1 - 5 of 5 Posts
G'day guys,
I'm trying to remove the surround to remove my headunit and so far I have removed the 4 screws on the side and the 1 behind the ashtray and something on the top seems to be holding it in place, I cant tell if there are screws or if I just need to give it a good yank out but thought I'd ask before I break something.
Cheers guys,
Mitch!
4 Screws on the side?
I thought it was 1 Screw behind the Ashtray, 2 screws on the side and 4 Screws on the top
Are you trying to take the whole facier off?
If so, i almost broke mine the other day.
There should be 2 or 4 (can't remember how many) screws in the top of the airvents at the top of the whole facier unit. They are pretty hard to see, and are well hidden.
Hope this helps.
thanks guys I'll give it a go, also I meant 2 screws either side not 4, sorry haha
Cool... that means you've missed the 4 screws in front of the air vents that screw at about 60 degrees of vertical.
Undo them and the whole lot will drop forward and you can undo the necessary plugs to get it to one side and work on the H.U.
1 - 5 of 5 Posts
