Ironman foam cell pro - Page 2 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > General Technical Discussions > Suspension and Steering
Old 26-12-2014, 10:03 AM
2jz929's Avatar
Chucked mine in the other day. Really smooth shocks, very happy at the moment. If the last then I'm on a winner, and as others have said - they are massive.
Was worried about going away from the Koni 88's as they have been so good but these are just as comfortable.
TD42 GU Wagon - Twin-Lockers, TD05 18G, DC 12mm pump, 3" Lift, 315 KM2's + lots more
http://www.patrol4x4.com/forum/membe...u-wagon-53091/
The Following User Says Thank You to 2jz929 For This Useful Post:
the big rig (26-12-2014)
Old 03-01-2015, 02:13 AM
1silverback's Avatar
How would these rate against the new OME sports.
Cheers Peter
2002 extended cab 4.2td. winch,uhf and barwork and waiting to be molested.[/IMG]
Old 03-01-2015, 05:36 AM
Brown Hornet's Avatar
Cant compare to OME but they are feeling like a much better ride than EFS. Heading out to kenilworth today to do a little more " testing "
2005 3.0 GU IV
2" Ironman Foam Cell Pro... 285/70/17 Mickey Thompson ATZp3, 2 3/4 beaudesert exhaust, LockRite Lokka... Nads...of course.
Old 03-01-2015, 08:49 AM
Originally Posted by sudso View Post
Putting them on mine soon!
I've had the std Ironman Foam Cells for the last 2 years and they are going great but only done about 15,000km on them. Have given them a hard time too, the dirt roads/tracks around here are as rough as guts.
As for reviews the Pro's are said to be valved very differently than the std foam cells but give a great ride. I know of a couple who run them in their comp trucks (Patrols) and they love em! Fat Big bore, big shaft, huge capacity.
Ironman say the Pro's have the best quality of everything in them (seals, valving, shims, oil, 3mm thick tubes etc etc) and are rebuildable and adjustable. Up to 8" lift lengths too for Patrols and Cruisers.
Well priced too from around $220 each
Cant wait
When you mention adjustable, are you able to purchase different shim stacks for these? They are not externally adjustable are they? Sounds like they are fairly comfortable with stock valving anyway, but would be good to have the option to try different valving if required.
Old 07-01-2015, 06:21 PM
How'd the testing go out kenilworth? Are they a comfortable ride?
Old 09-01-2015, 12:27 PM
ZORDO's Avatar
Replacement shims will be available in a month
LOVELLS -EFS- DOBINSON - BILSTEIN-KONI - RANCHO- TOUGHDOG- BLUEMAX - COIL SPACERS from $46pr - 4WD SUSPENSION & BODYLIFTS 0418 780 611 PH/FAX- 07 3351 2692 http://www.zordos4wdsuspension.com.au/
Old 12-01-2015, 11:30 PM
Perth Patrol's Avatar
so how are they running everyone? still happy? is a hard choice between the serious sized buggers and mono's
2004 GU IV ST-L TD42Ti
TD05 18g, 3" Exhaust, 2" Lift, 33" Muds, F&R Lockers, Winch, Dual Batt, Drawers, UHF, Fridge, more...
Old 15-01-2015, 03:47 PM
Robpar13's Avatar
Had them since the day of release and still love them... Been up the beach multiple times and to many 4wd parks, handle wonderfully.. 15,000 kms in so far
Rob
|2006 GU 4.2 ST Wagon|
The Following User Says Thank You to Robpar13 For This Useful Post:
the big rig (15-01-2015)
Old 20-01-2015, 09:57 AM
2jz929's Avatar
Just got back from a 3 week 5300km trip taking in the high country fully loaded and they have been unreal. Couldn't recommend them highly enough at this stage.
the big rig (20-01-2015)
Old 20-01-2015, 04:19 PM
hey TysGu, they have been great, purchased 250-400kg set up as i have rear draws and plans for winch bar...possibly rear bar. They handled the bitumen really well and flexed up great as soon as i hit the tracks.... very early days but very happy so far.
