Just a point to consider @Phdv61 with the minimum leaver set screw. I have a turbo dyno machine which is used to set VNT actuators against absolute flow values, so it is very VERY accurate. Setting the minimum lever set screw you can go past stall point of the vain's which will not drive the turbine wheel actually it is very sensitive less then a 1/32 turn to go from stall to flow with turbine wheel speed picking up considerably if you fluke the right setting. The dyno test machine has the ability to set turbine flow volume at absolutes using temps and barometric values with pressure. Using Nissans set spec for vacuum and rod travel even with 4psi pressure flowing into the turbine the VNT will stall with less than 1/8 of a turn out on the limit screw on a new std ZD30 turbo.
I cannot comment on your setup or the altitude change and difference to this limit screw position as i have no need too, we just dont have a need here in AUS for this attribute. But with your second needle valve and setting minimum vacuum at start would go a long way to get the vain's out of stall quickly and effectively.
I like and commend you for thinking outside the square on this subject, the second needle valve has huge potential and merit. Closed VNT vain's until max boost will not drive compressor volume i have proved this on the turbo dyno bench test machine. The vain's must open through acceleration and can be set as to not hinder spool or boost pressure rise. Boost pressure rise and boost spool is not a measure of a turbos ability to flow volume fast, but density is. As you have found out with your playing with MAF values you can get a lot more flow in spool with less boost pressure. SOOOOOO many pundits just cannot get this concept with turbo charging. As you may be aware its contributed to EMP exhaust manifold pressure and density efficiency of the compressor wheel and its drive power requirement and its start efficiency RPM. Your STD ZD30 comp wheel is not very good at building density or volume until 85,000 rpm and then some, boost value has absolutely nothing to do with this ability, its about turbine drive and EMP. Your STD cast comp wheel was never designed or could be cast in a fashion to build density with volume early like modern CNC machined billet comp wheels.
The STD turbine wheel and VNT design is quite good but doesn't have the drive capacity or phi values to meet the requirements of the heavy cast comp wheel for altitude changes you are talking about, a light billet CNC comp wheel in a similar configuration will be a lot more forgiving at altitude changes with flow volumes.
My interest here and for your idea is to have a mechanical system using current equipment to control the VNT on the auto fitted ZD30 patrol. These auto partols have a few issues due to the auto always imposing load on the engine even when changing gears so the turbine VNT never gets a chance to unload the EMP when using the mechanical control system. Consequently driver input of lifting your foot and depressing in traffic will send the EMP through the roof which leads to deceleration surge which will kill any turbo in the very short term. This little turbo has a small thrust washer and very close together bush bearings which is not very forgiving of deceleration surge.
The CRD auto version using the vacuum solenoid has programming to pop the vain's open for a split second when you lift your foot to release EMP using the TPS as its input. Fitting a mechanical VNT control systems will not compensate for this so the auto patrol will always be susceptible to deceleration surge and turbo complete destruction. Some remap tuners do use the vac solenoid and will get your results if they can understand how a VNT turbo works and its short falls. The Di ECU doesn't have anything close to the adjust ability the CRD versions have auto or manual.
A final note of advice on your playing with the minimum set screw i would suggest you set it back to Nissans spec of -0.68psi at 0.2mm and adjust no more than 1/32 turn from there. It really does make a huge difference on spool volume and mainly transitions on all on road driving conditions. With your trial and error you may already be at this setting. Nissan did do a lot of R&D on this turbo to suit the ZD30 engine especially the Di version. I believe this R&D was done in Poland on a turbo test machine exactly like and brand as the one i have at my disposal.
And again i commend you for thinking outside the box, that is very rare even for engineers.
But there is always a down side here when playing with stuff you done have full and complete appreciation on. I highly suggest to others here to not play with the set screw its very VERY much a tiny weeny turn of the screw to not doing as you expect. But if you must, buy your self a good hand operated vacuum pump with gauge and set the bloody screw as per factory spec to start with as from experience they are never correct. Then have a play with different positions using the pump and gauge as a guide. If you have already played with rod length then you need to set the rod length using the other two Nissan vacuum spec and clearances.. Even then you are still in no mans land as you cannot set the initial minimum flow setting Nissan has set for turbine flow against vain position for this ZD30 engine and its exhaust gas flow and temp volume. This can only be set on a VNT flow bench as Nissan do or more precisely Garret Do. Also different tunes and timing and fuel values will change exhaust gas volume and pulse so adjusting the stop position for a higher tune engine will require a more open vain position not a more closed vain position. Timing is a huge changer on exhaust gas volume hence spool / drive and volume flow through the turbine. So setting the screw and rpm open positions can be set using MAF / MAP values within reason, so thats a very good guide given by @Phdv61.
Off note i understand you are French so your written word can and is a little difficult and can be read with different than intended meanings i had trouble understanding your instructions hence i asked Ross to Email you on instructions with explanations and drawing, you did very well and cleared up much of my interpretations. Maybe our prominent learned ZD30 member miss read a lot of your writings, i see he has retracted much of his comments now. Hope he sticks around to add his perspective and maybe a trial experience using your concept.
