Extended brake lines - Page 2 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > Vendors > Zordos 4WD Suspension
Old 19-03-2014, 08:27 PM
Romanthedestroyer's Avatar
Hey Zordo, chasing a price for 4 inch extended braided lines for a 2006 4.2 ute.
Old 20-03-2014, 07:31 PM
ZORDO's Avatar
Hi mate.
$80 each
Postage to Toowoomba is $15
LOVELLS -EFS- DOBINSON - BILSTEIN-KONI - RANCHO- TOUGHDOG- BLUEMAX - COIL SPACERS from $46pr - 4WD SUSPENSION & BODYLIFTS 0418 780 611 PH/FAX- 07 3351 2692 http://www.zordos4wdsuspension.com.au/
Old 20-03-2014, 10:17 PM
Is that for the two down to the diff? How much for the ones to the wheels?
Old 21-03-2014, 08:02 PM
ZORDO's Avatar
Hi mate.
I only do brake lines chassis to diff
Old 21-03-2014, 09:37 PM
Ok. Is it possible to get braided lines on the wheels at all?
Old 23-03-2014, 07:19 PM
ZORDO's Avatar
Yes mate. you are looking at $70ea
Old 19-04-2016, 09:23 PM
Hi Zordo - Are you still doing brake lines? How much for rear brake line for an 2005 non abs with 6 inch lift inc postage to 2175?
08 Patrol Wagon, 2 inch lift, 33's, front/rear bars, sliders, Ironman 12000lb winch, ARB lockers front and back.
Old 13-05-2016, 03:31 PM
ZORDO's Avatar
$95 posted
Old 02-04-2017, 06:26 PM
Are the two front lines (have abs) easy enough to fit? Has anyone done a step by step guide on here?
Old 02-04-2017, 08:54 PM
Piece of cake to fit.
Do left front side, bleed.
Repeat right front side.
2010 CRD Auto, White, ECU flash, Nomad valve body, Lockrite front, manual hubs, EFS coils, bullbar, winch, etc.
Old 09-04-2017, 06:28 PM
Thanks mate, where both my lines go up to the chassis on the front (have abs) is it a case of just undoing the nut on the steel line coming down and then they just come off? Or are they held onto the bracket with a circlip?
The one on the passengers side looks like a ***** with the aircon compressor in the way...
Old 09-04-2017, 07:13 PM
Is there a specific order for bleeding if replacing both front and rear diff lines?
Old 09-04-2017, 07:25 PM
I believe when bleeding any brake you start with the calliper which had the longest amount of line to the master cylinder
Old 09-04-2017, 08:29 PM
Bingo!
http://powercurve.com.au/
Old 09-04-2017, 10:18 PM
No, not bingo at all.
You startvwith the proportioning valve.
Unless you have a 2012 or later Patrol.
Old 10-04-2017, 07:59 PM
Bleed the proportioning valve?
Old 10-04-2017, 08:19 PM
Yes
