Patrol 4x4 - Nissan Patrol Forum, Photos, Directory
Go Back   Patrol 4x4 - Nissan Patrol Forum > 4x4 Forums > General 4x4 Chat - Anything 4X4
Reply
Thread Tools Display Modes
  #21
Old 15-04-2007, 10:16 PM
GQTray GQTray is offline
Member
Default
Quote:
Originally Posted by OldMav
On my Maverick i had the compressor fitted under the alternator and run off the alternator with a small belt, it wore out belts and flew off at high revs. now it is fitted under the injector pump on alloy brackets, my model doesn't have the vacuum pump there, a 1160mm belt fits around the steering pump and water pump and compressor it seems to pump more air at idle than before and i don't loose the belt at high revs so now it is always on and ready. Anymore info just ask.
Gday Peter, just been reading this with interest. I had the sanden setup on my hilux with two 30 litre receivers and a blow off valve, super quick for tyres and great for the rattle gun etc. Set it up on the 18r turbo engine first and then on the V8.
Now I have seen the light and got the TD42 GQ and have been wondering where the hell to put the compressor. Do you have any pics of your mounting position etc and can you remember what the 1160mm belt is normally used for,ie what kind of engine or is it an industrial type v-belt(used one of these on the hilux but they didnt last as well as an automotive belt).
Thanks,
Damian
__________________
94 GQ Flat Tray
TD42 Turbo
Silver Patrol Club #10
  #22
Old 15-04-2007, 10:46 PM
OldMav's Avatar
OldMav OldMav is offline
SUI GENERIS UTE
Default
Damian
Have a look tomorrow night, i will have pictures posted of the system, i am not a big one for taking pic's but for you mate i will, i have been meaning to take pics but i rather work on the truck, as it is still in rebuild mode. also the other half takes a dim view when i use her camera with dirty hands.
__________________
Peter
  #23
Old 16-04-2007, 07:28 AM
Member
Default
Damian
Thanks very much mate, that would be very much appreciated.
__________________
94 GQ Flat Tray
TD42 Turbo
  #24
Old 16-04-2007, 05:18 PM
Crooksey's Avatar
Crooksey Crooksey is offline
Boosting GQ
Send a message via MSN to Crooksey
Default
or my workshop is the large shed on the airport just look for large boats.
Thats not the one next to caboolture powdercoaters is it ??
__________________
Cheers Chris
Now Turboed!!!!!
95 TD42 3"OME, 240Blitz, 285 BFG's, TX3400, AE4705, Garmin GPSMAP 60C, ERPS LCB Sliders, Dual Batteries.
  #25
Old 16-04-2007, 08:21 PM
OldMav's Avatar
SUI GENERIS UTE
Default
Quote:
No mate i build boats not play with ski boat toys. Actually on the airport itself second shed past the museum, and yes i need to hide to keep the dreamer from wasting my time.
__________________
Peter
  #26
Old 16-04-2007, 09:10 PM
OldMav's Avatar
SUI GENERIS UTE
Default
Pictures as promised:-
Mounts under injector pump
Mounts are alloy 15mm both sides of housing i have these mounts drawn on AutoCad of PDF if you want a copy. Remember i don't have a vacuum pump mounted under housing like later models. New belt is a DAYCO 13A1360.
Side bracket to make it stable i have now removed the back side bracket, it is not required.
Pic from the top showing outlet position and no second bracket.
Pic of pressure switch and blow off valve and non return valve, i used a piece of 6mmx75x75 alloy box because i can, you could do this in brass fittings like others, i did this to catch any oil and grease that may be pumped from compressor, also it is easier to mount compared to fittings.
Intake air taken from air cleaner box.
Pressure gauge to make it easy to set switch. Also relay to control clutch etc. Batteries are under tray in a cool spot and out of the road
Hoses are hydrallic so they do not melt and blow off. Cost about $150 for hoses.
!0 litre tank is under tray the black thing in the back ground. Outlets are either side with caps to keep the **** out.
Other side with cap off, cap is bolted to tray so i don't loose it.
