much trouble you're prepared to go to, I guess. Another question: is it even legal? What about Crash-Testing? I'd think RTA/Rego would view the 2 models as completely different vehicles. Worth looking into.
__________________
The Long & Winding Road. |
#8
This has been tried before. Body mounts were the main problem.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| gear box bolt patten from MQ box to GQ?? | nisnv8 | GQ/Y60 Nissan Patrol & Maverick Topics Only | 4 | 03-03-2009 10:07 PM |
| gq dash in mq | jonzi1 | MQ/MK Nissan Patrol | 8 | 13-10-2008 08:41 PM |
| GQ radiator into MQ??? | bludnut | MQ/MK Nissan Patrol | 4 | 15-07-2007 08:08 PM |
| Convert Auto to Manual Trans Nissan GQ Y60 | SAMAMRO | GQ/Y60 Nissan Patrol & Maverick Topics Only | 5 | 21-07-2006 08:32 PM |
