Hi, does anybody know if 1" lift springs are available for the GU. Reason is that my patrol is used for touring so I don't really need much lift. Only have about 20mm gap between front bumpstops and axle and I've already wrecked a bumpstop from hitting it too hard. I would like to keep the konis that are on it (standard length). Also don't want to hit the garage door with the roofrack.
Tony
Just get standard coils. They usually give you a little bit of a lift plus they are a bit firmer so you are less likely to hit your bump stops. $350 for set of 4 including freight.
