Hi Guys,
Questions keeping coming up about mods for the 2.8 (eg blocking egr, removing butterfly)
I thought id start a new thread with links to previous posts - threads that contain information - mods, also some of the mods that Ive done.
Feel free to add to this -
-EGR (exhaust gas redirection) blocking, intake butterfly removal
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/egr-blocking-2-8td-gu-41478/
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/blocking-egr-2-8-a-48527/
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/egr-blocking-intercooler-mods-37901/
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/erg-mod-2-8-td-23285/
-Intake manifold (why you should clean after fitting catch can or blocking egr)
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/2-8-gu-intake-manifold-61836/
-Cleaning of MAF (Mass Airflow Sensor)
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/2-8-maf-32994/
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/cant-do-maf-12962/
-Exhaust upgrades for noise - performance
I went 2.5 inch straight through, made a noticeable difference in power (im guessing due to the turbo spooling up quicker)
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/99-2-8-gu-exhaust-2-5-inch-3inch-58727/
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/gu-2-8td-exhaust-4658/
http://www.patrol4x4.com/forum/general-patrol-discussion-17/98-gu-2-8-td-change-exhaust-49003/
-Boost gauge install
I've got mine installed now, along with a McNally combo boost/pyro gauge & a Turbosmart boost controller. I know I could have gone for a cheaper boost controller, but I didn't want to stuff around & wait.
I'm still fine tuning the chip & boost. Without the boost controller it would normally go to 12-13PSI but spike to 15PSI if I floored it. I've now got it going to 15PSI under normal acceleration. It still blows a cloud of black smoke when I first take off, but is OK after that. I might wind the chip back a bit more, as it is still idling just a little bit rough. Has everyone else wound theirs back to a perfectly smooth idle or left it a bit higher?
Boost Sender for Gauge
Boost Controller
Gauge Mounted on Steering Column
