Hello Everyone
Over the Chistmas break my 2.8 started cutting out sometimes when my revs lowered, I could feel the engine would run a little rough, but it would start ok straight away. Then it would run fine for half an hour then it would do the same.. cut out. The malfunction light on the dash would come on.
The injector pump is tired, I have put an advance plate on it. The pump has done 270000 k
I have cleaned the MAF, I have cleaned the crank angle sensor but fault code still flashes 47 which is the crank angle sensor.
Anyone had the same problems and were able to fix?
