After having some driveline vibration issues after my 2" Lift I fitted a pair of Adjustable Upper Trailing Arms, I started by making them 5mm longer than the centre to centre dimension of the original fixed length trailing arms. This made very little difference, the vibration was still there but slightly quieter. I then increased them a further 5mm in length and there was a noticeable difference, not completely eliminated but a big improvement.
So after a 10mm increase in the length on the Upper Arms I got a result which nearly eliminated the vibration.......BUT.....after a couple of weeks letting everything settle in, it's back, not as bad as the initial problem but it's not sorted.
Am I correct in thinking when I had my 2" lift that the rear diff would have dipped forwards, as in to say it "rotated forwards towards the front of the vehicle".....? Should the Upper Trailing Arms be increased in length to push the diff back, as they are mounted to the top of the rear axle it kind of makes sense......?
Is it correct to keep increasing them until the vibration stops, I didn't know if 10mm was that much or not.
Any clarification would be welcome
Johnny
Johnny