And by the way the tray was welded by our apprentice to practice welding not to bad job but not survey yet.
If you need more detail just ask.
__________________
Peter
  #27
Old 16-04-2007, 10:48 PM
Member
Thumbs up
Peter you have totally excelled yourself mate. Thanks very much for the time you have put in taking the photos and giving out the belt number for me, it is very much appreciated. I dont have the cutout switch as my blowoff valve isnt a safety valve but is actually set to blow off at 800kpa, then drops back to 700kpa and so on. Quite handy as everything just keeps ticking over without overpressurising the receivers. A pdf copy of your brackets would be great but I dont want to annoy you too much after the time you have obviously put into setting it all up. Great information mate, hopefully I can help you out some day.
__________________
94 GQ Flat Tray
TD42 Turbo
  #28
Old 17-04-2007, 08:33 AM
OldMav's Avatar
SUI GENERIS UTE
Default
Just for interest drawing of brackets they are very simple and easy to make. It wouldn't be hard to extend the bracket to clear a Vacuum pump. You would have to check belt wrap on crank pulley.
__________________
Peter
  #29
Old 17-04-2007, 06:00 PM
Crooksey's Avatar
Boosting GQ
Default
my bad, i just saw a boat sitting out the front and i though hmmm maby, obvously not, i may have a look one day after work, (as i work on Lear Jet Drive) and say a gday.
thanks heaps for the pictures, im chasing up a compressor first and then i look at to where i will fit, as there may not be enough room under the vacume pump. I think i will use copper lines as thats not hard for me to come by, would you suggest 3/8 or 5/8 size lines??
__________________
Cheers Chris
Now Turboed!!!!!
  #30
Old 17-04-2007, 07:40 PM
OldMav's Avatar
SUI GENERIS UTE
Default
crooksey
Drop in anytime you are welcome, i am always after sparkys, maybe you will be really rich one day and have a need for a real vessel.
Back on subject it is nice to use 1/2 inch for outlet and 5/8 inch for inlet if you get a compressor with SAE fittings it is easy but with the ISO oring type you are restricted to 3/8 and 1/2 inch tail fittings. Using copper is ok but some where you will have to change to heat resistant hose.
__________________
Peter
  #31
Old 17-04-2007, 07:43 PM
Crooksey's Avatar
Boosting GQ
Default
Curious? for what reason is this??
__________________
Cheers Chris
Now Turboed!!!!!
  #32
Old 17-04-2007, 08:16 PM
OldMav's Avatar
SUI GENERIS UTE
Default
With these compressors they put out a lot of air which is very hot you need to use a tank for storage somewhere you need to use hose to get the line off the engine as copper will not handle the movement of the engine it work hardens and breaks. Using plastic hose and clamps on copper will work for a while until you use the system more than 10 minutes the hose will become so soft it will be prone to blow off the copper pipe.
__________________
Peter
  #33
Old 17-04-2007, 08:43 PM
Member
Default
What I used with my previous setup was high pressure touch fittings and 1/2" touch fitting tubing(blue plastic stuff) for the whole system as it is really easy stuff to use and there are are a lot of different fittings available, including check valves. I ran one of these between the compressor and receivers so the air didnt bleed back through the compressor. But Peter is bang on the money when he says the air gets bloody hot, I could only run it from the firewall back as it used to melt straight out of the compressor.
__________________
94 GQ Flat Tray
TD42 Turbo
  #34
Old 17-04-2007, 09:31 PM
Crooksey's Avatar
Boosting GQ
Default
I was thinking more along the lines (no pun intended) of flairing the copper and using propper flair nuts to join. good point on using the flex, what if i was to run copper to the firewall then use a length of flex or hydr hose as you have used to the chassis rail then copper again into the tank, again using flared nuts.???
__________________
Cheers Chris
Now Turboed!!!!!
