1 - 20 of 30 Posts
Hey Guys
I am waiting for new units to arrive in a few weeks so just putting the feelers out there!
I can get 120amp alternators for Y60 GQ 4.2L Diesel Engines (TD42) if your interested they should be $585inc plus postage
let me know if interested :)
Autos are Superior
Vacuum pump?
and can you get them for GU?
Autos are Superior
some will need vacuum pump, others wont.. but people will ask on options.
yeah, i'd be keen if it can do the vac pump on the back.
Discussion Starter #10
yep this is the model with the vac pump on the back- can get the later one but its only 100amp
BORDERTREK 4X4 & FABRICATION
Most Factory TD42 GU ones are 100A too and will fit non vac pump GQ's.
Discussion Starter #12
yep thats correct sudso 100amp is all thats avalible. i dont think there are any gq TD42's with out the vac pump the deswign changed with gu running a seperate chain drivcen vac pump. so as before these r the units for GQ TD42 ONLY
Errrrrr
OEX 120amp $$$ a bit over 400 when I last bought from patrol-a-part with vac pump
GU vac pump is driven off the timing gears, just below the injector pump.
The nutty professor
i am pretty sure the design changed in 96 , so there are a few gq`s with the vac pump under the injector pump
Discussion Starter #17
4.5lt 110 amp alternator will bolt straight onto GU td42's.
Marty
1 - 20 of 30 Posts
