Death Wobble Final Fix Poll - Page 3 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > General Technical Discussions > Suspension and Steering
View Poll Results: What was the single biggest factor in solving your death wobbles
King pin preload adjustment 12 26.67%
New panhard rod bushes 14 31.11%
Wheel bearing adjustment 3 6.67%
Caster bushes 1 2.22%
Wheel alignment 6 13.33%
Draglink ball joints 4 8.89%
Steering box adjustment 0 0%
Up grade of steering damper 1 2.22%
Replacement of shock rubbers and or shocks 3 6.67%
Wheel Offset Change 1 2.22%
Voters: 45. You may not vote on this poll
Old 30-04-2017, 09:25 PM
klappers's Avatar
So, I changed out my drag link ball joints seemed to improve for a while but the wobbles are back. I have narrowed it down to wheel alignment and tie rod ends stuffed. Will try some toe in when I get home and change out the stuffed tie rod ends
Want to turbo your TD42 on the cheap? Check here
http://www.patrol4x4.com/forum/engin...ay-td42-80484/
Originally Posted by GASSED GU View Post
..... I drive like a penis at the best of times
Old 30-04-2017, 10:01 PM
Sydo's Avatar
Sydoforumsuperfan :)
Perth Patrol fitted new draglink and damper wobbles gone
The Following User Says Thank You to Sydo For This Useful Post:
klappers (30-04-2017)
Old 30-04-2017, 10:28 PM
warthog's Avatar
Never had death wobbles. Just a shimmy. New tyres fixed it.
Must grease the king pin bearings one day.
Drop boxes and 3 " springs as far as suspension mods.
Old 30-04-2017, 10:52 PM
Franky73's Avatar
Educated Fool
I'd be checking your panhard rod bushes properly first, if you get the death wobbles. I'd bet money they cause the majority of death wobbles. King pin preload really just gets rid of an annoying shimmy after balancing etc etc is checked.
You don't have this issue warthog. I'm speaking generally.
Franky.
04 guIII TD42Ti ST-L. 2" OME Lift, Tough Dog RTC Damper, 285-75 MT ATZ P3's, Safari Snorkel, Dual Batts, Hid Spots, False Floor, Drop slide, Uhf.
The Following User Says Thank You to Franky73 For This Useful Post:
warthog (30-04-2017)
Old 30-04-2017, 11:13 PM
klappers's Avatar
Franky.
Changed mine with genuine, no difference
Old 30-04-2017, 11:42 PM
warthog's Avatar
Franky.
Yeah I've never had them apart was all. I wonder how they are going.
Old 20-05-2017, 12:43 AM
Sydo's Avatar
Had the wobbles around 80kmh but not bad. Adjusted tough dog damper up 2 notches and gonesky
