1 - 2 of 2 Posts
Hello,
I have 1999 2.8TD GU with bad gearbox (worn bearings-noise in 1,2,3 and 5 gear).
And I have a good GQ gearbox, which doesn't fit because of different clutch/flywheel and prop shafts...
Can I just change the input shaft and front case(bellhousing) and use GQ gearbox?
Regards, Gregor
Patrol 99 2.8 Gu / Y61, converted to a 2007 ZD30 CRD
To change the input shaft you have to pull all the internals to bits, just as easy to change the bearings then, i just did on my 2.8 GU, takes some time, but in the end you will have a better gearbox :)
/Spawn
1 - 2 of 2 Posts
