Im having trouble with a soft brake pedal, the patrol is completely rebuilt from the ground up.
Have installed new brake disc on the front and new calipers and pads, ned shoes and piston in the rear, new flexi brake lines, new seal kit for master cylinder, didn't sort out the spongy pedal so new master cylinder complete installed...
system has been bleed with a vacuum bleeder and finished of manually in sequence with gravity bleeding, to insure clear fluid and no bubbles, using DOT 3 fluid..... im all out of ideas and are looking for advice and help from someone who may have gone through the same..thanks
