1992 DA Ford Maverick LWB TD42
Built to Tour Australia
Power & Drivetrain
TD42 With GT28 Turboglide System - 9lb Boost
Sportflow 2.5" Straight Thru Exhaust System
Front Air Locker
Gearbox 5 Speed Manual
Manual Transfer - High / Low Range
Exedy Safari Sports Clutch
Suspension
King Spring Coils 2" Lifted - Front KDFR-42HHD
King Spring Coils 2" Lifted - Rear KDRR-43EHD
Polytech 30mm Coil Spacers All Around
Ironman Foamcell Pro Shock Absorbers - Front 45091LFE
Ironman Foamcell Pro Shock Absorbers - Rear 450951LFE
Superior Panhard - 886 Front
Superior Panhard - 885 Rear
OME Steering Damper
3 Deg Castor Correction Bushes to Front Radius Arms
Wheels & Tyres
OFFROAD
Mickey Thompson Baja MTZ 33" x 12.5" x 15"
Pro Comp Series 98 - 15" x 8" Black 13KG Steel Rims
ONROAD
Sumitomo Serengeti A/T 33" x 12.5" x 15"
ROH Cheviot 15" x 8" White Steel Rims
Exterior
Winch Deluxe Bullbar
12,000LB Tigers 11 Cabled Winch
100W XRay 160 Quartz Halogen Driving Lights
Safari Snorkel with Unifilter Cover
Rock Sliders Under Sills
Flexi Flares
Auxiliary Fuel Tank 75 Litres
Rear Work Light 15W LED
Under The Bonnet
Rotronic Battery Monitor System
Corrosion Guard Rust Prevention System
K&N Air Filter
3 Row O/S Radiator
Dual Batteries
Diff Breathers & Filtration
Interior
Milford Cargo Barrier
Rear Draws All Aluminium
MSA DS40 Platinum Drop Slide
Engel MT45 40L Fridge
Bushman 52L High Top Fridge
Dual Fridge Monitors
Piranha Digital Dual Battery Monitor
Pillar Pod Twin Gauge
VDO Pyre Gauge
VDO Boost Gauge
Engine Watchdog TM2 - Temp & Oil
GME TX3200 UHF Radio
Yaesu FT8900 Amateur Radio
TYT TH9800 Amateur Radio
Navman XLT85 GPS
Tekonsha Primus IQ Trailer Brake Controller
Eclipse CD5030 Head Deck
Fusion 1600w Digital 5 Chanel Amplifier
Stealth 13" Slim Line Sub Woofer
Soundstream 6" 95w RMS Splits
Soundstream 6" 120w RMS SE652T Rears
Full Recovery Kit
Roothy First Aid Kit
Delta 1A 10B 1Kg Firer Extinguisher x 2
LED Lighting and Cargo Lights
Window Tinting @ 25% Shade
Power & Drivetrain
Front Air Locker
Suspension
OME Steering Damper
Wheels & Tyres
OFFROAD
ONROAD
Exterior
Flexi Flares
Under The Bonnet
K&N Air Filter
3 Row O/S Radiator
Dual Batteries
Interior
VDO Pyre Gauge
VDO Boost Gauge
Navman XLT85 GPS
Full Recovery Kit
