Ironman foam cell pro - Page 7 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > General Technical Discussions > Suspension and Steering
  #121
Old 14-05-2016, 12:52 AM
Mine have been decent. Koni88s were nicer on corrugatiosn BUT they were on the softest setting and a bit too soft. Definitely haveny had them or driven them long and hard enough to suggest their durability. Going up north next year for 6 weeks of exploring so will have a better idea then but so will everyone else haha
  #122
Old 02-09-2016, 08:13 PM
ballsy's Avatar
Any further updates on them?
  #123
Old 16-12-2016, 06:38 AM
Sydo's Avatar
Sydoforumsuperfan :)
4" shock has nearly 1" less open and closed length compared to 4" OME. Useless trivia for the day
  #124
Old 16-12-2016, 08:56 AM
So same travel? That can be a good thing.. still have to space bumps or shock towers with these so that would mean even more spacing with OME?
Waiting for a set of 4inch shocks to arrive for my GU.
GU ST-L 6.6 duramax
  #125
Old 06-01-2017, 07:02 AM
Sydo's Avatar
Anyone's rear shocks rubbing on the coils ?
  #126
Old 06-01-2017, 09:38 AM
Are the rear shocks offset to avoid this happening ?
  #127
Old 19-01-2017, 07:02 PM
ZORDO's Avatar
Yes these shocks are off set to reduce the rubbing.
With any big shock & 3" +lift you also have to do the longer lower arms or adjustable upper.
LOVELLS -EFS- DOBINSON - BILSTEIN-KONI - RANCHO- TOUGHDOG- BLUEMAX - COIL SPACERS from $46pr - 4WD SUSPENSION & BODYLIFTS 0418 780 611 PH/FAX- 07 3351 2692 http://www.zordos4wdsuspension.com.au/
  #128
Old 20-01-2017, 08:46 AM
I've got my front shocks, still waiting for rears.
Interestingly I measured them against standard Gu shocks, (stock Vs 4inch), the ironman actually had bugger all extra travel which was surprising and they are only 3inches longer extended.
GU ST-L 6.6 duramax
  #129
Old 20-01-2017, 07:13 PM
ZORDO's Avatar
The Pro shocks do have a 35mm bump stop which will reduce compressed length
  #130
Old 21-01-2017, 05:03 PM
Sydo's Avatar
  #131
Old 09-03-2017, 05:28 PM
ballsy's Avatar
Looking at getting these in the next few weeks. Mh only concern is valving seems to be talked about commonly as being on the fairly firm side of things and im pretty light on for weight.. anyone got these in a light gq?
