I'm into the potentially ruining two transfer cases part of this deal.
I pulled the PTO drive gear out of the ute, the retaining nut behind it was loose and only held in place with a split pin, the service manual specifies 196-333nm and a split pin.
The PTO drive gear is attached to the main drive gear with what I assume are plug welds.
They do sit proud, so I wonder if that was why the nut backed off.
One of main drive gear teeth is chipped.
Not ideal. But that chip seems to have been there a long time. And it doesn't seem to really affect tooth contact, based on the pattern on the teeth.
So she'll be right. Hopefully.
There's apparently a spacer behind that main drive gear too. Seems like the sort of thing I should replace, but I'll pull them out of both transfer cases and see if I can get away with not waiting 14 years to get one shipped from Japan if they still even exist.
