1 - 20 of 20 Posts
Got bored on the weekend and decided to slap in a body lift, lol - kit from Marks4wd.com
Looks good. Im planning to do the same thing real soon but probable only 1-1.5inch lift.
Can i ask, did you keep the stock bush where the cab meets the chassis ? Do you think its worth while to change it at the same time as doing the lift ?
Just kept the stock bush, none were cracked just gone hard. If you have the bushes you may as well, but i wouldn't bother...
Should do some before after pics too. so we can gauge the effectiveness.
So that is 2inch + 2inch now?
I forgot to take a few pics before hand that's why there's a dodgy couple on the hoist. Right now its a 2" + 2" but it has Heavy Duty Lovell's coils all round which lift it a little higher and 20mm spacers in the rear.
Part of the furniture
mind if i ask who installed it?
and how much?
did they do all other related issues with the lift?
ie, fan shroud, fuel filler, gear leaver?
i wanna do a 2" BL in the shorty.
Installed it all myself,the kit was $300 odd including a selector lock plate for the transfer case.
I had to drop the bottom off the shroud, cut the plate under the gear boot and slice a small amount off the floor and also had to bend the bracket for the clutch slave line. My GQ has had a dodgy Gas conversion done in the past so i also had to rehang the gas line and neaten a few bits up. The doesn't seem to be any issues with the fuel filler but i may have a few issues with the gas as the filler is mounted in the rear bar which still needs to be lifted. I haven't worried about the bull bar as im gonna order a new one later this week.
If you have the $$$ (it will cost you between $300 and $400 for new bushes) and they haven't been done in the last 5 - 10 years, DO IT WHILST YOU ARE DOING THE BODY LIFT!!!!!!!!! You will be revisiting them in another 5 years time or sooner if you don't, and they are so easy to do if you have the bolts undone anyway.
$$ is the concern really if they dont look perished and cracked why change them? plus it only takes an hour to rip all the blocks back out again...
Previously known as twodiffs
1991 GQ Safari.
What marin said, also fit new bolts as well, I ditched my original 10mm bolts and fitted 12mm high tensile ones instead....they fitted straight through the same holes etc.
Discussion Starter · #12 ·
Found them on EBay, but cannot sem to find them anywhere now, only bought them 3 months ago - i thought they were tail lights when i ordered them lol.
Nissan Patrol GQ SWB
I did a 1" bodylift in my shorty a few weeks back but also replaced all the body rubbers. Old body rubbers kind of looked ok, but when place next to the new ones there is a nice difference in height and suddenly they didn't look as good a nick as originally thought. With the 1" bodylift and new rubbers it raised my shorty by about 35-40mm. No other changes required like rad shroud etc, just bent the 4x4 shifter so I could lock it in low. REAL easy to do yourself, I am an office worker so for me to be on the end of some tools, doing something I had no idea about and getting it done really says something for the average bloke out there wanting to do the same thing. Heat on the back captive nuts is a must.
Truck looks good 2Lucid, I am liking the bighorns a lot, need some myself! And those spanky indicators!!
Discussion Starter · #14 ·
thanks Branchy,
its such a simple modification i can see why so many people do it....
where would you get these mounts from, i need to do mine
PM Garry from NIZZBITS on this site or email [email protected]. He can sort out and with the best prices!
Just remember to use heat on the rear captive nuts and they will come out a breeze.
Patrol 2.8 TD
what size r those bighorns, i was leaning towards MT's but damm those maxxis look sweet
Discussion Starter · #20 ·
33x12.5x15's on 15x10's. Thinking about 35's now ive gone the body lift though haha
1 - 20 of 20 Posts
