What did you do to your GU/GQ Patrol today? - Page 721 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > General Technical Discussion Forums > General Patrol Discussion
  #14401
Old 26-04-2019, 04:06 AM
Drove it to work and back
Just like pretty much every other day...
  #14402
Old 26-04-2019, 11:26 AM
Boundry Rider's Avatar
Master Coalroller
Finally installed my ProVent 200 and now I get an actual slight vacuum reading in my crank case which is good news for rings seating performance yay.
File Type: jpg AF8D0A9D-6431-47D9-9431-549662ABA41A.jpg (66.9 KB, 36 views)
Big Grey '88GQ 6.5TD V8 4"Pipe 2"Body & 3"Dobinsons & HD Superior Components 3.545 Detroit & ELocker 35" Toyo MTs
The Following User Says Thank You to Boundry Rider For This Useful Post:
Oscar and Leone (26-04-2019)
  #14403
Old 27-04-2019, 01:07 PM
Marko_SJ's Avatar
Originally Posted by JT54 View Post
Something to consider. 12 months ago (my CRD/then full manual boost control) had a whistle/metal ring type sound, also like a fan hitting a metal cowl and sounded like coming from around turbo.
Took off turbo inlet elbow, felt a bit of comp shaft side slap and had a visual of a slight hone of housing bore adjacent to comp wheel. Thought the noise was being caused from the effect of the comp wheel touching the housing. Noted also at idle, I could wind the needle valve out a few turns and the noise would stop (reduced boost), once again thought turbo but after removing stock turbo and in with the Procharge stage3, fired her up and noise still there_ stuff it. ECPT installed it so to ensure warranty cover for new turbo. Was pulled down again, checked the exhaust manifold and yep the first two exhaust studs had failed / leaking gasket, then repaired (machined manifold and fitted Inconel studs) and then all good. Was very early stages of hearing the noise. I even took up a new exhaust manifold gasket for Harley just in case but from initial inspection it all seemed to be good with the exhaust manifold but we were fooled. Was a Bgrrrr.
Guess now have the new turbo and gets better as time passes, just keep playing and enjoying it....
Understand that the bearing can have a fair bit of play as when the oil pressure comes up the shaft will centralize with bearing.
Its the turbo annd it's my fault it's dead.
When I cut up the standard airbox I installed a K&N pod temporarily in it's place. The adaptor I got online was a poor fit. I tried to get a better one locally but couldnt, instead of having a a modicum of intelligence and parking the car up I drove it anyway.
Pulled the intake el off it this morning, really bad comp wheel damage.
Dunce hat goes to Marko.
GU CRD, a sierra and a "couple" of motorbikes.
  #14404
Old 27-04-2019, 01:27 PM
I Am Me and I Love My ZD30
Take a pic of the compwheel damage, they can have a bit of damage and still work ok, mine received damage due excess water from a badly positioned pre turbo nozzle many years ago (see below), still worked pretty good with a nice whistle . If the bearing is fine and not causing the wheel to contact the housing it should be OK for a while, was it still boosting OK?
I Like a Tidy Forum - 2000 ZD30 with a few bits and a New Eclipse Turbo
My Album - My ZD30DI Build Thread - My Channel - My Garage - Harley. Performance Tech
ZD30DI Tech Archives - NADS, So You Bought a ZD30
- Powercurve.com.au
Boost Control by Digibooster - Domestic Violence Has No Excuse.
The Following User Says Thank You to geeyoutoo For This Useful Post:
Marko_SJ (27-04-2019)
  #14405
Old 27-04-2019, 01:59 PM
Marko_SJ's Avatar
Attachment 490461
Surprisingly it easily still makes 18PSI and doesnt seem to have contacted the housing.
Leading edges are chipped on several of the blades of the impellor and bent on others. I wouldnt dare drive it due to being out of balance.
  #14406
Old 27-04-2019, 04:41 PM
JT54's Avatar
@Marko_SJ
Can you get a visual of the bore/wheel with mirror or endoscope and move the shaft end sideways with finger, is comp whl touching housing? It will need rebuilding or replacement at some stage now. Not a good find for you mate with trip coming up.
Take your intercooler off, wash it out as may have trapped the unwanted and hope the engine has not been dusted. Guess you will fix that induction pipework.
2008 GUIV WAG ST Manual CRD - To do the job
The Following User Says Thank You to JT54 For This Useful Post:
Marko_SJ (28-04-2019)
  #14407
Old 29-04-2019, 07:48 PM
started fitting new brake rotors i've had sitting around for some months now, contrary to popular belief the rotors pert near fell off the hubs, was pleasantly surprised.
The Following User Says Thank You to bxnswau For This Useful Post:
JT54 (01-05-2019)
  #14408
Old 01-05-2019, 09:52 AM
Softy's Avatar
Forum Tragic
New alternator which cost me $180 from eBay. Couple of members from here have had one in their cars for a couple of years now. So will see how it goes.
On Anzac Day i decided to fit it.. and because I'm a rough bstd this happened.
So tapped it up and went on the hunt for a replacement.. fun on a public holiday. But Facebook come to the rescue with this.
As I was going away on the weekend I needed some USB charging from the second battery...
Some areopro triple bank thing I just cut the cig lighter plug off, soldered my own switch onto it and hooked to the second battery. Might neaten it up... Might not either.
Now my new little toy.. I've had the one on the right for ages now, was good for keeping an eye on the battery, made redundant now I have an ecutalk... But anyway. The new one on the left is hard wired to the second battery, and has an inbuilt switch and some fancy fast 3.0 USB charger in built. Will see what it's like in due course.