2005 3.0 GU IV
The Following User Says Thank You to Brown Hornet For This Useful Post:
Old 20-01-2015, 04:23 PM
Sméagol's Avatar
Has anyone given them a good workout over heavy corrugations for long periods of time?
Old 20-01-2015, 04:48 PM
You guys arent making the decision any easier. As above, anyone done 12hrs straight on heavy corrugation? We've done 12 on the tough dogs and they were managable but you had to DRIVE the whole 12hrs.
The Following User Says Thank You to Perth Patrol For This Useful Post:
Old 21-01-2015, 03:42 PM
Sydo's Avatar
Sydoforumsuperfan :)
Tough dog 45mm adjustables ?
Old 21-01-2015, 04:18 PM
Nah mate. Just the standard tough dogs. I could feel the fade but had to drive through it because of deadlines.
Sydo (21-01-2015)
Old 21-01-2015, 09:26 PM
BORDERTREK 4X4 & FABRICATION
Sorry, height adjustable on selected makes and models ie: dual cab front struts etc. Not adjustable on Patrols and cruisers etc
4WD Accessories, Dobinsons & Ironman 4x4 Dealer, Welding, Auto Electrical Parts & Spares, Installation
Ph 08 8752 1389 b/hrs Mob 0400 250 734 b/hrs Bordertown SA
Old 12-03-2015, 12:15 PM
Ironman 4x4's Avatar
I did during testing mate - across the Fink Race Track and the Simpson desert. We drove 3x Ironman 4x4 vehicles kitted out with Foam Cell Pro across the desert along with the GU which had the standard Foam Cell shocks as did the Hilux.
The GU was by far the most comfortable ride - though it was helped by getting to ride shotgun with Penny Wells :P . But in all seriousness this was due to it and the Prado 150 being the only vehicles with rear coils, and being coils on the front as well, it beat out the Prado.
The GU did manage to verge on 115 degrees centigrade at one point and that's where you'll start to feel some fade from the shocks. BUT if it had been running the Foam Cell Pros I have all confidences that it would have been 30 degrees cooler (based off the GVM upgraded 79 series dual cab's temperatures) and wouldn't have been near fading.
On the trip we were driving 16 hours a day, often across corrugations, and at other times like through the fink and the simpson itself over whoops. We did 7 solid days of driving, leaving from Melbourne and driving up and doing the Simpson and Fink from the West heading East.
External temps during the trip were around the mid 40s across the days and not a lot cooler overnight.
Now saying that, I'm of course going to be bias, but it does give you an idea of the testing they endured. I'd have all confidence that you'd be able to drive extended hours on corrugations without fade.
Regards,
Matt
Marketing Manager
Ironman 4x4
The Following User Says Thank You to Ironman 4x4 For This Useful Post:
Sherro1 (05-04-2015)
Old 05-04-2015, 12:46 PM
Had mine in 4 mths now. Did most of the SA/Vic Border Track a couple of weeks ago which has heaps of woopty do's. Normally would have to go slower but was able to maintain a faster speed with the Pro valving and bigger bore etc etc.
Cant comment on long haul corrugations yet but what Matt from Ironman has said should give you a good indication
The Following 3 Users Say Thank You to sudso For This Useful Post:
kblof (05-04-2015), Sherro1 (05-04-2015), the big rig (05-04-2015)
Old 12-04-2015, 09:29 PM
Default Foam Cell Pro from Zordo
I finally chose a set of these last week. Ordered from Zordo after he kindly took me for a run in his cruiser, and I picked them up the next day.
Gave them a good test run over the weekend through the bush between Dayboro and Woodford and so far so good. My patrol has never riden and handled as comfortable as it is now. I compared and tested a lot of the more expensive options and these were the pick of them all for my set up, and also a lot cheaper.
I definitely recommend Zordo for great service and advice.
Old 08-06-2015, 08:19 PM
Beerhunter's Avatar
Glasshouse Bogan #1
Still happy with these? Think i might order some 6 inch of these from zordo tomorrow for the rear.
DUALCAB GU TD42 UN-COMMONRAIL DIESEL
Old 09-06-2015, 07:13 AM
Sydo's Avatar
I tend to avoid buying stuff with the word Ironman or Tigerz11 but if Zordo is selling them they are probably a good thing
