As as been asked before, do you need power or are you using a trigger, if it is a trigger for turning something on fine but if you actually want to draw some current run new cable.
If you decide to run a lead through the firewall why not use a trailer wiring lead - 5 or 7 wire. You can never have enough wires....
Not a bad idea, but using a large gauge cable 4 or 3 b&s (rated at 160amp +-) means that you are guaranteed to have 12v exactly all the time and there is no risk of running short of amperage due to the laws of voltage loss. Plus what if you want to add an 8th item to the battery at that point, easier and neater to update a fuse block and just plug everything back in to it rather than having to run another set of cables.
Yes I know that 160amp is a lot, I just purchased 10m of 4b&s and have used that to multiple points in the car to run all the little extras that we all love (Fridge, lights, power points, inverter, etc)
Just some food for thought.
