Hi, Thanks to the members of this forum, my '98 2.8 GU Patrol with 250K no longer has hot start issues after spending $40 bucks and less then 1 hour with the spanners.
Last year my car started to develop hot start issues. Car starts fine when cold, but once you drive for a few minutes or more, turn the engine off and try to start again before it had a chance to cool down (2 hours), it would take up to 6-10 seconds to start. Over time, this became 16-20 seconds. After having to restart the car a few times within an hour, the battery would be flat and the car would need to be jump started.
The "specialised" diesel shop I took the car to told me that it was the Fuel Pump which needed to be replaced at $5000 or revised at about $3000. Note: this was the same shop that convinced me to replace the turbo for a new one at $1500, when all it needed was a revision kit at $150 and 2-3 hours of work.
Hence I went to look on-line and found an old thread telling me about a modified cover plate (for the fuel pump) which could resolve the issue. I thought to give it a try..
Then, the Nissan Dealer in Sydney could not help me with this as they had never heard of it. First I called them, then I visited the service centre and even after giving them the correct (Nissan Genuine) part number, they still could not source it...
Again thanks to this forum, NIZZBITS came to the rescue. I emailed them, they sourced the item and had it delivered to my door for 40 Bucks (thanks guys). One hour with the spanners later and my truck was as good as new.
I obviously need to see if it lasts, but so far so good and I'm very happy I've been able to avoid or at least postpone a very expensive alternative fix.
