1 - 3 of 3 Posts
Hi all, looking to block the EGR just wondering do you remove that piece that goes into the manifold (tube like piece) first or just put the blocking plate behind it? I actually thought it was already blocked as there appeared to be a metal plate there but once I unbolted the EGR realised it isn't. Cheers
I just unbolted the two bolts, and slid the valve assembly toward the engine.
Then you just slide in the blanking plate and re fit the valve assembly.
Blanking plate template
Before:
After:
The next thing after that is to remove the butterfly from the cold side of the intercooler
Refit and away you go :)
Plenty more info here:
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/2-8-gu-mods-62629/
Mungrel your a champion. Thank you very much that is exactly what I was after and the pics help big time. Cheers mate
1 - 3 of 3 Posts
