Been slow progress on the 46" project, my times been split between two other projects. A 6.5 swapped y60 on 44" and an old dodge ram I have on 38".
I have however managed to do a couple of things.
Managed to fabricate the links for the rear. Just welded some bolts to some square tubing for a cheap jig and cut the 50 mm heavy wall pipe to fit between the bushing tubes.
All in all I'm pretty pleased with this first attempt at a triangulated four link
I also quickly tossed up four body mounts onto the frame as to locate the body when it goes on. I will then bolt the other new mounts and weld them to the frame after the body is on, seems easier this way.
The mounts at the rear need to be moved forward 15 cm because of the frame extension and all of them will be raised 5 cm as a body lift.
These mounts are not finished. Gotta drill out the plates on the two near the center of the frame and brace the ones at the rear. But all in all it's coming along.
Funny seeing as I go along how tall it's going to be. On the 46" baja claws I suspect the floor in the rear will be at my shoulder, standing at 186 cm. It may introduce problems later on but I'll deal with those when the arise.
