nissan patrol wagon petrol/gas 1992 4x4
when I turned te key it started and stopped, when key held on just a little it runs,
over bumps it would stopped, start again old little bit pressure to key would run, ,,then over a bumpy rocky rd it stopped and now no power to dash, accessories, starter,,, any Ideas, I have tried alot of things,, but better to ask than to tell ..
Thanks
Tony
NISSAN GU PATROL
Sounds like loose connection somewhere behind the ignition barrel or even a faulty ignition switch.
nissan ignition problems
Yep have chased wiring-- xonxfxn--, all over the place, have some new bits coming, but I think you could be right, thanx for taking the time to answer,
Tony
Ignition Problems 1992 wagon Petrol/gas
Gidday all,
would anyone know where I could get and ignition barrel for this wagon, also new points and dizzie cap. and any idea why spot lights stopped working, I have actually had problems since I had the Electronic trailer brake switch fitted , now I think about it.
Thanks for your time,
Tony,
