Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Forums > GU/GR Nissan Patrol Topics Only
Reply
Thread Tools Display Modes
  #1
Old 08-07-2009, 06:15 PM
camo75 camo75 is offline
Senior Member
Default EGR Valve and turbo boast
Hello all
Just a quick question i want to block the egr valve on my 3 litre Narava but i read something the other day that said once you block the EGR you need to re-adjust your boost.
Is this correct or do i just block the EGR valve off. On my 2.8 i just blocked the valve off and didnt need to adjust anything.
Thought l better check before i go any further
__________________
99 GU 2.8TD
2" Lift Koni shocks
Duel Batterys
Bull Bar, Draw system
3" exhaust
Driving Lights
Diesel Gas
270,000
Nothing like a mighty Patrol to let you see this great country of ours
  #2
Old 08-07-2009, 06:23 PM
tweak'e's Avatar
tweak'e tweak'e is offline
Senior Member
Default
navara doesn't run variable turbo so nothing needs to be adjusted.
don't forget to disable the egr butterfly setup.
http://www.navara.asia/general-tech-...erfly-mod.html
__________________
Navara, ZD30, EGR & butterfly mod.
to muddy to clean
  #3
Old 08-07-2009, 07:00 PM
Senior Member
Default
Thanks for the info
will have a play in the next week or so. Will let you know if i get stuck
__________________
99 GU 2.8TD
2" Lift Koni shocks
Duel Batterys
3" exhaust
Driving Lights
Diesel Gas
270,000
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Will Blocking the EGR affect valve life maysy1 GU/GR Nissan Patrol Topics Only 26 28-05-2009 05:44 PM
Blocking EGR Valve Question?? casndaveRX2.8 GQ/Y60 Nissan Patrol & Maverick Topics Only 10 03-03-2009 08:08 PM
EGR valve and Intercooler?? 4wdingmatt GU/GR Nissan Patrol Topics Only 37 06-03-2007 07:48 PM
Vacuum Hose Placement EGR Valve Kilifi Man GU/GR Nissan Patrol Topics Only 3 12-09-2006 05:12 PM
Vacuum Hose Placement EGR Valve Kilifi Man GU/GR Nissan Patrol Topics Only 0 12-09-2006 02:10 PM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
