ECUTALK for td42ti conversion - Page 3 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > General Technical Discussion Forums > Auto Electrical
Old 16-05-2019, 07:53 PM
drgtr's Avatar
and is it simple as just turning the tps after I losen the bolts and watching the voltage change on the ecutalk display?
Do I do it with engine on at Idle or just key turn onto reds/accessories?
2003 Td42Ti Gold Manual Wagon
3 inch Exhaust
Larger Top Mount Intercooler
Mamba 18G 6cm
Dyno Tuned to 23psi
315 75 16 Kumho Mt51
Highway 13.3L/100km
Suburb 14.6-15.6L/100km
Old 16-05-2019, 08:00 PM
I Am Me and I Love My ZD30
Originally Posted by drgtr View Post
Im so happy. I love it!
I always had a scangauge in my other cars now I have the best of both worlds. No ECU simple reliable engine but still have data!
at idle my TPS is 0.00 Does that mean my TPS is adjusted wrong?
Sorry mate can't answer that one, I'll let someone with a relevant 4.2 answer that, our TPS reads around 0.48v, if setup for % then naturally it is 0.
I Like a Tidy Forum - 2000 ZD30 with a few bits and a New Eclipse Turbo
My Album - My ZD30DI Build Thread - My Channel - My Garage - Harley. Performance Tech
ZD30DI Tech Archives - NADS, So You Bought a ZD30
- Powercurve.com.au
Boost Control by Digibooster - Domestic Violence Has No Excuse.
Old 16-05-2019, 08:13 PM
drgtr's Avatar
Thankyou. Ill check to see what its on as a display option
3 inch Exhaust
Mamba 18G 6cm
Dyno Tuned to 23psi
Highway 13.3L/100km
Old 22-05-2019, 09:39 AM
My TD42TI reads 0.74V at idle(550rpm) and 4.04V full throttle.
Hope that helps
Old 22-05-2019, 11:35 AM
drgtr's Avatar
Hope that helps
ta
are you auto or manual
I set mine to 0.58v now and sooooo much more smoother down below and makes boost come on earlier
Before it was sitting on 0.00v at idle
3 inch Exhaust
Mamba 18G 6cm
Dyno Tuned to 23psi
Highway 13.3L/100km
Old 23-05-2019, 08:07 AM
ta
Mine's a manual.
I adjusted it back down to 0.6V at idle and can't really tell any difference. Might just put it back for now
Old 23-05-2019, 08:49 AM
drgtr's Avatar
can you do me a favour if you have time today. Disconnect TPS and test drive?
See if any difference
3 inch Exhaust
Mamba 18G 6cm
Dyno Tuned to 23psi
Highway 13.3L/100km
Old 25-05-2019, 07:38 PM
skivvia's Avatar
Default options
All excellent info in this thread. If I may add, just for completeness if anyone visits this thread in future, there in another option to read the ECU.
In my 4.2 TDi, I have a bluetooth connection to whatever phone/tablet I want to read the data on, read and clear error codes etc. Logs data to a csv file too. Can customise the dashboard etc.
I have no connection to the seller, as I said, just to show options if anyone is interested. It's nissandatascan.com with a dongle from ConsultBT: Nissan Consult Bluetooth adapter
Banana bender 4.2TDi with some mods
The Following User Says Thank You to skivvia For This Useful Post:
drgtr (25-05-2019)
Old 25-05-2019, 07:43 PM
drgtr's Avatar
Thank you Skivvia
You are the best
I rather that the ECUTALK as my double din unit is android!
I use to use a OBD2 bluetooth adaptor with torque app.
So kinda dissappointed when I realise I had no options until you mentioned it tonigh
Thank you. Ordering now!
3 inch Exhaust
Mamba 18G 6cm
Dyno Tuned to 23psi
Highway 13.3L/100km
Old 25-05-2019, 07:47 PM
united fuel injection
ta
Factory voltage is .65v at idle of 650 rpm .
www.unitedfuel.com.au
Building tough 42's
Just a Redneck havin a go
Home of 200RwKw monsters
The Following User Says Thank You to ToughDiesels For This Useful Post:
drgtr (25-05-2019)
Old 25-05-2019, 08:04 PM
JFF45's Avatar
I seem to recall the factory manual says 0.4v - 0.6v at idle but the engine doesn’t need to be running.
John
GUII Ti 4500 - converted to TD42T auto
Old 25-05-2019, 08:08 PM
Factory specs ? now who adheres to those when tuning ?
Its always best to do it with the engine running and you are happy with the idle speed as if you change idle speed the voltage changes.
Building tough 42's
drgtr (25-05-2019)
Old 25-05-2019, 08:21 PM
JFF45's Avatar
You’re a more patient man then me to be trying to finely adjust the TPS on a shaking TD42
John
Old 25-05-2019, 08:50 PM
drgtr's Avatar
Even for td42ti?
If thats the case. I should adjust to match that?
What happens if lower or higher?
Do you get retarded timing and hesitation as a result?
Thanks again for your help
3 inch Exhaust
Mamba 18G 6cm
Dyno Tuned to 23psi
Highway 13.3L/100km
Old 25-05-2019, 08:51 PM
drgtr's Avatar
ahh my idle is at 800rpm and its set to 0.58v
So you said .65 at 650 rpm
so at 800rpm you advising it should be higher?
Thank you
3 inch Exhaust
Mamba 18G 6cm
Dyno Tuned to 23psi
Highway 13.3L/100km
Old 02-06-2019, 07:52 PM
drgtr's Avatar
Can you guys decipher my ecutalk gauge at idle and at 2000rpm
When cold the car goes really well.! Responsive and boost comes on quickly.
When warmed up I noticed it has more of a hesitation to it.
Spoke to another Td42ti who had the same issue and he tried adjusting his pump timing and it made no difference. He got sick of it too.
https://www.youtube.com/watch?v=L_Ds...ature=youtu.be
My first impression is injection pump timing is too low?
3 inch Exhaust
Mamba 18G 6cm
Dyno Tuned to 23psi
Highway 13.3L/100km
Old 05-06-2019, 07:11 PM
Dark side's Avatar
That ecu talk will be the death of you .
The Following 2 Users Say Thank You to Dark side For This Useful Post:
festerGU (05-06-2019), Haggie (05-06-2019)
ECUTalk Consult Software Now Supports Diesels NewKleer Nissan Patrol GU/GR Y61 203 11-05-2019 07:00 PM
GU 2.8 - RB25DET Conversion rb25detpatrol Nissan Patrol GU/GR Y61 143 10-09-2016 08:50 PM
G60 Disc Conversion (C216 G60 Drum to C200 MQ/MK Disc) Swerve Classic Nissan Patrols 6 29-05-2013 09:57 PM
L28 GM Delco ECM Conversion neRok Nissan Patrol MQ/MK 160/260 series 16 28-03-2011 09:43 AM
