Had a problem today, when I went to start the patrol this morning I had a flat battery, so I turned the solenoid on to connect the second battery to first but after turning motor over and letting key go as motor did not want to start the circuit breaker(100amp) between the two batteries kept tripping. Should I go higher amp with circuit breaker or is something else wrong? Not sure what starter motors draw, I jumped the circuit breaker bolts and started no problem from second battery.
Battery was flat because left amp and head unit on without realizing it for five days.:headwall:
cheers DD.
cheers DD.
