Line Pressure Solenoid Dropping Resistor - Page 14 - Patrol 4x4 - Nissan Patrol Forum
Go Back   Patrol 4x4 - Nissan Patrol Forum > Nissan Patrol and Safari Model Forums > Nissan Patrol GU/GR Y61
  #261
Old 22-12-2016, 07:44 PM
mad possum's Avatar
definitely a good little mod. was reluctant about doing it at first on a car with 55,000km but glad i did. Thanks for the R&D everyone. one day I'll do further mods when i have the cash.
2012 CRD Simpson ed.
Sold: 4.8 GU
My CRD build thread. https://www.patrol4x4.com/forum/membe...t-mods-359225/
  #262
Old 24-12-2016, 04:38 PM
Default your inbox is full
Originally Posted by skegbudley View Post
Let us know if you get stuck. Always happy to help.
just after your address mate so can you pm me?
1998 GU1 LS1 - rear dual wheel carrier, rock sliders, roof rail, awning, 33"s with Kumho mts, 2" lift, UHF, snorkel with 4" airbox mod, dual battery, 12000lb winch
  #263
Old 24-12-2016, 05:46 PM
Forum Tragic
Done.
  #264
Old 04-08-2017, 04:31 PM
Marko_SJ's Avatar
Originally Posted by Chaz View Post
G’day [email protected],
I guess you could say this is the geeks way. I experimented with a few resistors and found that anything up to a few hundred ohms doesn’t make much difference. Simply unplugging the resistor makes a very noticeable difference, but a bit harsh at light throttle. Anything between 1K and 5K ohms seems to work ok, but the higher the resistance, the quicker/harder the shifts.
The TransGo Kit really only addresses the 1-2 shift, where this mod effects all upshifts, downshifts and converter lockup.
Thanks for this information Chaz. Found this thread courtesy of @mad possum. I have tried the unplug the resistor trick to see if I like the feel (it IS a bugger of a plug!).
Love it, albeit manual shifts of the "t bar" at light TP do get a bit shunty and within a short while I got a P0745 code.
Just to make sure I understand this correctly: I simply take the existing resistor and put a 1-5K one in it's place? The higher the value the less the solenoid bypasses pressure?
This should smooth it out somewhat, and sort out my Patrol throwing codes?
GU CRD, a sierra and a "couple" of motorbikes.
  #265
Old 04-08-2017, 09:31 PM
mad possum's Avatar
correct and correct. glad we have another patrol with an improve auto
Sold: 4.8 GU
The Following User Says Thank You to mad possum For This Useful Post:
Marko_SJ (08-08-2017)
  #266
Old 08-08-2017, 04:52 PM
Marko_SJ's Avatar
Cheers mate. Just picked up another bracket/plug/resistor setup from the wrecker. I'll probably set it up the same was as Chaz's setup with the 2x 4K8ohm and a switch.
Tonight's job is to install projector LEDs into my full function lights and tidy up the loom for permanently, as well as re-install the standard line pressure solenoid resistor to get rid of my CEL and code for now.
Cheers all.
  #267
Old 13-09-2017, 03:42 PM
2005 zd30 with the re40r03a trans has nothing on the plate next to the booster! Any ideas fellers?
  #268
Old 11-02-2018, 04:24 PM
chule's Avatar
I've been testing the shift change and drive-ability of the trans with the factory resistor unplugged. It feels fine for my set up although as previously reported, at certain stages on a light throttle the 1-2 gear shift is really harsh.
Would it be ok to continue driving with it unplugged or should I just install a high ohm resistor so the TCM reads some voltage? I haven't had any faults at this stage.
Ta.
Sent from my iPhone using Tapatalk
05 GU IV DX clutchless 4 speed Grnd
  #269
Old 27-04-2019, 01:24 PM
So I have a 4.2, disconnected the resistor and have no real difference. Is there a possibility the line pressure solenoid is not working properly?
I had the fault light come up and the pulsing when the vehicles coasting so the system at least recognizes it being disconnected.
Thoughts would be much appreciated.
99 gu 4.2td
  #270
Old 28-04-2019, 11:47 AM
I thought the line pressure resistor doesn't change the pressure, it just change the timming.....
Sent from my mobile using Tapatalk
2006 ST GUIV to Cummins ISDE4.5 DIESEL, RE4 AUTO, EGT, FRONT IC, 2" left, ARB Bullbar, CUMMINS Engine Monitor, 3.54 DIFF, Stage 3 HD Valve body, Shiftkits Programmable TCU, BF LT275/70/R17AT
  #271
Old 28-04-2019, 11:59 AM
Forum Tragic
It changes the pressure. Or more accurately it lowers the pressure so there is a bit of slippage so gearshifts are smoother.
I like shiny stuff
Manual boost control and limp mode alki Nissan Patrol GU/GR Y61 37 07-03-2011 04:50 PM
ZD30 fuel pressure tweak'e Nissan Patrol GU/GR Y61 17 04-07-2009 08:45 AM
Power steering pressure return line... Alex Langston Nissan Patrol GQ/Y60 & Ford Maverick 7 10-10-2007 10:21 AM
