1 - 1 of 1 Posts
hey,
I have recently converted from toyota to a 2008 GU patrol and loving it. i have started the mods with an ARB bull bar and am now on to spotties. I plan to use the existing factory fog light plugs,wiring and switch but ther is no power to the plugs.
i have done some continuity and voltage tests and there is a problem fron the factory fog light switch to the control side of the fog light relay. i have power from the high beam wire and continuity from the battery to the relay and from the relay to the plugs and a negative from the plugs.
To cut a long story short does anyone know if there is a second plug from the fog light switch to the relay.
cheers.
1 - 1 of 1 Posts