Sent from my Pixel 3 using Tapatalk
2003 GU SIII Auto Grenade. 2" Lift, Full NADS, 3" Exhaust. Few other things
The Following 7 Users Say Thank You to Softy For This Useful Post:
Foo (02-05-2019), JT54 (01-05-2019), Marko_SJ (01-05-2019), skegbudley (01-05-2019), warthog (01-05-2019), wock78 (02-05-2019), Yeti's Beast (02-05-2019)
  #14409
Old 01-05-2019, 07:02 PM
BeNos's Avatar
Forum Tragic
Send a message via MSN to BeNos
fitted rear barn door strut. man oh man why did i not do this years and years and years and years ago.
gold gu TD42T Build in progress.
New Bus
For good prices on battieries and caltex oils, seq only.
www.revolutionforklifts.com.au
The Following 2 Users Say Thank You to BeNos For This Useful Post:
skegbudley (01-05-2019), Yeti's Beast (02-05-2019)
  #14410
Old 01-05-2019, 07:21 PM
Forum Tragic
Yeah mate it is
I like shiny stuff
  #14411
Old 11-05-2019, 09:43 AM
How much was the paint job?
BLUE OVER SILVER Club member No 5
RB30 #2 Dual fuel
NON-WHITE Patrol Club Member No 5
COB #8
  #14412
Old 11-05-2019, 12:42 PM
Overboard's Avatar
As long as you have an intercooler to catch the bits I'd still drive it until I was ready to replace it.
GU Series 1 wagon
Jan 2000
TD42T
The Following User Says Thank You to Overboard For This Useful Post:
Marko_SJ (15-05-2019)
  #14413
Old 11-05-2019, 02:49 PM
gu_2.8's Avatar
Ready for a day in the mud tomorrow with a new backpack for the muddy chit. $9 down from $60.
Sent from my iPhone using Tapatalk
1999 GU 2.8L
Snorkel
Dual Battery
EGT
The Following User Says Thank You to gu_2.8 For This Useful Post:
warthog (11-05-2019)
  #14414
Old 11-05-2019, 03:15 PM
Patty91's Avatar
$2000, my work does all the glass work for one of the local crash repairers so I organised a cash weekend job with one of the guys.
1991 GQ Ti TD42 (naturally asthmatic)
GQ TD 4.2 Club #11
The Following User Says Thank You to Patty91 For This Useful Post:
Grafe (12-05-2019)
  #14415
Old 11-05-2019, 05:43 PM
Patty91's Avatar
Finally worked out how to get a for sale ad up here.
https://www.patrol4x4.com/forum/patr...i-td42-407153/
GQ TD 4.2 Club #11
  #14416
Old 11-05-2019, 06:15 PM
GUzdute's Avatar
I am not a homo.
Can't do that in mine . It has an ashtray there.
NICK
My crd crossed the Nullarbor and back.
Now done the Vic High Country.
Is there anywhere my crd won't go.
240000 kms and still going strong.
  #14417
Old 11-05-2019, 09:21 PM
MQTray's Avatar
Pass the Popcorn
Easy done....Just replace your with a wagon infill panel.
'03 GUIII TD4.2Ti DX C/L Cab Chassis! UFI 18G TMCC intercooler BTC 4" airbox @ 125kw Micks HID
You can check out any time you like, but you can never leave.
  #14418
Old 12-05-2019, 09:25 PM
gu_2.8's Avatar
Had playtime in the mud. Only managed to break a couple of clips on the wheel arch guards. Will assess patrol for any other damages. Did manage to fill the entire g box cross member with mud and also all around the g box mounts. Clean up tomorrow after work.
1999 GU 2.8L
Snorkel
Dual Battery
EGT
The Following 3 Users Say Thank You to gu_2.8 For This Useful Post:
Marko_SJ (13-05-2019), skegbudley (12-05-2019), Yeti's Beast (12-05-2019)
  #14419
Old 13-05-2019, 10:50 PM
SteveInAus's Avatar
Default Pulled a bunch of wiring out
Lots of terminals handing off the aux battery of my ex-telstra car so decided to follow them and pull them out along with the unknown antennas. Turns out all those wires went nowhere, all cut and tucked I'm guessing before being auctioned off.
Had a lucky break and found 2 long runs, one a heavy gauge on a 20A fuse and another on a 15A fuse that I used to run to the rear of the wagon and wired into a double 12v socket. Fridge and camp lights sorted.
Also installed a Uniden UH5000 and 6.6 dBi antenna with all under bonnet wiring double insulated just to be sure.
2013 DX ex-Telstra Wagon. Manual cause itís more fun 👍
  #14420
Old 14-05-2019, 11:54 AM
y b normal's Avatar
Built this.
simplify, declutter...& go forth with purpose.
if you want to know what cylinderhead reconditioning company NOT TO USE in brisbane, p.m. me
i'd go vegan, but that would be a mist steak.
Press Release (Nissan Australia): Patrol more affordable.. Link Nissan Patrol GU/GR Y61 7 04-11-2011 11:03 PM
Patrol loss of torque especially when towing meercat Nissan Patrol GU/GR Y61 6 30-08-2011 01:34 AM
Press Release (Nissan Australia): Patrol more economical.. Link Nissan Patrol GU/GR Y61 20 19-10-2010 01:08 PM
Welcome to the Patrol 4x4 Forum [Updated 17th Sep] Link General Discussion 11 16-05-2010 02:16 PM
Buying my first 4wd - GU Patrol? jarz85 Buying a Nissan Patrol 10 24-07-2009 12:28 PM