  #35
Old 17-04-2007, 10:35 PM
OldMav's Avatar
SUI GENERIS UTE
Default
Copper along the chassis rail would be ok, but copper around the engine and its vibrations wouldn't be good it would have to have good supports, it would be easier and safer to just use fridge hose or hyd hose from compressor to firewall, or in my case the whole lot in high temp hose as i have had plastic hose fail after the fire wall with continious use.
__________________
Peter
  #36
Old 18-04-2007, 09:11 AM
sootygu sootygu is offline
Senior Member
Default
If anyone is interested I have drawings of brackets similar to those used by Endless Air to fit a GQ/GU. When I fitted my Sandon a mate laser cut the brackets and I fitted it all up.
They are a bit more complicated than OldMavs though.
  #37
Old 18-04-2007, 10:17 AM
Mav42's Avatar
Mav42 Mav42 is offline
Newbie
Default Interested...
SootyGq,
I've a compressor of a similar style to OLDMAV's that I wanna setup....
I'll be interested in your drawings also.... more information the better to get me started....
As to the OLDMAV setup, is this going to put additional pressure on the Diesel PUMP? could this cause an issue???
HEATH
  #38
Old 18-04-2007, 11:46 AM
OldMav's Avatar
SUI GENERIS UTE
Default
Quote:
Originally Posted by Mav42
SootyGq,
HEATH
Heath
If you knew the background and research that has been put into this set up, you then would understand why the bracket are so simple, i believe in the KISS principle. Anyway the system is only attached to the steel engine block which so happens to be the housing that also supports the injection pump and steering pump, this housing is more than strong enough to support a A/C pump under axial load. As for issues i have tried a few different brackets and locations they all have some problems, for me i decided under the pump has the least issues, The only drawback with this system is it does reduce the belt wrap a bit on the crank pulley i have calculated the contact area and the slip moment when wet supplied by belt companys for a 13A belt and as long as you don't rev the engine past 4800 rev the belt will stay on and still have a reasonable wear life. The water pump pulley also has another belt attached which is seperatly driven which also adds to our advantage to which i didn't add into the equation. You ask for tech so the answer is tech and reasons why.
__________________
Peter
  #39
Old 18-04-2007, 01:18 PM
Mav42's Avatar
Newbie
Default Thanks...
Thanks for that update Peter.....
You've obviously put some thought into this little project... As I said I'm trying to work out my best way forward for the unit I have. Are they all the same size? How can I work out if the AC unit I have is compatible with your bracket design?
I was just trying to back track for a second... What did you do for lubrication on your unit? did you mention that in a previous posting??? if you did then I'll have to have a reread...
THANKS..... HEATH
__________________
Heath - Ford Maverick TD4.2
2" coils, OME Nitrochargers, OME damper, headers and 2 1/2" exhaust, Uniden 088
.. still the family BUS...
  #40
Old 18-04-2007, 02:13 PM
OldMav's Avatar
SUI GENERIS UTE
Default
THANKS..... HEATH
Of this type all compressor brackets are the same dims. In other words if the compressor looks the same as in the pic's then this type have the same lugs if you look up sanden on the web there site has all the dims for SD type units. Also the reason this brand has been chosen is because they are robust and lots of them used on past cars. I have posted on lubrication and the reasons for my decision, But the pump needs to have a hole plugged to stop circulation of oil or pumping oil or grease into your air system. this has been address in eariler posts.
__________________
Peter
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Endless Air setup on GU 3.0TD DEEV8 GU/GR Nissan Patrol Topics Only 18 07-03-2010 03:58 PM
DIY: Onboard Air Canuck General 4x4 Chat - Anything 4X4 12 21-02-2007 01:20 PM
TB42 Engine Air Flow Intake. Mulisha GQ/Y60 Nissan Patrol & Maverick Topics Only 9 20-05-2006 12:55 PM
Air compressors/lockers/air tanks Richo General 4x4 Chat - Anything 4X4 1 13-12-2005 06:41 PM
intercooler (air to air) PSI 08 GQ/Y60 Nissan Patrol & Maverick Topics Only 0 05-10-2005 09:34 PM
Subscribe in NewsGator Online
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
