nissan GU Patrol
Can someone give me some clue on how much S%#T I will have to remove to replace passenger side engine mount on a 98 2.8. No manual I have looked at show the removal.
Thanks
nissan GU Patrol
Discussion Starter #2
anyone. Where's Benno
If I were doing it. I would remove the intercooler undo engine mounts. Put a jack under the gearbox and undo those bolts. Jack the motor up with engine hoist and lower the gear box. It's worked for me in the past.
Good luck
nissan GU Patrol
wow, thanks that seem a lot of work just for the engine mount. I've do the job now thanks Troy only had to remove the intake pipe on the turbo and jack her up.
